Question about Pioneer Car Audio & Video
My Pioneer DEH-1550UB does not shutdown when I switch it off. The lights stays on. How do I turn it off without detaching the face?
jbreth
  • 69 Answers
SOURCE: Pioneer DEH-P4000 DFS Alarm driving me crazy
How to disarm DFS alarm How to disarm DFS alarm Disarming alarm Upon entering your vehicle and within the ENTRY DELAY TIME set within the DFS alarm Menu, attach your Pioneer Detachable face. If you have forgotten the Detachable Face Panel: If the STARTER DISABLE is ON, insert the ignition key in the ignition within the ENTRY DELAY TIME, then turn the key from OFF to ON 5 times within 1 minute. If the starter disable is OFF, insert the ignition key in the ignition and turn the key from OFF to ON within the ENTRY DELAY TIME. CAUTION: If the starter motor will not run, the cause may be the DFS alarm. To check whether the DFS alarm is cause, try switching the position of the switch installed according to the AVOIDING TROUBLE section of the installation manual. If the DFS alarm is the cause of the trouble, then the starter motor will run. In case, confirm DFS alarm operation in safe place. If there is no problem, switch back to its original position. If left at the newly switched position, some functions of the DFS alarm will not operate. If the starter motor will not run after switching the switch, something other than the DFS alarm may be causing the problem. Have the vehicle checked at a nearby dealer. ----------------------------------------------- Select the DFS alarm feature ON/OFF mode (alarm ) in the initial setting menu. Press the arrow (up) button to switch the DFS alarm feature ON. Press the arrow (down) button to deactivate the DFS alarm feature. Press FUNCTION button for 2 seconds to enter the DFS alarm setting menu These are a couple of things I found to fix this problem. Here is the link that I got them from: http://www.pioneerelectronics.com/pna/v3/pg/support/knowledgebase/0,,2076_310069579,00.html Hope this helps:) Jason
Posted on Sep 04, 2007
  • 124 Answers
SOURCE: how do i turn aux on my pioneer deh-7600mp radio
Shut it off then hold the function button, cycle through till you find your option to turn it on, the turn the radio back on and use you source button to change to CD, TUNER, and AUX
Posted on Dec 27, 2008
xscrewdriver
  • 246 Answers
SOURCE: Pioneer 7800MP can't turn on
It looks like the flexible cable worn out. Try to replace the cable.
This link may help:
Intermittent display on Pioneer DEH-P7800MP car audio
Posted on Jun 04, 2009
  • 7 Answers
SOURCE: Car Radio just stoped working.
My same model did this too. The wiring harness may have gone bad. Try direct wiring the stereo or replacing the wiring harness if you can get one. This fixed the problem for me.
Posted on Jun 28, 2009
kenw392
  • 2226 Answers
SOURCE: Pioneer deh-p8600 Motorized face not functioning
it probably has a bad flexible cable.
Posted on Jul 29, 2009
FACE OFF KEEP S COMMING OFF PIONEER DEH-14UB
hi teresa, you have a problem with the face latch on the unit, or the holding groove behind the detachable face. have the mounting of your unit checked out by an installer as well. check for broken plastic holder section of the units front chassis. if all checks out well then best you have your unit seen to by a technician. cheers.
Jun 22, 2012 | Car Audio & Video
Pioneer premier deh-p880 prs faceplate opens when you turn car off
The face folds down to give you the option to remove the face if you want. It will return to the upright position a few seconds later whether you remove the face or not. There should be a tab on the underside of the face you can push should you decide to detach the face from the chassis.
May 07, 2012 | Pioneer Premier DEH-P880PRS
I have a DEH-3087 CD receiver but I cant find the manual book. Can you share the Manual Book in soft-copy ?
Keep in mind that the Pioneer DEH-3087 CD is the Indonesia's Daihatsu OEM version of Pioneer DEH-2950 MP, with screen color to match the dashboard light, no remote control, and no detachable face, and with an interface to Toyota wiring. This user guide link for Pioneer DEH-2950 MP can be used for this model: www.pioneer-latin.com/downloads/crd4138a.
Hope this helps (remember to rate this answer).
Mar 11, 2011 | Pioneer Car Audio & Video
FACE NOT LIGHTING UP
what you need to do is call pioneer and find a pioneer service center that is close to you as possible and get in contact with them and get a ball park price to replace the bulb in face or face of radio if it detachable you could buy just the face of the radio ... or maybe something else but have it serviced so you dont have to buy new one hope it is still underwarranty
Dec 23, 2010 | Pioneer DEH-P850MP CD Player
The detachable face plate opens up when i turn off the ignition
This is a option you can disable in the menu, it is meant to make it easier to detach the faceplate when you leave the car
Apr 12, 2009 | Pioneer Car Audio & Video
This link may help:
Mar 24, 2009 | Pioneer DEH-P7800MP
PIONEER DEH-P7700MP/P770MP CD/MP3 Faceplate
do you want the detachable face or the case to hold the detachable face?
Here is the detachable face at the Pioneer site:
http://parts.pioneerelectronics.com/part.asp?productNum=XXA7322
Here is the case for the detachable face:
http://parts.pioneerelectronics.com/part.asp?productNum=CXB3520
You might find the face, or even the whole radio with face cheaper on ebay.
Jun 20, 2008 | Car Audio & Video
Face not detaching
HAVE YOU TRIED PRESSING THE eject switch located on the right hand bottom side just below the display ? this switch will work for just 2-3 seconds after u switch OFFthe iginition.
OR
With the stereo OFF (iginition turned ON) press the multicontrol to access face opening ON or OFF .select ON . and the face will always open when iginition is turned OFF .
rate me positively if you feel helped .thanks .
Jun 06, 2008 | Pioneer DEH-P6800MP CD Player
Car Audio & Video Logo
18 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
