Question about Brother FAX-8360P Plain Paper Laser
I have trouble faxing over my voip line
Brother MFC4800 will dail out the get the response the gets static and fails to send. Or it connects with the other fax but transmission fails due to poor line condition. What can I do to improve this??
  • Anonymous Apr 15, 2008
    Poor line quality error on faxes over voip trunks on 4100
  • 47 Answers
You need an analog line for fax to work
Posted on May 12, 2008
Suggest try connecting your fax machine to another telephone walljack.
Posted on Mar 17, 2008
    New Friend:
  • 120 Answers
SOUNDS AS IF YOUR PHONE LINE IS THE PROBLEM. LAWRENCE
Posted on Feb 16, 2008
SOURCE:
Fax problem
I want to make sure I understand this completely. You get no dial tone from the fax machine when hooked up to VOIP. In the past, was there an audible dial tone from the fax, or did it just dial silently and give you an error if there was no tone? When you said you got a dial tone by connecting a phone to the ext phone port of "the machine" did you mean the fax machine? If you get a dial tone by running a phone through the fax machine, then the line is good. I have used a fax machine over Sunrocket before they went defunct, which used the same technology base as Vonage - so it should work. If you used to get an audible dial tone when using the fax, and no longer do, and you are geting a dial tone on a regular phone that is connected to the ext. port of the fax machine, then the problem has to be in the fax machine itself, not the VOIP. If you can verify that, we can go from there.
Oct 08, 2007 | Brother MultiFunction Center MFC-440CN...
I'm not sure what type of machine it is but I think it's a Brother. It has a separate fax line and isn't connected to a computer or network or anything like that. The machine will receive faxes fine but...
Are you working with a line over VOIP like Vonage? If so faxes can be hard to send and receive because of line condition.
Also, if you have DSL make sure that you have the proper line conditioners in place so you have good line condition.
If those aren't a problem then contact your phone provider to discuss the issue.
Mar 03, 2011 | Office Equipment & Supplies
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
Km-2550 fax machine stays busy for long periods while it has document in memory and is communicating. The product is not a Lexmark, its a Kyocera KM-2550, but thats not a choice so...
1.....connect a regular fax to the line and see if you get the same response if you do then its a phone line issue... ... now lets troubleshoot...plug a phone in and pick up the reciever... listen for static on the line... if there is static... that can cause issues... call phone company... also if its voip... that can cause issues... if so tune your voip or get filters and this might reduce it... and possibly eliminate the issue.... if not... then i would call a kyocera tech and have him update the firmware for everything on the machine... printboards... scanners, fax... main system and if it keeps happening I would replace the fax board... still happening replace main board...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 19, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Comm error on a VOIP line
Fax cannot send on a VOIP line unless the VOIP line has T.38 fax protocol service.
Sep 25, 2009 | Brother FAX-575 Plain Paper Thermal
Have voip and brother mfc 7420. error code 2001 and 2006
Get a new phone wire. Put a phone on the line and listen for static. Too many phones on one line will cause problems. If the phone line is going thru a surge protector, check the quality of the sound with it and without it, it may be damaged. Keep power wires away from phone wires, they cause static.
Apr 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Aug 12, 2008 | Brother IntelliFax-4100e Fax
Brother Printer Fax Machine
The connecting depends on several issues. This cant be said within a few words.
You have to read the manual which explains the very diffrent setting (see chap. fax). You can download the manual here:
www.brother.com (choose your country from landscape, choose your country, choose download&support)
Have a look at the faq, too.
If that doesnt help, plz call brother hotline of your country!
Jan 11, 2008 | Brother Multi-Function Center MFC-240C...
Brother FAX-8360P Plain Paper Laser Logo
200 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
