Model 10904 exide nautilus gold charger. 12v dc ok but pc board controller not functional. Need schematic or how to purchase pc board.
Unable to complete install Huawei Mobile model
Posted on Oct 15, 2013
I need a schematic for a LT2 echo board to install in my president grant PC-409AB
break audio line. J2 input goes to mic pin J1output to radio.
(leave the shielded ground wires disconnected. on audio)
Power use a 1k ohm resistor from 12v dc on pwr switch.
Ground run the ground wire to board ground
test and set echo level.
this will work for any radio. if the echo needs 12v instead of 8v remove the 1k resistor and just use a 1n4001 diode on the power wires . some models require 12v some are 5-8volts.
Jan 18, 2015 | Radio Communications
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
HOW DO I RECHARGE SPECIFICE CHARGER OR BY COMPUTER
By computer so that you will obtain the specific charger that you need.
plankw,
What laptop is it? Manufacturer name, and Model Number.
(Bottom of laptop)
Also,.....on the Bottom of the laptop is stated the Input, and Output voltage.
Your concern is the input Voltage, not so much about the Amperage.
(V = Voltage, A = Amperage)
Example;
Input: 12V2A (Sometimes printed as 12V~2A)
12 Volts at 2 Amperes.
The AC adapter (Charger) must also have the correct plug to fit the laptop's DC Power Jack.
(DC IN)
Regards,
joecoolvette
Apr 21, 2011 | Computers & Internet
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Have lost manual. I need car charger for Mio P550 but Mio no longer making. Have purchased Scala AC Travel Charger Part No; SEL15305 (Input voltage 100-240VAC, 50/60Hz) and end is right but not sure if it...
The important thing is the ampage. If you have your old car charger check the ampage output. A higher amp rating charger will be ok as the p550 will only draw the current it needs. The voltage you listed sounds like a house charger not a portable car charger. cars run at 12v and the output should be something like 5v dc - 1amp (normally anyway).
Feb 18, 2010 | Mitac Mio P550 GPS Receiver
BATTERY SPECS FOR A JEEP GRAND CHEROKEE 2.7 DIESEL WHAT IS THE CORRECT BATTERY SIZE
Exide 031SE Exide Excell Car Battery (EX22) £76.79 Numax 069 Numax Car Battery 12V 68AH £55.99 Exide 069SE Exide Excell Car Battery (EX69) £76.79 Optima Optima Red Top RT S 4.2
(8002-250)
(BCI 34) RTS4.2
£149.05 Varta Type 069 Varta Asia Car Battery 12V 70Ah
(Short Code: E24)
(Varta DIN: 570 138 057 or 570 413 063)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
(8002-250)
(BCI 34) RTS4.2
(Short Code: E24)
here are some batteries that will work . you can find equivilants to what ever your dealer carries .. :
exide 031se (EX22)
exide 069SE (EX69)
Numax 069 12 v 68AH
Optima RT S4.2 (8002-250) (BCI 34) RTS4.2
Varta type 069 12V 70AH (E24)
Oct 14, 2009 | 2003 Jeep Grand Cherokee
Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Jul 03, 2009 | Kitchen Appliances - Others
Computers & Internet Logo
130 people viewed this question
David Payne
David Payne
