Question about Electrical Supplies
SH 5300 EX ELEMAX GASOLINE GENERATOR BURNING OIL AND CHOKING OUT EVENTUALLY.
    Master:
  • 452 Answers
Sounds like rings are worn is it difficult to start,remove plug and do a comp test, possably ok on test because oil ring wear out quicker the reason i ask u to do is if compression down also it mite need a new piston if not u might get away with re ringing the piston
Posted on Oct 15, 2013
2 Suggested Answers
SOURCE: generator is burning oil and choking out
my gnerators burning oil iam start generator not smok then why oil burning oil please help solution
Posted on Sep 21, 2013
I have problem on elemax shw190 generator welding machine, the problem in not giving enough power for welding. Wishing for your help thanks
It will be either the Amp selector switch is starting to fail or the AVR. I would start by checking the switch is not showing signs of burning. (You can order a replacement here>> http://www.generatorguru.com/shw190/?sort=featured)
If you are not getting the correct voltage to the electricity plug sockets then it is most likely the AVR. This can also show up as a surge in voltage as well as low Voltage results.
Hope this helps! :)
Nov 29, 2016 | Electrical Supplies
Starts runs great turn off the it won't start again
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Great video on low pressure warning switch removal and ...Pulled off the shroud over the sensor. ... It wouldn't start so I replaced the spark plug, gas, and oil - then it did as yours. ... 1200 Watt Generator Won't start - Duration: 14:49.
gasoline engine on portable generator won't start what do I ...
answers.angieslist.com/gasoline-engine-portable-generator-won-start-I-d...
Apr 16, 2014 - gasoline engine on portable generator won't start what do I need to do ... PULL, Take OUT the spark Plug , make certain it is clean and DRY and then start allover again. ... start then when talking pulling rope use electric starter - if won't ...several times till starts, moving choke to OFF or RUN position once it ...
How To Fix A Portable Generator That Won't Start ' My ...
blog.mygenerator.com.au/how-to-fix-a-portable-generator/
Jan 21, 2016 | Electrical Supplies
What's the best choke setting for starting a cold generator
Full choke to start, open choke partially immediately the engine starts to where the motor runs smoothly, continue opening as soon as you can while keeping the engine running smoothly. Be sure to open fully before leaving the unit, running it with the choke partially on can cause a rich fuel condition which tends to wash the oil off the cylinder walls and it also dilutes the oil with gasoline.
lp
Dec 26, 2010 | Coleman Powermate Portable Generator...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Weedeater is usable and ready, don't know how to start it
I hope you have fresh gas and 2-cycle oil mixed up! They always seem to start strong and explosively cut on good, fresh fuel. :D
1:Choke on.
2:Push the primer bulb (rubber ball by the side of the air filter) 3 times.
3:Place trimmer on ground. Grasp the handle, squeezing the throttle fully in left hand. Kneel and give that starter a crisp, sharp tug with your right hand. If the engine "hits", then push in the choke until off. Goto step 4.
If it does not give a hint of life, repeat the tug on the line 2 more times. If it STILL does not start, check for a distinct odor of gasoline. Likely, at this point, it is flooded, proceed to step 5.
4: With choke now off, continue to depress the throttle fully and give it another sharp pull on the starter. If it starts and revs? Let it idle for a minute to warm up, then go to work!
5:With choke OFF, press and hold throttle at full. It may take several pulls on the starter rope to see any life. If after 10 pulls and there is still no life, and still smells of gasoline - time to see the Ex about getting the trimmer looked after for some TLC. :D
May 08, 2010 | Craftsman 25cc Gas Line Trimmer
I have a coleman powermate generator 5000 in from 2006. Has never been started. I tried to start, filled the oil/gasoline and It would not start. What can I do beside's taking it in for service.
Remove the air cleaner and spray some starting fluid into the carb. If it starts then ok if not then remove the spark plug and check for spark.
Keep posting until its fixed. Give the model number PMxxxxxx.
Jul 27, 2009 | Coleman Powermate Powermate 5000W...
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Have a 16k propane guardian generator have to manually start and
Is this an RV generator?
If you have to really choke an LP engine but it runs more or less normally once started you need to troubleshoot the demand regulator and the fuel supply lines (look for air leaks). I'd also check the fuel inlet pressure before the demand regulator.
Rate me,
Carl
Nov 19, 2008 | Guardian Rv Generator 4800 Watt, Gasoline,...
Electrical Supplies Logo
57 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
