Question about Acer Aspire T135 PC Desktop
Acer v5700gx beeps all the time when I connect to power, nothing else, just beep beep beep
ardmax
  • 155 Answers
SOURCE: acer ast180
The beeps that you are hearing are messages created by the POST (Power On Self Test) to indicate that something is wrong. If you know your motherboard type it is possible to find the documentation explaining what 3 beeps mean.
Because we don't know the motherboard type (At least for now) let's use the common sense.  Did you verify that the power supply is properly connected to the drive?  Can you confirm that removing the second Hard drive it boot again ok? In some type of BIOS 3 beeps means memory problem. By accident did you touch the memory? Are all the ribbon cables well plugged in?
Posted on Oct 20, 2007
Teis
  • 340 Answers
SOURCE: Have a Acer Aspire E380
Your problem can arise from several things:
1. Keyboard not connected,
2. Monitor not connected
3. RAM error (defect RAM)
4. Graphic card defect.
5. HDD error
Solutions:
1. Have a look, check if both keyboard and mouse is mounted tight?
2. Have a look, is it mounted tight?
3. If, you have two blocks, on each 510MB, you swap them around, or, leave one at teh time, fire up, still the beeping, turn it off, take this one out, and put the other in.
If your RAM is one block of 1024MB, you would have to by yet another one to do this (and, it won’t hurt to have 2048MB, only make it faster.
4. Have you got another disk, put it in, Install your OS, and fire up.
If none of the above works, then I hope for you that the warranty is still active.
Regards
/Teis
If, this on the other hand was of some kind of help do vote before you leave, -thank you.
Posted on Dec 15, 2008
  • 233 Answers
SOURCE: ACER Aspire- beeping sound - 6seconds when I power machine on
The beeps are telling you there is a hardware failure (POST). The number and length of beeps will give a better indication as to what has failed. Write back with that info and someone on this web site will interpret this for you.
Posted on Jan 19, 2009
bob_computer
  • 3153 Answers
SOURCE: Acer T180 powered up all i get is beeping . From the hard
The beeps you refer to are known as "computer beep codes" and may also be known as "computer post codes" although they are in fact slightly different with the post code being the more technically descriptive of the two.
These are very descriptive and can tell you exactly where to home in on the problem.
In the back of your manual should be a list of these beeps and if you listen very carefully the are quite similar to morse code it is this distinction the gives you the information. If its not there then you should go here
http://www.postcodemaster.com/
You need to scroll down to the beep codes.
or try here
http://www.pantherproducts.co.uk/Articles/Motherboard/BIOSbeep.shtml
Sometimes it is just a matter of opening the computer (good time to blast the dust bunnis with a $3 can of compressed air (outside of course) and then remove each connection (one at a time) and reconnect before doing the next one.
You should do this with all the cards, rem, and cables. (computer off AND disconnected during the above)
If any of the connections seem difficult the look for a small pusf in latch on one side of it and push it in whilst wiggling the connection gently.
When you have done connect and try your computer again.
If you were lucky it may now work again. If not you may have to seek more help at your local repair shop.
Posted on Aug 11, 2009
  • 16 Answers
SOURCE: I have an Acer T180 desk top which was working OK. Now just beeps
The beeps you refer to are known as "computer2.gif beep codes" and may also be known as "computer post codes2.gif" although they are in fact slightly different with the post code being the more technically descriptive of the two.
In the back of your manual should be a list of these beeps and if you listen very carefully the are quite similar to morse code. Its this distinction the gives you the information. If its not there then you should go here
Posted on Oct 18, 2009
I have a Acer Verton E430 Desktop. Suddenly upon restart after the initial beep and Acer splash screen returns to restart with one short beep and process continues on and on.. Advise how to solve.
One short beep can be DRAM refresh failure.
  1. Remove RAM memory, Graphics card, other Plug-in cards, and Drive cables from your mainboard.
    Only CPU + Fan + Power cable are installed on the mainboard.
  2. Power on the PC, and listen to the beeps:
    • no beeps => Power supply, CPU, mainboard or BIOS is most likely defective.
    • some beeps => remember the beeps and next step.
  3. Power off the PC, and insert the RAM memory.
  4. Power on the PC, and listen to the beeps:
    • no beeps => RAM incorrectly installed.
    • same beeps as before => RAM is most likely defective.
    • beeps have changed => next step.
  5. Power off the PC, and insert the Graphics card.
  6. Power on the PC:
    • some beeps => Graphics card is most likely defective.
    • blank screen =>Graphics card is most likely defective.
Dec 02, 2014 | Acer Computers & Internet
4 Beeps on my Acer X1935 and then nothing, no display
maybe you check on Rams, sometimes BIOS battery
Nov 11, 2012 | Acer Computers & Internet
My acer aspire laptop makes a beep sound when swith on button is pressed
beep are of manyh types how many beeps it gives?????? reply me fast so that i can help u
Jul 06, 2012 | Acer Computers & Internet
Long beep and continue acer motherboard N1996.
1. Beep codes indicates that there is some problem with your RAM memory sticks installed into your computer motherboard.
2. For detailed information about the beep codes, refer your motherboard user manual as there are different kind of beep notifications for different problems.
3. Try removing the RAM from your motherboard, clean of any dust, replace it back to the motherboard and try starting your system. Repeat the step for atleast 10 times, until your system starts up.
4. If still the problem, persists, try replacing your RAM and try again as this will help us to find out if the problem is with RAM or not.
I hope this is helpful to you.
Please rate the solution provided.
Thanks
Jun 29, 2010 | Computers & Internet
The PC powers up but, nothing on the screen and no beeps
You need to ensure that the speaker is connected. Then you will hear the beeps.
If you hear no beeps even then, then you motherboard is not powered. Check connections.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 23, 2010 | Acer Aspire AM1640-U1401A Desktop PC
Power light on and beeping and no picture acer aspire t180
If your computer beeps when you turn it on you have a problem with your power supply, system board, graphics/video card or keyboard.
Reboot your system with out the keyboard if it no longer beeps your problem is a couple of stuck keys on the keyboard.
If the beeping continues remove your graphics card and reboot your system.
If your pc still beeps the it is either your power supply or the system board.
Jan 10, 2010 | Acer Aspire T180 PC Desktop
Acer travelmate 290 beeping, starts with blue screen and then black and beeping
See if there is an error beep. If there is an erro beep, then change
main board.
Power off. Then check if RAM CPU BIOS are well-connected.
Press Fn+F5 three times slowly
LCD FPC
LCD inverter
LCD
USB does not work correctly USB device cable is firmly connected into the USB ports. Test
Oct 29, 2009 | Acer TravelMate 290 Notebook
Acer ast180
Oct 20, 2007 | Acer Aspireā„¢ T180 PC Desktop
No display jus beeps
Your memory chips must be had i that sounds like a chip problem under the laptop secured by two screws will be where the chip lodged pull it out and re-enter it might go it might not but that your problem I am sure of it.
Oct 10, 2007 | Acer Ferrari 4000 Notebook
Acer Aspire T135 PC Desktop Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
