Question about Welding Tools
Overcurrent condition in primary IGBT switching circut
Miller welder dynasty 200 shuts down and goes to HEL P1. Can I fix it myself?
  • 24 Answers
This is a very difficult machine to diagnose even for a factory trained person,do not reccomend.
Posted on Sep 18, 2009
I have a HEL p-6 code on a xmt 304 how do I fix it
Sounds like a input power problem . Make sure voltage is correct coming to the unit and wired correctly. I checked a Miller welder recently ,auto link that would come on and weld but not good . Took cover off and it was wired wrong .
Dec 08, 2014 | Welding Tools
Hel -10 on max star 200
The Help 10 code on a Miller Maxstar 200 indicates a depressed trigger. If it still doesn't clear, replace the trigger control.
Jul 29, 2014 | Miller Welding Tools
Have a Miller Dynasty 300 that won't tig weld, displays HELP 12 code. Suggestions??
Some welders have a resistor that is obvious and accessible but to give an error code it is likely something else inside. You'll have to look at the circuit board for a component that is burned. If you are lucky you will find a fuse.
Nov 21, 2013 | Miller SYNCROWAVE 250 DX TIG RUNNER WELDER...
How do I know date of manufacture of a dynasty 200 by serial number?
If u look on inside of the door u will see vin number manufacture and production date all on inside of door or under Hood same thing
Feb 08, 2012 | Miller Welding Tools
I have a miller wildcat welding/ generator and the problem is that when I start the generator, it runs for a few minutes and then automatically shuts off. Whats the problem?
Hi:
The most common problem is the oil pressure switch. First make sure your machine has the oil up to the level line. If oil level is ok, then order the oil pressure switch and change it. If neither of these two actions cure the problem then send it in to be inspected by an authorized service mechanic.
Good luck
Aug 06, 2011 | Howard Miller Miller Wildcat 200 Welder ...
Help code 24 ?
On this page enter your serial number and you will be able to download your manualhttp://www.millerwelds.com/service/ownersmanuals.php In the Dynasty 350 manual On Page 76, section 7-4 it says: Help 24 Display Indicates a power supply to the control and interface board PC6 failure. Possible cause is a short in Pin A or Pin B of the remote control. Unplug the remote control and see if it goes away.
Dec 05, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Miller dynasty 200 fan not running at all I have the cover off is there a way i can jumper the fan to always run? This fan uses 15 volts dc. can i jumper the temp sensor
If you have power on the input side of the temp sensor and no power out yes you can jumper the temp sensor. You should also be able to test the temp sensor with a match. Un-mount it, then heat it until it clicks and check for continuity. (Remount when complete) If you have continuity with applied heat the problem is not the temp sensor. It could be a fan relay problem.
If your sure you want to bypass normal fan power, I would look for the power source for the fan on the welder's schematic and then run a seperate in-line FUSED power lead to the fan and then ground the other side to the chassis. Make sure the source you choose has enough amperage to power the fan. Some places on the main board if you tap 15VDC you can damage the main board.
Kelly
Sep 18, 2010 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Changing from 480v 3 phase to 220v single phase need diagram on a Miller Dynasty DX tig welder Serial # KH577649 stock 903519-01-1
i have a old miller thunderbolt CC*AC/DC welder its wire single phase 480 can it be switched to 220 single phase
Dec 02, 2009 | Miller Welding Tools
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Welding Tools Logo
384 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
