Question about Denon Audio Players & Recorders
Panasonic sa vk81d tray init - Denon Audio Players & Recorders
  • 4 Answers
SOURCE: disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
I had a jammed disc that was causing this same error message. To remove the jammed disc, remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
redhead7377
  • 51 Answers
SOURCE: MY Panasonic SA-pt950 is displaying
dvd drawer need to be retimed.
Posted on Jun 26, 2008
SOURCE: cd jam in panasonic sa-pm17
Hi. Got the very same problem. At christmas I had loaded two cd's in one of the racks. I used needlenose pliers as well and pulled each of the 5 trays out (well past their runners). Tried to dismantle the unit with the 3 screws on each side, but gave up. When I turn the power off and on and do a cd check the "hello" flashes then nothing, tried cd/change power button and basically everything else. All I can say is go easy on the unit as I was to forceful an now think i've ruined it. I'm gutted as this was a great mini hi-fi and has served me well. Best of luck with ur Panasonic, cheers.
Posted on Jan 22, 2010
  • 4234 Answers
SOURCE: Panasonic Surround Sound system Displays "INIT" and Disc tray will not open
Upon powerup, these units perform some testing functions and attempt to get to a 'known" state. It would seem that this is not completing. This can be because the CD mechanism is jammed or because of a power supply problem. Without seeing the actual unit and taking a few measurements, I can not state for sure the exact problem. I would pay for a detailed repair estimate and report the results here. From that, we should be able to guide you through the actual repair.<br /> <br /> Regards,<br /> Dan
Posted on Aug 24, 2010
max6688
  • 54 Answers
SOURCE: My Panasonic SA HT730 is
PCB under DVD deck mulfunction, need replace working boards
Posted on Mar 22, 2011
My SA HT 730 displays INIT on main unit and tray will not open. Can you help me? I love my panasonic.
INIT = Initiate, reason why you cannot open it is because it is having an error starting up and it is not completing
Oct 20, 2014 | Audio Players & Recorders
Hi, My panasonic SA-HT940 IT IS READING INIT WHAT DOES THAT MEAN.??
check system output by aux port if output is normal then system amplification work proper
try another cd all cd it reading or init then lense clean with lense cleaner and try
May 18, 2012 | Panasonic Home Theater System System
Inits?
Could you please describe your problem a little bit better for me?
Dec 20, 2011 | Panasonic sa-ht930 Home Theater Audio...
it is the problem of cd changer mechanism and company have 1000 reasons to blame the user.
May 31, 2009 | Panasonic SC-HT930 System
Reciver shuts off
Check your speaker and sub connections. When they are not imputed correctly the system will shut off.
Jan 10, 2009 | Panasonic sa-ht930 Home Theater Audio...
Panasonic SA-HT680 Home theater problem
Try these steps to reset the unit. I got these from the Panasonic Cust. Service # 1800-211-7262
1. Unplug the unit power.
2. Wait 2-3 mins before replugging the unit.
3. Turn it on.
4. If the display shows INIT / PLEASE WAIT, Press and HOLD the Tune Mode (STOP) button on the main unit. At the same time press #10 (Channel button) in the remote control. They have to be pressed & held simultaneously for atleast 5 seconds. Wait till the INIT / Please Wait display disappears.
5. Once the message disappears, RESTART the main unit by pressing the POWER button OFF / ON.
6. If it does not work, try several times. If it does not work, contact a local repair shop (call them to find out a repair shop near you). If the repair shop wont do it for you, call them back - thats what they told me.
Jan 19, 2008 | Panasonic SC-HT680 System
Init please wait
I've just spent the last 3 nights trying to fix that same issue with my sa-ht670 player. I ended up pulling out the dvd tray assembly, and making sure there wasn't anything broken inside or obstructing other pieces. Come to find out, my 1 year old had pulled on one of the trays and it pulled the tray off it's tracks. After that, it would just go to "init please wait" forever. I pulled the side track cover off and aligned the tracks manually. Everything had to be absolutely perfect or else you'd get nothing. After the fact, I realized that there were two holes in the bottom of the player that you can take a spare small gear (which is attached to the plastic cover on top of the dvd tray assembly) and stick it in there and manually adjust the tray positions to make sure everything is aligned properly. After messing with it three days, it ended up being quite simple to fix. Everything works like a charm now. If you need details, feel free to email me.
seeyouatthetop06@gmail.com
Sep 01, 2007 | Panasonic SC-HT670 System
Disc tray 1 is blinking with 2 ovals around it, tray not in right Panasonic SA-HT680
Nov 19, 2006 | Panasonic SC-HT680 System
49 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
