Question about Golden Technologies Compass Electric Wheelchair
Need diagram of internal view on a gp600 compass motor and gear box
My 83 Honda shadow 750 vt won't start it whirls, it has a new a battery and have check gas lines. Pls help
The whirling your describing sounds like your describing a whirling starter that's not turning the motor, the starter is just spinning internally. Bad starter if so. Check the teeth on the flywheel if u pull the starter too.
Aug 16, 2017 | Honda VT 750 Shadow Motorcycles
How to change blower motor resister 2010 jeep compass
its under your glove box it may be your whole blower motor that has to be replaced. it also might be right next to your blower motor. you just need to remove the bolts and disconnect the wires. if they give you new wires i would replace them too. they tend to get a high resistance so that the blower motor doesnt get enough power
Jun 17, 2015 | 2010 Jeep Compass
My gear will turn without having the chain on . When chain is attached it the motor just works. No chain movement
I wasn't familiar with your saw but I looked at the parts diagram for it in the link below thinking there may be a replaceable drive pin or something like it that would possibly have sheared.
http://www.masterparts.net/111409-01.html
I didn't see any. That would indicate that the sprocket may be stripped out on the inside and would require replacement, or, that there is something stripped inside the gearcase. If you look at the diagram, the motor shaft is parallel with the handle. So to drive the sprocket gear that drives the chain, they use gears inside the housing to turn the sprocket that's at a right angle to the motor shaft. Do you follow me? It would appear from the parts diagram that if it is those internal gears, that it would require replacement of the whole motor/gear assembly ...... probably as expensive as a whole new saw!
The reason that the sprocket turns without the chain on is that there is evidently enough friction between the shaft that the sprocket mounts on, and, the sprocket. But not enough of a connection to drive the chain.
To check further, leave the saw unplugged, and use your finger to try to turn the sprocket. If it turns by hand like that, it would indicate that something is stripped out as I said. To see if it is the sprocket, remove the "Retaining Ring, 5/16" that is shown in the diagram, and inspect the inside of the sprocket. If that appears good, then it would be an internal problem and probably not worth fixing.
Ed
Oct 31, 2013 | Remington 111409 - 01 6" Branch Wizard...
2007 Jeep Compass Starter
Patrick J Farone wants answers to this question 2017
5 different engines, which one?>
USA car? why skip that,?
ever seen a starter ever,
ever do work on one ever? be key fact to know, right?
Patrick. most engines are the same, 99%
the only real question is it top or bottom access
but no engine stated so that cant be answered, the 2.4 is top
why piggy-back? generic>
1: pull neg. battery lug or boom eat acid and go blind.
2: jackup car, to stands, on jack stands,
3: see starter there, any shelds off now. gain access is NOW.
4: remove all wires to it now.
5: remove all base bolts, it falls and hits your head, duck please.
6: reverse above, should not have to be said but there.
watch 100s do it on Utube yet? no lack of examples there.
all cars same once seen with eyes have you?
now ill do 2.0/2.4L jeeps (from the SM, usa issue)
  1. Open hood.
  2. Remove air cleaner box and air tube.
  3. Disconnect and isolate the battery negative cable
  4. Remove starter motor mounting bolt.
  5. Disconnect the electrical connector at throttle body.
  6. Remove Throttle body bolts and remove throttle body.
  7. push starter under intake manifold.
  8. Tip starter nose toward cooling module.
  9. Pull starter up and out.
  10. Disconnect starter motor wiring.
  11. Remove starter motor from vehicle.
May 05, 2013 | 2007 Jeep Compass 2.4
I need a pic. of a 03 chevy trany with a 323 eng.
Let me know if this helps you....
internal component exploded view:
the case and related parts exploded view:
the channel plate exploded view:
the PArking Pawl, and related parts exploded view:
the gear train exploded view:
Jun 26, 2012 | Check Point Network Adapter
Epson Artisan 810 ADF Jam. Your comment about the drop of super glue sounds like what I need to do but which gears? And where do I find a diagram showing how to remove the motor / gears? Thanks
I just finished replacing the ADF motor assembly (Part 2132225 from Compass Micro). It is somewhat tricky. You need to download the service manual via the link in the adjacent solution. There are 2 screws to remove the plastic housing and then 2 more to loosen the motor unit. It is very easy to knock loose the little plastic gears as you try to remove the motor unit. Make sure you pay attention to where they go so you can replace them. Then you have to pass the cable all the way to the corner of the lid and down to the main board hook up. There is a plastic fastener for the cover over the main board that you have to bisect to lift the panel for access. Make sure you seat the motor assembly firmly and make it very tight when you screw it back together.
Dec 09, 2010 | Office Equipment & Supplies
I need a fuse box diagram for a 2000 Mercury Mountaineer so that I can tell what fuses go to what area's
Fuse/Relay Location Amp Rating
1 20A Moonroof, Adjustable pedals, DSM, Memory lumbar motor 2 5A Microcontroller power (SJB) 3 20A Radio 4 20A OBD II connector 5 5A Moonroof 6 20A Liftglass release motor, Door unlock/lock 7 15A Trailer stop/turn 8 15A Ignition switch power, PATS 9 2A 6R TCM/PCM (Ignition RUN/START), Fuel pump relay 10 5A Front wiper RUN/ACC relay in PDB 11 5A Radio start 12 5A Rear wiper motor RUN/ACC, Trailer battery charge relay in PDB, Radio 13 15A Heated mirror, Rear defrost indicator 14 20A Horn 15 10A Reverse lamps 16 10A Trailer reverse lamps 17 10A RCM, PAD lamp, OCS module 18 10A Reverse park aid, IVD switch, IVD, AWD module, Heated seat switches, Compass, Electrochromatic mirror, AUX climate control 19 - Not used 20 10A Manual climate, DEATC, Brake shift 21 - Not used 22 15A Brake switch, Stop lamps, Turn lamps 23 15A Power mirrors, Interior lamps, Puddle lamps, Battery saver, Instrument illumination, Homelink 24 2A Cluster, Theft LED 25 15A Trailer park, Trailer electronic brake module 26 15A License plate/rear park lamp, Front park lamps, Manual climate 27 15A Tricolor stop 28 10A Manual/DEATC CB1 25A Windows
Feb 25, 2010 | 2000 Mercury Mountaineer
I need diagram of gearbox for Hobart d330 mixer
Parts manuals are available for viewing and free download at www.hobartservice.com
Dec 23, 2009 | Hobart D300 Stand Mixer
Golden Technologies Compass Electric Wheelchair Logo
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
