Question about Farberware 2.5L Single Deep Fryer, Stainless Steel
How to turn it off without unplugging it. - Farberware 2.5L Single Deep Fryer, Stainless Steel
I can't turn demo mode off or Standby from flashing on my Sony CMT-MX550i, can't turn unit off without unplugging it.
Sony CMT-MX550i -- I had good results by pressing the "TIMER MENU" button on the remote and simply setting the time. After that, no more demo.
Jan 16, 2013 | Sony CMTMX500i Desktop Micro System
My Panasonic 1300w microwave will not turn off. It doesn't cook but won't turn off without actually unplugging it or opening the door and leaving it open. Any help?
You may have a shorted door switch or a shorted relay on the control board.
You can see a help file on door switches here.
Dec 01, 2012 | Panasonic NN-SN657SMicrowave Oven
Amana ACD125R compressor will not turn off without unplugging
If it's a mechanical thermostat, then it's electrical contact points must be closed for some reason. If the thermostat is electronic, then the logic board may be fried. Either way you would have to replace the thermostat.
May 06, 2012 | Refrigerators
I suddenly unplugged without turning off my TV and now it will not turn on
Try leaving it unplugged for several minutes (15-20) and then try powering it back on.
May 04, 2011 | Samsung LN32C450 32 in TV
How can i reboot my PC without keyboard?
Here are some of the steps to you can reboot your pc without using a keyboard:
1) Long press the power button
- Press the power button for about 3-5 seconds. If the power LED or power supply fan shuts off, that means you have successfully turn off your pc. Press it again to turn on.
2) Unplug the power cord from the power supply
- Force your pc to shutdown by unplugging the power cord from the power supply of your pc. Put it back again and press power button to turn on.
Note: Please make sure you have saved important activities before doing this as this will immediately turn off your pc.
Hope it helps.
Thanks!
Feb 22, 2011 | Computers & Internet
Philips 3360H - can't eject DVD
Try this..turn it off, unplug it for a min or two, then plug it back in. THEN...if the power stays off...hit the eject/open/close button on the panel.
Sometimes this activates the eject mode without turning on the unit. IF NOT, try the remote eject without turning on the unit.
Apr 06, 2010 | Philips DVDR3370H DVD Recorder/HDD...
When turned on it sort of made a brief "crack" then a slight hum...no picture, and it wouldn't turn off without unplugging. Replugged in and hit "on" the hum returned, no picture , wouldn't turn off again...
upon realizing that no one would give me any suggestions without charging me, I solved the problem by lugging this huge TV out to the dumpster and throwing it in.
Sep 10, 2009 | Panasonic CT-32G23 32" TV
Error message 222aO-reset power
Unplug the power cable from the All-In-One aswell as the power outlet.
Leave it unplugged for atleast 1Min.
Then plug the power cable directly to wall outlet without any surg protector.
And then press the # and No 6 button in the All-In-One and the without releasing the buttons insert the power cord untill it showas up a message as Semifull reset.
If the Printer turs off then release the keys and turn the All-In-One On and then try.
Good Luck
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
Cannot turn television off without unplugging
it might be due to on/off switch failure.
Oct 14, 2007 | Zenith C27V22 27" TV
Farberware 2.5L Single Deep Fryer, Stainless Steel Logo
Top Farberware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Tom Chichester
Are you a Farberware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
