Question about ViewSonic PJ588D Projector
I am unable to change the color settings in my pj588d because the setting menu items cannot be selected in order to adjust them
Big font size
Type Change Window Colors and Metrics into your start menu, when the widow comes up your going to want to select icon as the item type. In order to adjust the font size change the value selected. Make sure you hit Apply, you may have to do this a number of times in order to get the fonts to the size you want. This will affect the size of the fonts in your OS (Windows), things like icons, right-click menus, Start Menu.... However if you want to change the size inside of other programs you will need to get inside of their individual settings.
Hope this helps.
Oct 01, 2013 | Microsoft Office Outlook 2007: Windows
How to change the font on mu laptop
Type Change Window Colors and Metrics into your start menu, when the widow comes up your going to want to select icon (or any other type you want) as the item type. In order to adjust the font change the value selected, you may also want to adjust to font size to match. Make sure you hit Apply, you may have to do this a number of times in order to get the fonts the way you want. This will affect the fonts in your OS (Windows), things like icons, right-click menus, Start Menu.... However if you want to change the size inside of other programs you will need to get inside of their individual settings.
Hope this helps.
Sep 29, 2013 | Gateway mb.bl002.001 - Nv53a Amd Laptop...
How do i make fonts bigger on everything on my laptop
Hope this helps.
Sep 19, 2013 | Computers & Internet
How do I change the font on my computer?
Type Change Window Colors and Metrics into your start menu, when the widow comes up your going to want to select icon as the item type, or any other you wish to change. In order to adjust the font face change the value selected, may also need to change the font size to make your font of choice readable. Make sure you hit Apply, you may have to do this a number of times in order to get the fonts (and size) you want. This will affect the fonts in your OS (Windows), things like icons, right-click menus, Start Menu.... However if you want to change the size inside of other programs you will need to get inside of their individual settings.
Hope this helps.
Aug 22, 2013 | Plumbing
How do you enlarge fonts on computer
Hope this helps.
Aug 21, 2013 | Fontaine Plumbing
How to adjust color for better picture
Hello there,
For the Best Picture use the HDMI Cable and here are the Settings for the color setup.
Adjusting Your HDTV Settings
Using the On-screen Display (OSD)
The remote control or the control buttons on the side of the TV can control all the function settings. The
OSD allows you to adjust contrast, brightness and other settings. The TV will save changes made to the
settings, even if the TV is turned off.
The OSD consists of several menu options. The main menu options may vary depending on your
selected input source.
Note: Some of the main menu options may have additional submenus, for example, the TV Rating
submenu for Parental Controls.
The remote control or the buttons on the side of the TV can control all the function settings. The HDTV
Settings App allows you to adjust contrast, brightness and other settings. The TV will save changes made
to the settings, even if the TV is turned off.
The HDTV Settings App consists of several menu options. The main menu options may vary depending
on your selected input source.
1. Press the VIA button.
2. Press ? or ? on the remote control to select the HDTV
Settings App, and then press OK. The Main Menu will be
shown on the screen.
3. Press ?, ?, ?, or ? on the remote control to select one of
the menu options:
? Input
? Wide
? CC
? Sleep Timer
? TV Settings
? PIP
? Network
? Bluetooth
? Help
4. Press OK to select the option or feature you want to adjust.
5. Once the menu option is displayed, press ? or ? on the
remote control to select one of the items to adjust.
6. Press OK to select it, and then press ?, ?, ?, or ? to adjust the selection.
7. Press BACK once to return to the previous screen. To return to your program once adjustments
have been completed, you can do one of the following:
a. Press EXIT on the remote control.
b. Press the RED button on the remote control.
c. Highlight and select the RED X in any menu.
i hope this was helpful don't forget to Rate
Jan 26, 2011 | Vizio M550NV 55 in LCD HDTV
I want to put color bar in pd 170
dear when u will open menu .. at last where we check ..HR. METER ,if u remmber ...
der is the option for the colour bar
Jan 25, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
Color is washed out ,almost black & white
Good Day;
Washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Good Luck, big IRISH. PS: don't change any other setting!!
Sep 07, 2008 | Mitsubishi WS-55315 55" Rear Projection...
COLOR &CONTRAST NOT GOOD
Good Day, LEE-M;
Try this :
White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change. Good Luck, big IRISH.
May 20, 2008 | Mitsubishi WS-65315 65" Rear Projection...
LCD brightness question
You can adjust the brightness or color of the LCD display as needed. 1. Set the POWER switch to CAMERA position. (In the PLAYER mode, you may only setup the LCD while the tape is playing.) 2. Open the LCD screen, and the LCD switches on. 3. Press the MENU button. 4. Turn the MENU DIAL so that VIEWER is highlighted and then press the ENTER button. 5. Turn the MENU DIAL so that LCD ADJUST is highlighted. 6. Press the ENTER button to enter the sub-menu. 7. Turn the MENU DIAL so that it highlights the menu item you want to adjust (BRIGHT SELECT, BRIGHT ADJUST, COLOR ADJUST). 8. Press the ENTER button again. You may select NORMAL or SUPER in the BRIGHT SELECT feature and press the ENTER button to save the setting. Use the MENU DIAL to adjust the value of BRIGHT ADJUST and COLOR ADJUST. You can set values for BRIGHT ADJUST between 00 ~ 35 and COLOR ADJUST between 00 ~ 35. 9. Press the MENU button to finish the setting.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
ViewSonic PJ588D Projector Logo
15 people viewed this question
Top ViewSonic Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a ViewSonic Office Equipment and Supply Expert? Answer questions, earn points and help others
