Question about Epson TM-U220 Matrix Printer
How print barcode with epson U220 - Epson TM-U220 Matrix Printer
Rain041304
  • 63 Answers
SOURCE: My Printer EPSON TM-U220 does not print....HELP!!!!!
Change port to Printer port Lpt1 not the esdprt. then uncheck enable bidirectional support/ Restart computer and then try to do a windows test page
Posted on Feb 12, 2008
  • 10 Answers
SOURCE: Epson TM-U220 Matrix Printer not printing in WinXPP
hi basiime
possible issue is port configuration. if the generic text driver works, apd driver should work too.
what may be happen is that when you install the apd driver the other printer drivers that you have were still using the same port that your apd driver were using. example, you have generic txt assigned to lpt1 and then the apd were assigned on the same port, this is were you get the trouble.
what you must do is, first, check any printer driver that you have using the lpt, say for example, you generic text is using lpt1, when you install the apd driver set it to lpt2. apd drivers will create a new port normally called esdprt. try to use that port but if that will not work reassigned the port of your apd driver to lpt2 printer port then uncheck bi-directional support. from there you should be able to print..
hope that resolves your issue.. =)
Posted on Feb 24, 2008
  • 7 Answers
SOURCE: TM-U220 printer is not printing anything.
do a self-test first. Perform by holding down the feed button then powering on the printer. if it prints then it is not a printer issue, but a driver or cable issue.
Posted on Aug 13, 2008
Basti
  • 1447 Answers
SOURCE: Unable to install Epson TM-U220B[U220 with UB-U02III usb interface] on Windows 7 AND XP!
Hi!
Are you using a third party USB adapter or a USB interface? On the self test page that you printed does it say USB connection or something that will say about USB? or does it say parallel or serial connection? try to check the dip switches setting if its configured properly. visit epsonexperts.com site for more info.
Posted on Sep 20, 2012
Douw
  • 91 Answers
SOURCE: epson tm-u220 not printing receipt info, but printing random symbols
Hello
Try to re install the drivers. Uninstall the old drivers first
Posted on Oct 03, 2012
Can i install two(2) EPSON TM-U220 printer on a terminal?
You can have as many printers as you want but each has to have a port defined. When you installed the driver, you must have defined both as one printer and now it's confused the system. Uninstall ALL printers and start again making sure each has a unique port.
Sep 13, 2014 | Epson Tm-u220 Pos Printer Serial Black
Epson tm-u220 not printing receipt info, but printing random symbols
Hello
Oct 03, 2012 | Epson TM-U220 Matrix Printer
Hi!
Dec 24, 2011 | Epson TM-U220 Matrix Printer
Every time I print it suddenly stops in the middle of printing and says "error".
hi there
the only one i could find is TM-U220 , which falls under the TM-U200 series, as stated in this link.. i i advise you to get in contact with Epson directly , as they are the only ones who can assist you with this issue..
I hope this serves you well
http://pos.epson.com/products/TM-U220.htm
http://pos.epson.com/developers/index.htm
Nov 04, 2010 | Epson TM U210PD Matrix Label Printer
Epson TM-U220 not working with window 7
download this driver APD-406aE i did it and it is working perfect with my windows 7 on a TM-U 220B
Jul 07, 2010 | Epson TM-U220 Matrix Printer
Epson m188b paper
the choice is yours
http://search-manual-online.com/epson-u220-printer-manual-manual.html
http://www.pdfone.com/related/tm-u220-thermal.html
if this is good for then its good for me, please vote me
Mar 25, 2010 | Epson TM-U220PB Matrix Printer
Printer prints garbage...
Hi
make sure it is configured to the right port and using the epson driver. go to printer and faxes and properties then ports. check of the correct printer driver is check. what type of cable are you using anyways? com for serial, LPT for parallel.
Hope this help
Jan 02, 2009 | Epson TM-U220 Matrix Printer
Problem setting up TM-U220
print the self-test, push the feed botton while powering on...
you can see there the serial interface...
baud rate, data bits, parity, stop bit etc...
then go to the printer and faxes,
right click the epson driver and click properties...
go to the ports window...
click on the epson tm u220 reciept.
click configure port...
adjust the baud rate as same as in the self test...
it works...
May 22, 2008 | Epson TM-U220 Matrix Printer
How to eject cash drawer pos
Open the Cash Drawer
Hex code
<1B><70><30><40><50>
Apr 03, 2008 | Epson TM-U220 Matrix Printer
Epson tm u220
What type of interface card are you using to connect printer to your computer?
Mar 14, 2008 | Epson TM-U220 Matrix Printer
Epson TM-U220 Matrix Printer Logo
22 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
