'Full light' blinks on and then off when you replace shred basket. Aurora AS1712x shredder. It's not full, won't work at all.
    Sergeant:
  • 183 Answers
The sensor or button that tells it it's full, probably has paper dust or something jamming it. Clean it up without liquid and it will probably work.
Posted on Apr 24, 2009
Machine says it's FULL, and won't shred, but it isn't/
there is a sensor that detects when the basket is full, if you remove the basket, look up for the sensor that would point down into the basket. it is probably dirty, clean off sensor.
hope this helps
Jul 05, 2012 | Fellowes SB85C Shredder
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
Our Aurora AS1712X paper shredder is jammed in a couple of places with paper so badly that we cannot free the jam and the tooth wheels cannot turn freely. Is there an easy way to clear the jam?
Try running the shredder in reverse and oiling the blades. More help with paper shredder oil here: http://hubpages.com/hub/Paper-Shredder-Oil
If you can't get the paper shredder up and running, it looks like you might have to pick up a new paper shredder. Paper shredders can be pretty cheap though, great guide to cheap paper shredders here: http://hubpages.com/hub/Best-Paper-Shredders
May 20, 2010 | Aurora Electronics AS882C (Cross-Cut)...
The basket full light comes on even when the basket is empty. if you hold the shred button down it will shred as long as it is pressed
needs bag full retorfit kit available from fellowes if under warranty or we have the part for sale if not under warranty cooksmobileshred@bellsouth.net
Mar 19, 2010 | Fellowes Powershred 220CC Shredder
Basket full light on
without seeing the product, there are 2 (two) things to check.
First, unplug the shredder and go underneath where the bin full flap is. Sometimes paper debris gets stuck between the flap and switch. Check to ensure the switch is not out of adjustment. you'll have to remove the top cover to perform this. Otherwise, your PC Board is defective.
Mar 02, 2009 | Fellowes 2200 Cross-Cut Shredder
The "bin full" keeps on coming on
first off, fellowes has had problems with the bin full sensors that sometimes, can only be corrected by replacing them. however, there are two things to check. make sure it doesn't have a bunch of shredded paper hanging down from the cutters. that can trigger the bin light as the sensore are located under the head, but above basket. last, but not least, clean the sensors. they get paper dust on them after awhile causing same indication. if those two things don't fix it, it will have to have sensors replaced.
good luck,
razors
Jan 20, 2009 | Fellowes Manufacturing Powershred C-220...
Shredding
check door safty switch or is the bag or box full that has a switch also? just a suggestion.
Jun 24, 2008 | Aurora Electronics AS1015CD Cross-Cut...
224 people viewed this question
k24674
jasbo
jasbo
