Question about Microwave Ovens
Set clock emerson microwave mw8769b
How to set clock.
MicrowaveSvc
  • 9047 Answers
SOURCE: setting the clock on Emerson MW 8115SS
Press Clock, press the numbers for hours & minutes, select with AM/PM pad, then press Clock again to set it.
Yours Emerson microwave owner's manual is available for free download here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Emerson MW8987B Not Working
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Posted on Sep 16, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: setting clock
Your owner's manual is here.
Posted on Mar 02, 2009
rhozel2010
  • 269 Answers
SOURCE: Emerson MW9111 will not heat- all timers & clock work
Hi! try checking the fuse that goes to the magnetron.
Posted on Sep 12, 2009
hardrocko
  • 1476 Answers
SOURCE: how to set hour on clock of emerson microwave,
Try this site http://kitchen.manualsonline.com/ex/thread/view/idThread/712587 They do not have your exact model, but they have so many I would think that there is one that would be close enough to yours to get the information you need. Check your model number again and make sure it is correct. Also try checking a manual for your brand with the same power rating. The electronic controls, including the clock setting procedure should be very similar if not identical. Let me know if you need more help.
hardrocko
Thanks for using FixYa and the generous rating.
Posted on Mar 06, 2010
How do I set the clock on Emerson microwave model mwg9111sl
Hello!
Here is the link to the manual for Emerson MWG9111SL - setting the clock.
I hope it will help!
Microwave Cooking Emerson MWG9111SL 8 23
Jun 19, 2017 | Emerson Microwave Ovens
Reset clock
Unplug for a minute and set the clock as you normally would using the clock button on the control panel
May 22, 2014 | Emerson MW8889SB Microwave Ovens
Goes to military time
According to the manual:
Press "Clock" pad once to set clock for 12 hour time clock
and
Press "Clock" pad twice to set the time for Military time.
I'm not sure what you mean by "goes to" military time.
Is that after you've already set it for a 12 hour time clock?
Jul 22, 2010 | Emerson MW8107WA Microwave Oven
Lost my manual, how do i set the clock
Many Emerson microwave owner's manuals are available for free download here.
Even though yours may not be there, there might be one close enough to help you.
For more help from Emerson
visit here or get help using your appliance at 1-800-898-9020.
Get help locating an authorized servicer or parts at 1-800-695-0098.
Jan 16, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Setting clock
Mar 01, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Microwave is new but it won't allow me to set the clock .
If you set the default for high heat, it will normally boil 8 ounces of water in 60 - 75 seconds.
Feb 04, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
My Emerson microwave is stuck in clock mode and won't cook
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
For more help from Emerson visit here or get help using your appliance at 1-800-898-9020.
Dec 05, 2008 | Emerson MW8107WA Microwave Oven
MW8107WA 1000 Watts How do I set the time? .
Cant find a manual, but on most microwaves, the clock is set by pressing the 'Clock' key, then the numbers for the time, and pressing the 'Clock' key again.
Jul 13, 2008 | Emerson MW8107WA Microwave Oven
Setting the clock on Emerson MW 8115SS
Mar 10, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
I have an Emerson Microwave Oven MW8997W and cannot change the hour (time) on my clock. How do I change the clock? Debbie
If your keys do not work at all, you probably have a bad keypad, in which case I'd ask you to reply back. In the meantime:
SETTING THE CLOCK
When the microwave oven is plugged into an outlet,
the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been set,
the time will appear with blinking colon, unless
the oven is cooking or defrosting.
You can actually download your owner's manual here
Mar 10, 2008 | Microwave Ovens
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
