Question about Grundfos Pumps UPS15-58FC
A Grundfos 15-58, as well as an electric boiler
A Grundfos 15-58, as well as an electric boiler (18KW Slantfin Monitron), installed last week, converting my system from oil. Weather still too warm for heat, but pump is switched on nonetheless, is "humming" noticeably (somewhat more than a "purr"), and is warm to the touch (about "4-5" on a scale of 1-to-10). I realize this is a motor, and motors do such things, but, is this normal for this particular unit?
Grundfos pump problems
I've just had a ideal i35 boiler fitted, the grundfos ump3 economic pump has failed / seized and has been replaced 4 times since the boiler was installed 7 months ago.
It has just stopped working again and ideal are refusing to attend.
any advise would be appreciated.
Aug 14, 2014 | Grundfos Pumps Grundfos UP15-29SF 1 12 Hp...
WHY DOES MY BOILER PUMP CONSTANTLY RUN
Hello anon, this sounds like there is a problem on the electric side of your boiler. Depending on the boiler if its a combi type it is one of the pcb's calling for the pump to run. If at all possible call a specialist who deals with Central Heating and dont try and fix it yourself.
Aug 02, 2014 | Grundfos Pumps Grundfos Redi-Flo2 Electric...
Grundfos stopped circulating.
At approximately $238.95 new, it pays to do a bit of troubleshooting.
Below are some sites that may help:
http://www.plumbersurplus.com/Brands/Grundfos/74
http://waterheatertimer.org/Water-heater-recirculation-system.html#Grundfos
There are no repair parts for these pumps, and nobody at Fixya has reported taking Grundfos apart and repairing it.
Jan 21, 2013 | Grundfos Comfort System Recirculator ...
We have a robbens underfloor heating system with a heatrae electric boiler on a floating floor system. The underflooe heating manifold has a grundfos Alpha + pump. What setting should this be at? Currently...
Venting of the system is when you re circulate the water or cooling fluid in higher speed to eliminate the air bubbles from the system.
If water circulate on a too higher rate does not have time to dissipate the heat so your floor is cold.
You need to go to 2 or even 1 depending on the length of the heating coil in the floor. Unfortunately the pump only has 2 speeds (setting 1 and setting 2) so whoever install your system had to calculate the length of the pipe for maximum efficiency. Try on 2 and if not satisfactory go to setting 1. If too hot on setting 1 then you can adjust the heat by reducing the amount of water from the shut-off volume control. It is a hit and miss situation, I know but unfortunately that is the only choice remaining now after the system is installed.
Jan 10, 2010 | Grundfos RCP-96 Recirculation Pump for...
Grundfos Pumps UPS15-58FC Logo
37 people viewed this question
Top Grundfos Pumps Plumbing Experts
Boyet Soriano
Boyet Soriano
Matthew Ward
Level 1 Expert
Gil Shultz
Are you a Grundfos Pumps Plumbing Expert? Answer questions, earn points and help others
