Question about Microsoft Windows Vista Ultimate Edition
I am considering buying a new computer. I have a
I am considering buying a new computer. I have a Canon Pixma 8500 Printer, an Epsom Perfection 1650 Scanner, and an HP Laser Jet 5mp printer. If I buy a computer with Windows Vista on it will these devices work with it? Also, I am confused as to whether to get a Dell or HP computer.
  • 207 Answers
The good news is that your Canon iP8500 printer is Windows Vista compatible. Driver page for them is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=357&modelid=10440
More good news, the Epson Perfection 1650 scanner is also compatible with Windows Vista.
It would also appear that your HP Laser Jet 5mp printer is compatible with Windows Vista:
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=25481&prodNameId=15013&swEnvOID=2093&swLang=8&mode=2&taskId=135&swItem=lj-44462-1
Whether or not to get a Dell or HP is a preference thing. The biggest thing you have to ask yourself is, how much are you wanting to spend on a new system? Both vendors are fairly comparable as far as hardware and support. The biggest thing I should mention is that, ensure that when you buy your system, to tell whomever you are buying it from that you need Windows Vista 32 bit. Not all of your components were compatible with Vista 64 bit.
Best of Luck and hope you have lots of fun with your new system!
Posted on Apr 24, 2009
    New Friend:
  • 113 Answers
Ya, all your devices will work on Windows Vista. To get all your devices to work on Windows Vista, you have to procure Vista Drivers for the same. If you are unable to get the Vista Drivers then you have to install the devices with COMPATIBILITY MODE OF WINDOWS XP. Still you can use them on Vista.
Dell and HP both are the best. Go for anyone.
Do I need a new scanner bulb?
It sounds very much as if the scanner is faulty/failed. The warming-up phase is to ensure that the scanner lamps output is steady, making for consistent scans. Usually this is just a simple timing circuit.
Having once tried to fix a broken flatbed scanner myself, I found that obtaining the correct replacement lamp for it was impossible - I think inkjet printers and scanners are considered "consumable". You may be better off buying a new printer. Alternatively, if it keeps producing good prints, consider buying a separate scanner. HTH
May 27, 2014 | Canon PIXMA MP780 All-In-One InkJet...
Canon pixma MP950 error code 8500
I think you need to reinstall printer driver again, Be sure unistall by REVO then reistall the drivers again.
Download the printer drivers from this link Pixma MP950 Driver download
http://printer-driver-download.us/canon-pixma-mp-950-driver-download/
Feb 12, 2013 | Canon PIXMA Office Equipment & Supplies
Canon Pixma ip3600 message saying printer is not online
This could be a problem with the port. If you have the printer attached to a USB hub, directly connect to the computer. Try connecting to a different USB port and test the current port with a known working device. Consider trying a new USB cable (minor damage could be a factor in signal loss).
I hope this helps.
Feb 04, 2010 | Canon PIXMA iP3600 Photo Printer
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Te.co.ukFile opening error
Did you try uninstalling and re-installing the drivers. Uninstall everything including the canoscan tool bar, Arcsoft photo studio and Omnipage. And re-install.
Hope that helps,
Sai.
Jan 13, 2009 | Epson Perfection 1240U Flatbed Scanner
Canon Pixma 8500 - will not print Cyan
Hi. Missing color printing means the print head is defective and need to be replaced. Print head is expensive, Waste ink full warning can be disabled with a program ( canon software tool ) I advice to get technical support. Or buy a new printer
Feb 24, 2018 | Canon PIXMA Office Equipment & Supplies
Canon Pixma IP 8500
Sounds like the print head is bad or seriously clogged. If you have done repeated print head cleanings with no success, I believe Canon sells the print head if your unit is out of warranty.
Manuals available for download here.
May 19, 2008 | Canon PIXMA iP8500 InkJet Photo Printer
Canon BJC 8500 WASTE INK FULL
How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
Instructions:
Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
1. Turn off the printer.
2. Whilst pressing Resume button also press on POWER.
3. Then Press RESUME button and release POWER.
4. Then Press RESUME button again .
5. Then release all buttons.
6. Led Indicator should be green and stay green.
7. Click RESUME button 4 times if you wish to try again.
Then See Table Below:
Orange - Service test print ONCE - Orange - Service test print.
Green - EEPROM information TWICE - Green - EEPROM information print.
Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
Green - Left margin correction 14 TIMES - Green - Left margin correction.
8. Turn off printer.
9. Restart Printer.
Good Luck!
Tinteiros - Magic Inkjet Flush (Ebay)
Nov 07, 2007 | Canon BJC 8500 InkJet Printer
Microsoft Windows Vista Ultimate Edition Logo
121 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
