Question about Sony Playstation 3 (PS3) Console
Playstation 3 I RECENTYL INSTALLED THE 1.93 UPGRADE DOWNLOAD....MY PS3 ORIGINALLY HAD THE 1.90 ....THINGS WERE WORKING FINE FOR AWHILE, BUT NOW MY PS3 WILL NOT LOG INTO NETWORK. SAYS IT HAS A SERVER PROBLEM. I HAVE FOLLOWED THE INSTRUCTIONS TO RE-DO THE NETWORK SETUP , AS DESCRIBED IN THE MANUAL, BUT IT STILL IS NOT WORKING. ANY SUGGESTIONS? I AM HARD WIRED THROUGH A ETHERNET CABLE..I HAVE DSL THROUGH A MOTOROLA SURFBOARD MODEM....IT WAS WORKING, BUT NOW.....?
START OVER REVERT TO ORIGINL FIRMWARE AND TRY TO CONNECT AGAIN THIS WORKED FOR ME BECAUSE MY FIRST UPDATE WAS DONE WITH A FLASH DRIVE AND NEVER DELETED IT
Posted on Sep 30, 2007
SOURCE:
How do i download adobe flash player 10 for my ps3
You cant.Sony has to roll out a firmware upgrade.If you upgraded to firmeware 3.5 you also can no longer install a third party OS.
Jul 14, 2010 | Sony Playstation 3 (PS3) Console
My playstation 3 wont come on. The red light keeps blinking. It was working fine the I turned it off for awhile, when I came back it wont come on.
1)Turn off your playstation 3. If you think your ps3 has been caught by the heat, then wait at least 20 minutes and put it back on again
2) Check if there's any loose cable.
3) Try to put out your playstation's hard-drive, and put it back in. You might want to repeat this 2-3 times for better results.
If this did not work
Send your playstation 3 back to Sony
May 09, 2010 | Sony Playstation 3 (PS3) Console
Upgrade to ps3 firmware 3.01 and now it won't play games.
The error code is actually one of two things, a) a faulty sector on the internal hard drive, or b) a faulty installation of software/firmware, both iterations actually coincide with eachother. If the hard drive suffers a faulty sector ( a section of damaged space on the drive that data may have been written to that no longer is readable), an installation may still be processed, and even work, but the error can cause some serious side effects, such as option b. If your PS3 has installed an item incorrectly, including firmware, it is in high risk of receiving this error.
Basically, what is occuring is the corruption of game disc recognition and execution. If you will notice, in 90% of all cases, the drive will still play DVD and even Blu Ray movies with no problems. When trying to start a game however, the title, sooner or later, will receive the error.
1) Ensure that your internet connection is stable. If you are using a wireless connection, make sure your signal is at least a solid 80%. If not, make the proper adjustments until it is.
2) Dust your machine regularly. Any PS3 owner will tell you that the Playstation 3 is a dust magnet. Just run a dry cloth over it every couple days, and you should be fine. This will help prevent heat issues and shorts that may occur.
3) When installing firmware and/or software, make sure you follow the instructions. Even if you have installed 6 versions prior, each one is different, and may require additional steps. Save yourself the headache and just follow them, it only takes a minute or so longer to do it right.
Lets sum it all up, the error is not hardware related and is caused due to corruption of firmware. Restoring you PS3 will not roll back the firmware, and unfortunately will not fix the issue 9 times out of 10. If you are receiving this error, contact Sony for a replacement unit.
Sep 20, 2009 | Sony Playstation 3 (PS3) Console
Upgrading PS3 HDD
You can upgrade the hard drive to a bigger one just as long as it's the same physical size as the original one. The 40GB PS3 is technically capable of backwards compatibility. It's just that Sony's OS doesn't support it on that model (maybe, there will be a firmware update that will allow it in the future). If you install Linux on the PS3 (which Sony officially allows you to do), then you can install the PS1 emulator (it's called ePSXe) and the PS2 emulator (it's called PCSX2). Both of them are free to download for Linux. The only thing that won't make the 40GB model the same as the 80GB is the finish of the console, lack of built-in memory card reader, lack of built-in WiFi, and only 2 USB ports. But those aren't neccesary.
Jul 06, 2009 | Sony PlayStation® 3 (80GB) Console
Hd port on back broke need to reset video to use av cables any help???
Press the power on the PS3 for 5 seconds (in standby mode) till it beeps thing to reset the graphics output
May 29, 2009 | Sony Playstation 3 (PS3) Console
An error occurs during ps3 download installation
The only thing you can do is to restore the PS3 to original, then download your upgrade again.
May 25, 2009 | Sony PlayStation® 3 (80GB) Console
I need to update my ps3 but it just says error80710723
You may want to install its orginal HDD back into the PS3 if you upgraded the HDD or download the update on to your PC nad follwing the PC update option.
http://www.us.playstation.com/Support/SystemUpdates/PS3/PC_Update.html
Apr 19, 2009 | Sony PlayStation® 3 (60 GB) Console
Playstation 3, 60Gb will no longer turn on properly
your ps3 is trying to tell you that it it is broken to point it needs looked at call sony at 1800-345-7669 to see if it is under warrenty
Jan 04, 2009 | Sony PlayStation® 3 (60 GB) Console
Call of Duty 5 & Drake will not move past the Start Screen.
TRY TO DOWNLOAD THE NEW UPGRADE!!! I BELIEVE YOU TRY BUT SOMETHING INTURUPTED WITH YOUR SERVER AND IT DIDNT DOWN LOAD RIGHT TRY TO RESET YOUR PS3 OR MAYBE YOU HAVE A CORRUPTED FILE!!!
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Playstation network problem
download straight to comp than transfer over cd-rw
then install the disk in your playstation and run the settings
May 19, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
