Question about Mountain Plumbing AG600S Air Gap for Reverse Osmosis Systems
Problems with reverse osmosis water treatment system
Hi there ! I had a Maruyama reverse osmosis water filtration system installed in Dec 08 . in the first month it used up one bag of salt i replaced this bag of salt but then forgot to keep checking the bin unit where the salt is stored. They guy who installed it said usual consumption about one bag a month, so when i checked on it next i found that the salt in the bin had almost gone completely and bought a bag that very day. This time i bought the recommended salt lumps instead of ordinary salt cristals which i had used the once in the interim. Now there appears to be no change in the amount of salt lumps in the bin even though the salt had been put in over 5 weeks ago, it seems as though there is no proper activity in the unit. I was wondering if the bin is supposed to be full of water all the time or if the water gets pumped into the bin when it self cleans and then pumped out again. In the bin one can also see where the old level of the water was around the rim. At present there is only tiny bit of water in bottom of bin but i do not know whether when it is in the cleaning process this water level rises?? what can i do to find out if the system still funktions correctly, tried ringing the supplier they seem to have gone out of business as no reply to phone calls mess. etc help would be very much appreciated as i kinda worry about the state of the water from our well in Ireland thanks tina
  • mcarolan May 02, 2009
    thanks a million :o) i will check it out :o)
    Problem Solver:
  • 8 Answers
Http://www.ag.ndsu.edu/h2oqual/watsys/ae1047w.htm Treatment systems for household water supplies gives a great description for reverse osmosis systems. I am not familiar with the Maruyama system since I live in the states. After reading the above article you might want to test your water. Your system may be operating properly? To me it soulds like you have a water softner and flushed the salt out, and now you have the proper pellets? If your water is not very hard you shouldn't use too much salt. Building supply stores sell cheap water test kits. Try that, and if your water tests ok, and doesn't smell, and lathers up with soap sounds like everthing is working ok. Hope I helped
Posted on May 02, 2009
Salt taste in water
If you're getting salty water from a reverse osmosis permeate line, that means the ro membrane is ruptured or the membrane o-ring is deformed.
Replace the o-ring and if that does not solve the problem, replace the membrane as well.
Mar 10, 2014 | Fleck Water Dispensing & Filtration
How does a water purifier work?
A water purifier works through the process of reverse osmosis. Water purifiers cleanse water by passing it through a series of filters. This helps remove large amounts of contaminants and other harmful chemicals
Jul 09, 2012 | Camping, Backpacking & Hiking
Water filter drain running all the time
Is this a new system? The should be a small restriction in the drain line. The size of the restriction is matched to the gallon per minutes of the R.O. system. Yours could be missing or not the right size, ie not enough restriction.
Jul 02, 2012 | General Electric GE SmartWater Household...
I want some topic for water problem by population
Some of my favorites are easy ways to conserve water,prevention of backflow and cross connections and public dangers they can present. Also filtration,ozone treatment,reverse osmosis systems,options to water softening without using salt and grond water pollution by private, agricultural,and industry. You can get a wealth of information from EPA, local building dept. local and state health agencies. Hope this helps. Thanks
Nov 11, 2010 | Water Heater Innovations MR85245 High...
I have a GE smartwater reverse osmosis system model number GXRM10GBL02. Water leaks daily from the small hole on the faucet on my counter top. Any idea why water comes out that small hole? Otherwise the...
That is the drain for the reverse osmosis system. You have what is referred to as an AIR GAP faucet. The waste water is pushed up there before it goes to drain just as the drain for a dishwasher does. If water is coming out of the faucet the drain is most likely plugged or the line is kinked causing water to back up and overflow. Check the drain line for kinks and clean out the drain where it attaches to the stand pipe.
RJ
Oct 22, 2010 | General Electric GE SmartWater Household...
I bought a new tank for my reverse osmosis water treatment and it did not come with directions. It's supposed to be ''charged,'' whatever that means. When I hook it up to my system it does not fill with...
Typically a reverse osmosis storage tank should have a precharge of approximately 7 psi. Depending on the make/model of your tank it may have a higher charge currently which would cause the tank to not fill. There should be a schrader valve on the bottom or side of the tank. Using a tire gauge and bicycle pump you should be able to check the current pressure in the tank and adjust it up or down to 7 psi.
reverse osmosis storage tanks: http://www.freshwatersystems.com/c-32-reverse-osmosis-storage-tanks.aspx
Geoff D., CWS-I - WQA Certified Water Specialist
Fresh Water Systems, Inc - http://www.freshwatersystems.com 1.877.335.3339
Nov 04, 2009 | General Electric FX18M GE SmartWater...
Side by side refrigerator
The ice maker is not producing ice or not enough ice
 Refrigerator connected to a water supply and the supply
shutoff valve turned on?
Connect refrigerator to water
supply and turn water shutoff valve fully open.
 Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
 Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
 New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
 Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
 Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
 Reverse osmosis water filtration system connected to
your cold water supply?
This can decrease water pressure
OR
The water dispenser will not operate properly
 Freezer door closed completely? Close the door firmly. If it
does not close completely, see “The doors will not close
completely.”
 Is the water pressure at least 30 psi? The water pressure to
the home determines the flow from the dispenser. See “Water
Supply Requirements.”
 Kink in the home water source line? Straighten the water
source line.
 New installation? Flush and fill the water system.
 Water filter installed on the refrigerator? The filter may be
clogged or incorrectly installed.
 Is a reverse osmosis water filtration system connected to
GOOD LUCK TO YOU!!! LET ME KNOW IF THIS SOLVED YOUR PROBLEM
Jan 31, 2008 | Whirlpool ED2FHEXN Side by Side...
Mountain Plumbing AG600S Air Gap for Reverse Osmosis Systems Logo
385 people viewed this question
Top Mountain Plumbing Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Mountain Plumbing Plumbing Expert? Answer questions, earn points and help others
