Question about Briggs & Stratton Garden
Must use full choke position to keep it running.
Sometime (not always but, more times than not) when I start my Murray, I can only keep it running when I have it fully choked even after it has warmed up. I have sprayed cleaner into the carburator to clean out any dirt deposit with no change in problem.
What else can I try or do to fix this problem. Thank You. Don
  • 68 Answers
I would say the carb. needs to be taken apart and the little ports blown out with air.
Also ,check the tank for dirt.
Posted on Apr 26, 2009
My murray weedeater want run off choke why?
Carburetor needs to be rebuilt. I won't even think twice about. the diaphram is on it's way out.
Aug 29, 2017 | Weedeater Garden
Just starting to use this spring, and having fuel starvation issues. I ran it this winter a couple times and it ran properly.
add a little carb cleaner to the gas and try letting it run on half choke for a while longer .
Mar 28, 2015 | Garden
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
Where is the choke on the Murray 875 rear rider?
Most of these models have a automatic choke, located on the carburetor. Some are coil springs and others are electronic. There is no manual adjustment on these. Some older models had it included as part of the throttle control. My guess is yours is automatic and is part of the carburetor system.
They are common item to go bad.
Aug 24, 2014 | Garden
Turns over but dose not start, spark plug sparking ok
Check you have petrol if the bike has not been run for sometime replace the fuel. Petrol ages and causes all manner of problems.
Are you trying to start the bike but it has gone onto reserve, move the fuel tap to the reserve position then try to start it. If the above fails, then try these:-
Is the spark plug wet when removed. If dry it sounds like the petrol is not getting through. Try opening the filler cap and leave it open, make sure the kill switch is in the run position. Try starting with the throttle full open. Does the bike have a manual choke try to start with the throttle shut, choke off, then full on, then while continuing to turn over move the choke lever in stages from fully on to fully off. I find on my Yam TW125 (winter and bad weather hack) that if I have not used it for a while sharp twist the throttle a couple of times no more than a third of a turn. Hope this helps.
Apr 08, 2014 | 2009 Daelim Roadwin R 125 FI
Cannot get the brushcutter started, it has spark but doesn't want to go. Have forgotten the method of starting, eg. 10 prime pumps, five pulls with full choke but turned off, then half choke turn on...
Normal starting practice is always done with the ignition on, primer as many times as it takes to 3/4 fill the bulb, move choke to full closed, crank engine until it fires once, move choke to half if there is a half position, crank engine until it starts and runs, move choke to full off.
Aug 24, 2011 | Garden
I have a murray push mower 6-22271 briggs straton 4 hp. it start and then stalls . filter clean. choke fully closed when control is in full forwrd run/choke position. I pour gas in the throat and pull...
Your carburetor needs cleaned. It is dirty/has debris in it. If it has a bowl that is. If it has a diaphram (carburetor mounted on the fuel tank), replace the diaphram. They go bad.
I hope this helps get you going.
Jul 28, 2011 | Garden
Stops when given full throttle
Most likely carburetor needs adjustment.
May 15, 2009 | Garden
Cannot keep tiller running
Could a gas/oil mix been used by mistake. When you cleaned carb did you also clean dusty air filter?? Try leaveing off filter first and run. Are you sure you are in "choke position" when engines seems to be running ok,be sure to double check yourself here. If engine runs ecelleant in "choke" sounds like your in "Run" position and positioning is problem not performance.
Please rate. Thanks jj505
Mar 28, 2009 | Garden
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
Garden Logo
318 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
