Question about Weiser Lock Locks & Locksmithing
Weiser deadbolt key won't turn - Weiser Lock Locks & Locksmithing
  • 5344 Answers
SOURCE: PIN NUMBER
Take off the cover on the inside door of the lock. Grip it on the sides and pull up or twist. Press the Program button (on the left of the power board) once. Then type in desired code (4-8 digits) on the Touchpad followed by pressing the Lock button. If you hear a 2-second beep, the code is properly stored. If you don't hear the beep, the encoding period timed out. Then you need to repeat the sequence from pressing the Program button but do it faster. To store a second code, press the Program button twice and then type in the desired code followed by the Lock button. (Any earlier code will be lost during these steps.) Then replace the cover over the power board.
If you want to print out the programming information, go here: http://www.weiserlock.com/en/products/smartseries/powerbolt.aspx and scroll down to the Installation instructions. The programming instructions are at Step 5 on the PDF.
I hope this helps.
Posted on Jul 23, 2010
  • 15 Answers
SOURCE: Weiser keypad deadbolt lock deadbolt does not move
Hi... You have too be sure that the deadbolt is free when it go inside the deadbolt hole... however this system is very low power and the (over torque clutch) will sleep if the deadbolt it's not completely free.
Also if you try to open the door before you unlock it, you may block the the deadbolt inside the deadbolt hole. Take care too unlock the door before open-it...
Posted on May 14, 2011
  • 963 Answers
SOURCE: I have a weiser combination
Weiser has a lifetime warranty against mechanical and finish problems with their locks. Contact them from this link:
http://www.weiserlock.com/en/Products/SmartSeries/Powerbolt.aspx
Posted on Nov 06, 2011
  • 963 Answers
SOURCE: deadbolt barely moves in weiser lock
I assume that you get the same results whether you operate the lock with the door open or the door closed. That is, that you've already ruled out a bind between the closed door and the door jamb.
I'd recommend changing the battery first of all. At this time of year, cold weather can have a negative effect on your battery power.
If you've already changed the battery and are still having the problem, you should pursue having the lock covered under warranty. Weiser has a lifetime warranty covering the mechanical operation (and finish) of their locks. Before they cover it under warranty, they are going to ask you the same questions about battery and binding that I've already mentioned.
To change the battery for your lock, go to this web page:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Or, alternately, this page for the Kwikset version, which is identical, if you have trouble loading the first page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Faq/50160000000HhhEAAS.aspx
Notice that the above are of the " .PDF" file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Finally, the warranty information link:
http://www.weiserlock.com/CustomerService/WarrantyInfo/Powerbolt.aspx
Review it, and then follow the "Support Contact" link on that page. It's always best to contact them by phone and seek their assistance.
Good luck--and please provide feedback if this helps!
Posted on Dec 09, 2011
  • 963 Answers
SOURCE: Weiser Power deadbolt works backwards on keypad
I have installed your Powerbolt, but when I push the Lock Button, it unlocks? What should I do?
First remove the cover on the inside of the Powerbolt unit. On the right hand side under the batteries, you will notice that is says "Door Direction Jumper". If the cap is mounted on Prongs 1 & 2, carefully remove it and move it over so that it mounts Prongs 2 & 3. A is right handed, B is left handed.
http://www.weiserlock.com/Support/Faq/50160000000HhmZAAS.aspx
Posted on Aug 19, 2012
Lost my keytried to pick but failed don't remember how bump key works can you help?
If you have a standard lock,tap the bump key in the last bit while turning the bump key with a slight pressure and it should unlock as fast as your regular key,if you have
experience with the pressure and speed needed.
Apr 28, 2017 | Cars & Trucks
I forgot the code and I lost the key
The Weiser brand and Kwikset brand Powerbolt are identical, so these instructions will work just fine for you:
Aug 03, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
I have a weiser combination lock and it seems to be bogging when keying the comb. in so i recharged my batteries and installed back into the lock and it still bogs. Is there one batterie better than...
Jun 28, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
We locked our deadbolt lock this morning. When we returned home, we entered the key in the hole, but it was unable to turn, and we were locked outside. Why did this happen? How do we get the key to turn...
I don't have a direct answer, but I can steer you to the Customer Service web page for Weiser locks:
http://www.weiserlock.com/en/CustomerService/ProductSupport/SupportContact.aspx
There you will find the toll-free number for their Customer Service (Call Us
Toll Free: 800-677-LOCK (Mon-Sat, 7:30am - 4:00pm PST)
as well as FAX and mailing information. Good luck!
Mar 07, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser powerbolt worked well for several months but now is not reliable anymore. Changing batteries did not help. It sounds like it is locking but sometimes fails to lock...we cannot trust it anymore
Good lock or good unlock
Feb 05, 2011 | Weiser Lock ED1460X3VKD Powerbolt 1000...
When i try to lock or open with key pad it will make the sound like its closing but the bolt does not move. can only lock and open with key.
The deadbolt may very free inside the deadbolt hole... This system is low torque and a over torque clutch may slip if the dead bolt it's not completely free inside the deadbolt hole... Also, if you try to open the door before to unlock it, you may block the deadbolt... take care to unlock the door before open it. to be sure that the dead lock is ok, you can turn the manual knob and be sure is turning very very easily.
Also are you no that POWERBOLT is a 3 codes memory? go to that link to see more info about that : http://www.fixya.com/support/t8006865-not_overwrite_old_codes_just_keeps
Have a good lock
Have a good unlock
Jan 30, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
Weiser keypad deadbolt lock deadbolt does not move when motor runs
Dec 30, 2010 | Weiser Lock POWERBOLT ELEC DEADBOLT
I have a weiser lock powerbolt 1000 and i just installed it and progammed it except the bolt wont lock unless the keys are in the door, if i type in the code with the keys in it works fine but when i...
Have a good lock
Have a good unlock
Sep 11, 2010 | Weiser Lock Powerbolt 1000 Lock
Locks & Locksmithing Logo
102 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
