Question about HP PSC 1350 All-In-One Thermal Printer
Check ink level on a 1350 printer with windows 7
alkhaled
  • 12 Answers
SOURCE: Ink Level
Perform the following steps to check the estimated ink levels:
  1. Open the Printer Toolbox . There are two ways to do this:
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.I hope this Solve your issueKhaled
Posted on Oct 21, 2008
SOURCE: hp psc 1410v ink levels
i want a solution to my hp printer for window vista
Posted on Dec 12, 2008
SOURCE: HP 5610 officejet all in one: how do i check my ink levels?
Windows users: Turn on printer.....
In the HP Solution Center, click Settings, point to
Print Settings, and then click Printer Toolbox. Click the Estimated
Ink Levels tab.
Mac users:
In the HP Image Zone, click the Devices tab. In the Select Devices area, click the icon for your HP All-in-one. In the Device Options
area, click Settings, and then choose Maintain Printer. If prompted, select your HP All-in-one, and then click Utilities.
Hope this works for you....Eye
Posted on Feb 28, 2009
ctau
  • 372 Answers
SOURCE: how to check ink level on hp officejet 6210 all-in-one printer
  • Open the Printer Toolbox . There are two ways to do this:
  • The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink.
  • Posted on Mar 22, 2009
    MNfisherman
    • 11896 Answers
    SOURCE: How to check ink level for a hp 1210 printer /vista
    1. Check the back of your computer to make sure that the printer is appropriately connected to the computer and is plugged in. If the printer is not plugged into the computer, find the printer jack on the back of the computer and plug it in before you move on to the next step.
    2. Step 2 Click on the "Start" menu button which is located on bottom left hand corner of your screen. Click on the "Settings" bar and notice that a list of functions pop up to the left of the settings button. Click on the control panel icon.
    3. Step 3 Look for the printer/fax icon in the control panel window. Double click on the printer icon.
    4. Step 4 Find the icon for your printer in the opened window and right click on the icon. Now click on the "Preferences" option.
    5. Step 5 Look for the menu box pop up with tabs near the top of the box. Click on the "Services" tab.
    6. Step 6 Click on "Service this device." You will find the button on the Services menu that you just activated.
    7. Step 7 Click on the estimated ink level tab and a graphic will appear indicating how much ink is left in the cartridge.
    Posted on Aug 07, 2009
    How do I check the ink levels on my HP Photosmart 7350 inkjet printer under Windows 7?
    Do you have the alternate software installed so you can use this on windows 7? I assume you do. If that is the case go to installed devices, i.e. printers and right click the printer icon, see if the ink level shows up in the tools menu..
    Jun 06, 2016 | HP PhotoSmart 7350 InkJet Printer
    Why can't I find the ink level of my HP 7960 printer the way I did with Windows XP?
    The ink levels are a feature of the HP software. What probably happened is that when you had WIN XP you loaded the entire software package which included the ink level utility and with WIN 7 you may have only loaded the basic drivers which does not provide this capability. Check the HP support site for a full software package and see if that brings it back.
    Sep 18, 2014 | HP new photosmart 7960 inkjet printer...
    Can no longer check my ink level.
    Sometimes Windows 7 drivers need to be downloaded from the HP support site. Also, make sure you have installed the application on the CD that came with the printer in addition to the printer drivers. That is what you would have run under Programs before. If your Windows 7 computer was not used to manage the printer before, you will need to install the HP management tool on it in order to see ink levels.
    Mar 20, 2014 | HP DeskJet 3930 InkJet Printer
    Cant find hp psc 1350 on list of hp printers
    HP "series" numbering can be somewhat confusing, but Windows 7 does have the correct driver for your printer.
    For the HP PSC 1350, you will need to use the 1300 series driver.
    The 1310 series driver is for models numbered 131x (e.g., 1315, 1318).
    Jan 25, 2013 | HP PSC 1350 All-In-One Thermal Printer
    I want to check ink levels on an HP deskjet 5650 with Windows 7
    Google HP 5650 windows 7 driver go to HP website and download ututlity tools
    Dec 07, 2012 | HP DeskJet 5650 InkJet Printer
    Cannot connect 1350 printer with windows 7
    The printer PSC 1350 is not compatible with Windows 7.
    We can directly plug and play it to use the Printing Part.
    And in order to scan, only way to do is through Windows Application.
    There are different softwares and ways to scan, use as per your choice.
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01884960&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
    May 20, 2010 | HP PSC 1350 All-In-One Thermal Printer
    Ink levels
    On Windows XP I could see the ink levels however now on Windows 7 there is no way to see ink levels or to clean the print heads. I have to use my iMac to see ink levels and clean the print heads.
    Sep 17, 2009 | HP Deskjet 6940 InkJet Printer
    To estimate ink level I click on HP Director as instructed in manual and it takes me nowhere. Would appreciate help
    its very simple just open thecover of your printer it even shows the ink levels. and tick the box to display ink levels every time
    Jul 10, 2009 | HP PSC 1350 All-In-One Thermal Printer
    HP PSC 1350 All-In-One Thermal Printer Logo
    109 people viewed this question
    Seeker5211
    Seeker5211
