Question about Honda Electrical Supplies
My honda eu6500is wont stay running - Honda Electrical Supplies
My honda generator eu6500is is flooding out.
Alfred,
Try checking the float 1st. Much like it is done in this video (different generator but same princible.):
Dec 19, 2016 | Honda Electrical Supplies
What controlls the rpm on a eu6500is
The inverter signals the throttle motor, which is really just a small servo motor on the top of the carb. When the inverter senses more load, it increases the throttle to compensate.
Jul 10, 2015 | Honda EU6500iS Inverter Generator
Service manual required
I can't find a free download on the internet, most are Owner's manuals or are not for the exact model you want - I don't know how similar similar models are. You might try the following:
http://cdn.powerequipment.honda.com/pe/pdf/manuals/00X31Z376011.pdf (from Honda, EU7000is owner's)
Honda EU7000i Model Info Super Quiet 7000 Watt Inverter Generator Honda...
This is the shop manual for the EU6500is model ($44)
Honda EU6500is Generator Shop Manual
owner's for the EU6500is
http://www.freeproductmanual.com/honda-eu6500is-manual
Finally a link to the search results most of the were taken from
https://uk.search.yahoo.com/search;_ylt=A9mSs2tVBShVngQA_xZLBQx.;_ylc=X1MDMjExNDcxNzAwMwRfcgMyBGZyA2FsdGF2aXN0YQRncHJpZANyOTBfV1hQeVNvT0twcW5oS3NxWlFBBG5fcnNsdAMwBG5fc3VnZwM0BG9yaWdpbgN1ay5zZWFyY2gueWFob28uY29tBHBvcwMwBHBxc3RyAwRwcXN0cmwDBHFzdHJsAzMwBHF1ZXJ5A0hvbmRhIEVVNjUwMGlzQSBzZXJ2aWNlIG1hbnVhbAR0X3N0bXADMTQyODY4NjQ3NQ--?p=Honda+EU6500isA+service+manual&fr2=sb-top-uk.search&fr=altavista
You could try contacting Honda (relevant division) also; if they will provide the manual you want, it might be free
10.April.2015
Apr 10, 2015 | Honda EU6500isA - 5500 Watt Electric Start...
Tune up Honda can some one pick up at home and take to shop the bring back ?
Most common problem with under underutilised genset is stale fuel. At best drain all the fuel and refill at worst the fuel system will need flushing.
Kevin H
Aug 21, 2014 | Honda EU6500iS Inverter Generator
Where can I buy a hard copy owners manual Honda generator eu6500is?
The manufacturer would be an excellent place to start... and they have superb paper manuals.
Jul 31, 2014 | Honda EU6500iS Inverter Generator
Honda es6500 won't start has fire,compression , gas, not voltage at carb, oil light on then goes out when cranking
If you run 12volts to the carb, will it run? I assume since it has no power at carb as you stated, that it has a fuel shut off at carb and will need voltage to activate magnet.
Apr 03, 2014 | Honda EU6500iS Inverter Generator
E04 error code
Honda eu65 complaint overload indicator light on and engine shutoff
Aug 12, 2012 | Honda EU6500iS Inverter Generator
What e 21 fault code mean on a Honda generator eu6500is
I have a brand new Honda EU6500 flashing starts but then quits and gives error code E-21. Turns out the rubber batter hold down was undone and blocks air intake so engine quits. Put strap back in place and now runs fine.
Jan 24, 2012 | Honda Electrical Supplies
Electrical Supplies Logo
91 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Roland W VanLue
Roland W VanLue
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
