Question about Photography
Crank assembly for Vivitar V3000
I need to find a replacement crank assembly for my V3000, Can you help please. Regards. Stu I have a broken hand crank on my vivitar VPT 120 tripod. Where can I get a replacement crank.
2 Suggested Answers
Door Tech
  • 98 Answers
SOURCE: Crank assembly for Vivitar V3000
I have a Crank assembly for Vivitar V3000
Posted on Oct 02, 2009
Replace the timing belt and the car will not crank
Always crank motor over by hand with a ratchet or breaker bar before attempting to start with key. You can very well ruin or lock up your motor if the timing is incorrect before you try to start with key. If its locked up, unhook battery. Place ratchet and socket on crank pully. rotate in reverse and then try to rotate forward. If there is anything holding the motor from turning by hand, pull timing belt and make sure everything is aligned correctly and try to crank by hand again 2 or 3 revolutions. If tight or locked, then motor needs inspected for bent, jammed valves, broken pistons.
Aug 30, 2012 | 1996 Dodge Intrepid
The pedals on my Nordic Track SL700 turn completely free. I think I need to replace the crank assembly but cannot seem to get into it. Is this bike worth the price of a new crank assembly part?
Dear Sir:
Please do the following:
Use aflat screwdriver to unseat the tabs that hold the front top cover in place.This will expose the flywheel and pedal arm connection points. Rotate theflywheel by hand and determine whether lubrication will accomplish the repairs.If the bearings are exposed, use a grease gun with an extension nozzle and lubricateboth bearings with lithium grease. If the bearings are damaged or sealed,proceed to the next step.2
Removethe front and side covers on the main frame. Hold the flywheel with one handand use a box wrench to loosen the bolts that secure the pedal arms at eachside of the flywheel. Pull the arms away from the flywheel and remove thebearings from each side.3
Test thebearings as before. Lubricate exposed bearings with lithium grease andreinstall them. Sealed bearings must be replaced. Reattach the pedal arms tothe flywheel. Replace the main frame covers and front top cover to complete therepairs.sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 09, 2012 | Exercise & Fitness
Broken elevator column crank handle
Please state the make and model. But if it is any Vivitar model then like all budget tripods spares simply aren't available.
You either make a claim under the manufacturer's one year warranty or you chuck away your tripod and buy either another budget model or invest in a quality brand which does have spares support.
The only other option is to see if a friend or relative has an engineering workshop and can fabricate spare parts for you from scratch. It's likely to be a straightforward job, but not one which is worth paying for.
Mar 07, 2010 | Vivitar Photography
2003 chevy surb... can not release my spare tire...cable is broken ,,,nothing to pull on help !
If when you turn the crank nothing happens to drop the tire. Look up inside and see if the cable is loose (most likely not) if not the assembly is broken, you will have to cut the plate that holds tire up and replace the spare tire cable and crank assembly.
Oct 08, 2009 | 2003 Chevrolet Suburban 1500
Rockwood pop-up camper.when i try to use hand crank to put it up or down only the back seems to go up not the front
Hello.
You either have a broken cable, or it may have come loose. Gain access to your anchor points and check the cables. Replacement cable can be purchased "by the foot" al Lowe's/similar as well as cable nuts and such Check the axels and spools powered by the hand crank for anything out of whack, like a broken weld on a cable drum, etc.
Best regards, W/D
Aug 17, 2009 | Coleman Campers Grill
Need a diagram for 94 3l diesel hilux timing belt replacment pls.
Hello Paul
I hope this help you
6a737ed.jpg Regards Paul
www.limotec.co.uk
If you need more please contact me
Jan 13, 2009 | 1994 Toyota 4Runner
My wifes car seems to get stuck once you put it in gear. she has a ford fiesta P reg. the only way to get it out off gear is to stall it or switch off the engine, once this has happened you need to get...
Hi Stu!
The problems lies with clutch operation, Not having much to do with Fiesta's but sorting similar problems classic Ford vehicles.
I take it the clutch is operated Via a cable? on recent Fords they use a plastic Ratchet and Pawl system which automatically adjusts when cable stretches.
This may have reached its maximum so a replacement is required, also would be adviseable to change the cable too.
Have you a decent spares stockist's local? Halfords can help but you'll need to take out a Mortgage for their parts.
So Shopping list, 1. Auto adjuster (Ratchet/Pawl) 2. Clutch Cable, 3 Lube for cable and shaft on pedal assembly and 4 Haynes Manual.
Good Luck Stu!
You can do this I know you can.
Paul 'W'
Onyer~EDson(:0)~[><
Jan 13, 2009 | 1999 Ford Escort
Try Wal-Mart, Target, Circut City, or Sam's Club. I'm sure they have it.
Mar 22, 2008 | Vivitar V-2200GX Tripod
Vivitar V3000 Tripod
I did not have any luck in locating the leg locking assembly for my Vivitar V3000. Instead, I plastic welded both that were broken on mine. So far, so good!
Dec 14, 2007 | Vivitar V-2200GX Tripod
Photography Logo
177 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
