Question about LG WM2432CW Front Load Washing Machine
Washing machine run for few sec. n stop
Washing
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$$%
Posted on Oct 01, 2010
F24
does the drum just move back and forwards or does it turn complete turn if it dont do complete turn it might be that the belt is slipping and needs replacing this is cheap and easy to do post back if you need more help but i had a machine with same prob but mine was different make and model but after replacing the belt it solved prob and is still working to this day sorry if this is not much help .........................................................
Nov 13, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune TL starts, fills with water a few sec then clicks loudly a few times and then stops, a few sec later it repeats this, then stops for good. Tried unplugging and restarting, but same thing...
Any error codes?
Do you want to troubleshoot? If so here is the Service Manual.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
I would start by removing the front cover of the machine follow all safety warnings in the Service Manual.
Follow the first few steps in my Clutch Fix post to remove the front cover.
Then let me know if during the water fill cycle the machine rotates the wash basket CCW in a slow spin during the water fill cycle before the machine stops and we will go from there. Give me all the detail you see with the front cover off I need to know if the wash basket is rotating CCW during the washer fill cycle.
You can lift the washer top up a slight amount to observe the slow CCW spin of the wash basket. I’m checking that the outer tub bearings are not seized……Rich
To pump out the excess tub water with this process;
Enter Service Mode by simultaneously pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on. Stop with off button or hit the Presoak key.
This process is documented in the Service Manual. I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode to pump out the tub.
Jun 26, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer starts for a few secs then stops like it is waiting for wa
Trust water supply ok ...does it run on pump out only?...Check caps connections are correcct
Apr 08, 2010 | Washing Machines
After about 10 mins error code H2O is displayed.
the h2o message means the machine isn't getting enough water. check pressure and water intake pipe.
Mar 15, 2009 | Washing Machines
When i start wash. machi. pump starts and few sec.later led flash
Check the water supplies at the back, if the valve is opening, and the water is getting into the machine, it can be a faulty water level switch, or membrane sensor, depending on the model.
A faulty or clogged inlet valve can also close few seconds from opening the valve, usually becausu of a faulty solenoid.
If valve and water level switch are ok, then this is a faulty control.
Have valve and water level switch checked first.
Dec 10, 2008 | Whirlpool AWM6120 Front Load Washer
Very annoying beep when finished programme
When the machine is on, but not running, press and hold the "pre-wash" button. After a few seconds it will begin that beep noise, keep holding it in until the beep volume goes down and finally stops completely (5-10 secs). Once the beep has stopped, release the button and voila, no more annoying beeps at the end of your cycle.
To restore the end of cycle notification (beep) do the same thing as described above, but release the button earlier while the beep is still going.
Nov 23, 2008 | Bosch Classixx WFL 2066 Front Load Washer
F & P washing machine GW709AU not competing rinse cycle and then beeps and flashes light.
My Whirlpool washing machine is not stopping after completion of wash cycle instead it is repeating the cycle again. It is not consistent, but out of 3 washes 1 wash is happening that way...we are manually stopping machine by gaurding carefully when timer shows nearer to completion.
Sep 15, 2008 | Washing Machines
Smart drive Pride 5.5
can you empty the machine completly of water, and start again.you could try unpluging it for 2 mins it might reset it self best of luck!!!,close,eire
Dec 15, 2007 | Fisher Paykel EcoSmart GWL15
LG WM2432CW Front Load Washing Machine Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
