Question about Bodum Bistro Electric Burr Coffee Grinder White
Same problem still not solved. Machine whines, but won't grind. Anyone know how to fix this?
Grind time is short, puck is wet and sloppy, espresso weak
Sounds like you might have more than one problem.
From page 12 of the manual... NOTE THE LAST LINE.
"8. ADJUSTING THE GRINDER
• Open the lid of the bean container.
• While the grinder is running turn the grind selector switch to
the desired position (Fig. 6).
-The smaller the dots, the finer the grind.
-The bigger the dots, the coarser the grind.
Important:
The grinding grade can only be adjusted while
the grinder is actually grinding."
Sep 08, 2014 | Jura Capresso Impressa E8 Espresso/Coffee...
1998 Mazda 626 clutch whining/grinding won't shift gears
Need to replace clutch kit will repair clutch problem and throw out bearing
Feb 11, 2014 | 1997 Mazda 626
My washing machine keeps displaying error code F17 and won't go on. Does anyone know what this means and what I can do to fix it?
F17 indicates no water coming into the condensing chamber during drying.
Unplug the appliance.
Take the top off.
Check to see if the condensing chamber below the heating chamber is blocked.
Oct 15, 2012 | Siemens Washing Machines
Model LT2000 hydrostatic drive wont move in either direction drive belt started smoking than quit now tractor wont move in either direction
If the main drive belt, from the engine to the rear end of the tractor broke, you won't move, nor will you hear a whining or grinding noise!
An easy check- inspect if each rear wheel has a key installed between it and the axle shaft. One pops out- it won't drive.The key is a square piece of hardened steel that is inserted into the axle, then the wheel hub is slipped over it and the axle, then the necessary fastener is installed to keep the wheel on. This could be either a bolt, or a spring clip. And, if the transmission has failed, you may or may not hear any whining or grinding noises!
My guess it the drive belt is toast as you said it was smoking, look at it and the order a new one. Here is a site you may be able to download a manual, Tim:
http://www.searspartsdirect.com
May 23, 2011 | Garden
2002 Mitsubishi Montero Sport XLS transfer case issue.
The best place for a DIY manual is www.ALLDATADIY.com their info is very accurate.
Jan 29, 2009 | 2001 Mitsubishi Montero Sport 4WD
The machine won't start up
in the self test does it flush the unit ? If not you have to prime the unit by allowing it to pump hot water through the frothing valve. Open the valve and the pump should pulse water out. After this the machine should indicate it is in the operating mode for coffee
Jun 20, 2007 | Saeco Royal Professional Espresso Machine
Bodum Bistro Electric Burr Coffee Grinder White Logo
Top Bodum Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
ray gallant
Kolbrun...
Are you a Bodum Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
