Question about Zyxel Prestige 320W Wireless Firewall Router
I bought a zyxel in set it up to my desk top and it is working. when i try my lap top it is saying the (zyxel) is a security enabled network. but i did not set it up with a password so what can i do to get password or override it to change it.
    Scholar:
  • 154 Answers
Goto control panel of the router and disable the security key... put it on open.
Posted on Apr 24, 2009
My desk top will work with the router but the lap top which is wireless will not connect. the message I get is failure to establish a successful connection which my be due to poor signal strength or an...
You will need to check the wireless settings of the router.
If your network is secured then make sure that you are typing the correct network key.
also make sure that the DHCP server is enabled on the router.
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Nov 07, 2010 | Linksys Wireless-G WRT54G Router
No Internet via zoom X6 wireless router to desk top, lap top ok.
Access your zoom router by using the laptop which still has access to the router.
Your going to have to open your Wireless Network Connection Status window located under your network settings.
If you see this window your going to left click the (details) button
Now you should see a IP DNS server address
for example: 192.168.1.xxx
Type that address onto the address bar of your web browser.
it should take you to your router setup page.
There you will need to check if the lan port is enabled
Feb 04, 2010 | Zoom X6 Adsl Modem/router Rohs...
Just bought a new lap top have a wireless router on my PC but want to connect to the internet on my new lap top which is wireless enabled, it has picked up the router which is still named as default but...
From your PC (not your laptop):
Click START
Click RUN
Type CMD and press ENTER
Type IPCONFIG and press ENTER
Find the line stating "gateway 192.168.xxx.yyy"
Start Internet Explorer
Type http://192.168.xxx.yyy
Login to your router
Click the "wireless configuration" button
Set a new security-key or passphrase.
Now, try connecting wirelessly from your laptop, using the new security-key or passphrase.
Sep 19, 2009 | Computers & Internet
Have 2 lap tops,1 desk top. Desk top and 1 lap
For the 2nd laptop, first upgrade the LAN card driver, then reinstall the driver if the problem is not resolved with the driver upgrade.
Hope this helps.
Aug 29, 2009 | D-Link 802.11g Wireless Router WBR-1310...
HELP!!!!!! Trying to enable wpa-psk security on my laptop?
You should set the security on your computer wifi card to wpa-psk and then type in the securitycode which is written in your Zyxel Router.
If this is not possible with your networkcard, change to wpa or wpa2 inside the Zyxel. And do the same procedure with your networkcard, when detected the Router.
May 04, 2009 | Zyxel P660HW-D1 Router
Connecting my new laptop to the internet
There is a wirless icon in the botom right corner of the screen right click it and say view all wirless networks. lock for the one you own say conect it might ask for a WEP password which is located on the botom of the router that is if you did not change it from the defult.
Jan 03, 2009 | Zyxel Prestige P-330W Wireless Router...
Lap top can go online, but won't let me go online.
please check the wireless settings for your laptop.
using your laptop,
first, go to command prompt and type services.msc
second, check WLAN if it was set to automatic. if not click stop and double click WLAN and set it to automatic before clicking start.
using desktop pc that is connected to the router
first, access the modem software of your d-link router
second, goto wirelesss settings
third, set channel to maximum level
fourth, apply settings
Oct 03, 2008 | D-Link 802.11g Wireless Router WBR-1310...
Wireless router
Do you see a little monitor Icon in the lower left bottom. If so go ahead and right click on it and select wireless connections , If not open network connections, now you should see detect wireless networks, Click on that,( IF SO ) Now you should get a window that shows your wireless connections, Select the network you have by clicking on it, and then in the lower left of the window Opened you should see a connect button, select that, you should be able to go online now if not let me know, there are some other things we can try to get you up and running just write back here if it does not work and as soon as I get this I will get back to you. I am sure its nothing we can't solve. Ok thanks bear001
Dec 23, 2007 | Linksys Wireless-G WRT54G Router
P-334wt
Suggestion,
First, go to ur Router Configuration Page. There are 2 pg into related WireLess Configuration Settings. So u find ur problem into the WPA security configuration is under the wlan Security section, and then you select WPA PSK (Pre Shared Key) and TKIP encryption for Lan security. As well as changing the WPA Mode to enabled, u will need to enter a WPA Pre-Shared Key. So u found, which is a Network key and why to need.
mr-winthaw@myanmar.com.mm
Raider.CsStriker@gmail.com
Oct 22, 2007 | Zyxel P-334WT (P334WT) Firewall
Zyxel Prestige 320W Wireless Firewall Router  Logo
195 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
