Question about Ovens
I own a Stoves rotostar 750 grf and have a broken left hinge support need to replace it. Is it available to receive ?
4 Suggested Answers
  • 89 Answers
SOURCE: STOVES 600 oven door wont shut properly
open the door about 30 degrees, lift straight up to release the hinges, this will allow you to remove the door.
you will be able to assess the hinges from there.
most likely the hinges are just out of alignment
Posted on May 26, 2009
  • 250 Answers
SOURCE: I have a Stoves 720
Try espares. If the part is not listed, there is a contact on the website to obtain a quote for a part. Of course once you have the part number you can try elsewhere.
Posted on Nov 18, 2010
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
Posted on Jan 02, 2012
Stoves Q720 GRF DO main oven ignitor clicks / sparks continuously
Might be the PC board, or it might just be the switch behind the oven knob - try disconnecting the wire leading to that switch and see if the clicking stops. If it does, the switch is bad. If not, suspect the electronics.
Aug 23, 2014 | Ovens
Hello, i have a stoves q720 grf do double oven and the problem is with the lower oven, after about 20 minutes the oven switches itself off and the lights on the front of the oven flash on and off. van...
I have the same problem. After anywhere from 5 to 30 minutes the oven(s) switch off and the light and clock start flashing - I have to switch the cooker on and off to start using the oven again.
Any resolution please?
Oct 07, 2010 | Stoves 720EF Electric Double Oven
The hinge on the main oven door of my heritage 900ef needs replacing. Where can i buy one from please
Well, you can try STOVES and see what they will charge, and/or try espares. Once you have the part number, google that to see if anyone else can supply.
You may want to think about replacing both hinges and the springs at the same time, to ensure the door works/closes properly. Also, check the rubber seal round the door, then tend to become brittle when at the end of their service life, so it may pay to include that with the order as well.
Apr 12, 2010 | Stoves 720EF Electric Double Oven
The right hand side of the main oven has broken
You have not given much information to go on, but I am assuming that you mean the door hinge has broken.
If it is a drop down door, then you will have to replace the hinges as a pair.
If it is not the door that is the prob, then I need more information.
Thanks
Please rate my comments.
Nov 22, 2009 | Stoves 720EF Electric Double Oven
Dhow do i remove stoves efa600H oven door hinges?
Nov 20, 2009 | Stoves Premier 600EMa Electric Single Oven
May 26, 2009 | Ovens
How does the q900 works
I do not know either but I would be tempted to turn off the gas, but keep the electric to the oven, and use a plastic Knitting needle to find out. It should show on a display somewhere.
Feb 11, 2009 | Stoves Premier 720GRa Gas Double Oven
Main oven door does not shut properly
i removed the side panels which exposed the hinge mechanism. I have then removed the whole door and the associated hinges by simply unclipping the retaining springs.
Dismantling has revealed that the pivot pins have become dislodged from their housing, and this is why the door was not shutting properly. I am now spot welding the pins back into position.
Also noted is wear in the slots in which the pins rotate but am hoping that it is all still serviceable as I think spares for Stoves are expensive.
One other point to note is the very poor design of the whole hinge assembly. Not what I expected from Stoves.
Jul 31, 2008 | Stoves 720EF Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
