Question about LG WM-2277HW Front Load Washer
Do I need to drain my LG washer at regular intervals?
  • 15 Answers
You should drain it and remove/clean the filter - if lint builds up in it, you can damage the recirculating or drain pumps.
Posted on Apr 30, 2009
  • 113 Answers
No you shouldnt unless you put to much soap in it
Posted on Apr 24, 2009
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
I need to force my lg tromm to drain
My LG Tromm washer has a small door on the bottom left hand side on the front of the washer. Open the door and you will find the drain filter and a stoppered, small rubber tube. Position something to capture the washer water under the small rubber tube and pull the plug.. This will drain all the water from the washer.
Aug 01, 2014 | LG WM1814CW Front Load Washer
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
Can 3431 be converted to a regular vented dryer?
You cannot convert this model. This unit blows hot air into drum and the water is turned to steam and exhausted out through the pump to the drain. Unlike regular dryers that blow hot air into drum, creating link and just heat that blow out vent.
Jun 22, 2010 | LG WM3431 Front Load Washer / Dryer
Our lg washer model wm0642hw tub clean cycle stops
software problem. regarding smell, after wash keep the door opened for ventilation, use fabric conditioner etc. also check whether any rodent has gone inside and messed up the place
Mar 18, 2010 | LG WM0642H Front Load
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
Lg front load washer WM2301 will not drain
drain hose may be bent or clogged, or the drain filter itself may be clogged
Sep 11, 2009 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
97 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
