Samsung EZ view kit: Remote Monitoring Video Surveillance Sysytems SMO-151QN/XAAV
I can not connect this product to a DVD Recorder. Any Suggestion
  • Anonymous Jul 04, 2008
    can't get vcr to record off of monitor.
2 Suggested Answers
SOURCE: Connecting the recorder to the security system
need to repair samsung video shr 1040
give me adress of repair service
Posted on Feb 01, 2008
Is the 60' cable (MCB-60) considered coax cable?
No, coaxial cable for closed circuit tv systems are either of the RG59U or RG6 variety. The cable you are speaking of is a cable made specifically for Samsung products,which uses a RJ11 connector that is normally found on telephone jack cords. It would be best if you stayed with the MCB-60 cable for your system.
Feb 04, 2010 | Samsung Power Supply, Control Plate for ...
SAMSUNG SMO-211QN SECURITY SYSTEM
1. Connect LAN cable of Cable/ADSL modem or Direct Fixed/Static IP LAN Line to WAN port of IP Router.or hub/sw with cable/lan terminal
2. Connect LAN ports of IP Router/switch/hub(1~4 or 1~8) to Ethernet port SMO-211QN/SMO-150QN to be set up and to
Ethernet port of Local PC to use during setup.
3. Connect Video cable of Camera to MONITOR.
4. Turn on the MONITOR power.
This a basic setup local no internet static ip you will have to
follow directions for setup in the software program you install
on the computer the uset the computer. The computer connected to the lan terminal
I am just giving you the basics you are goilng to have to read
and understand the rest as far as the rest of the setup on the
computer This is from page 107 of your manual
Link to manual if you dont have it
http://www.retrevo.com/s/SAMSUNG+SMO-211QN+users+manual+?sub.x=75&sub.y=14
Dec 07, 2007 | Samsung Color Indoor Security Camera with...
I can't configure my Samsung SHR-1041 for remote
It depends on the router you are using but you should be able to open the dvr in your router to get through your firewall.
Dec 29, 2009 | Samsung 4 Channel Dvr
Camera's won't work
1. check connection wires and terminals are connected correctly there is no struggle in the cable or the cabling has been damage.
2. check the other three cameras the most simple is to connect the cameras that doesnt work in the terminal that does work!
Oct 05, 2008 | Samsung Weather Resistant Security Camera...
Cannot view replay
It has something to do with the software and hardware as well.
But not the monitor that is trouble you.
Mar 30, 2008 | Computers & Internet
Cannot view security system remotely on internet
Check IP address make sure it is correct. Also firewalls will prevent you from linking to dvr.
Nov 02, 2007 | Lorex 4 Channel Business & Home Security...
If you are hooking your cameras into the SMO-151qn then you can use the pigtail cable to connect to the Shr-1040. Make sure the video out from the SMO-151qn goes into the video in of the Shr-1040. If there is a choice use CH1. On the Shr-1040 hold down the mode button and press CH2 for about 10 seconds. The Shr-1040 should reboot. Once it comes up press the record button. After recording for a feww minutes stop the recording. On the SMO-151qn press the button on the front Live/Vcr. You should see the screen from your Shr-1040. IF you hit play you should see what you recorded. Good Luck!
Jun 11, 2007 | Samsung SHR-2082 8 Channel Stand Alone Dvr...
Samsung Digital TV and Sony DVD Recorder
hi, did you find a solution? i have in built freeview and have bought a recorder but i cant pick up any freeview channels on it. the dvd recorder is a Wharfedale DVDRHD400 cheers tom
Feb 11, 2007 | Samsung 4 CHANNEL DIGITAL VIDEO RECORDER...
1,043 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
