Question about Mtd Garden
Yard machine 11a 439r729
Changing oil
5 Suggested Answers
  • 5 Answers
SOURCE: oil change
if this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
SOURCE: How do I replace the starter rope on a YArd
Thanks for your help, but my friend fixed it today.
Posted on Jun 30, 2009
kel1guy2002
  • 3740 Answers
SOURCE: what type of oil is used in a yard machine lawn
SAE 30WT i.e non detergent. Change oil every 25 hours and every 4th oil change us a detergent 30 WT oil.
The manuals will never tell you that but having worked on small engines since the mid 60's that 4th oil change with a detergent oil does a bang up job of keeping the oil ring from eventually cooking onto the piston. Also washes out the crank case and makes it look like new!
Kelly
Posted on Sep 07, 2010
  • 111 Answers
SOURCE: what type of bolt do
You will need MTD part number 710-1257. Or if you have a bolt and screw place it is :Hex Screw, 3/8-24 x 2.5. Hope this helps.
Posted on Apr 03, 2011
My yard machines by mtd mower model number 11a-b13l029 won't start?
Fuel must be less that 30 days old! Air filter OK? oil level OK? Is the shut off cable streteched, If it is then is makes contact and will not allow the engine to start.
May 15, 2014 | Mtd 22" Yard Machine Push Mower
Briggs stratton
Firstly try changing the spark plug. If it still persists check the oil level. It may have too much in it.
Jul 14, 2013 | Yard Machines 158cc Push Lawn Mower #11a...
How to change oil on 158cc briggs
remove oil check stick,Tilt it over and let it run out of the hole. New tech,lol.
Oct 26, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
I can't find a place to check the oil on a Yard Machine, Briggs & Stratton 300 series lawn mower, Model #11A-020B029. Can you help me? Do I mix the oil and gasoline together?
There should be a cap on the side of the engine that looks similar to this picture. The cap may be black in color. When you remove the cap the oil should be to the top of the threads. If you replace the oil it will take 18 oz or 500 ML of oil.
Jun 26, 2011 | Yard Machines Garden
What type of oil is used in a yard machine lawn mower model no. 11A-414E029
Kelly
Sep 07, 2010 | Mtd 22" Yard Machine Push Mower
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
Jul 10, 2009 | Mtd 22" Yard Machine Push Mower
If the oil in my lawnmower is overfull, how do I fix this?
should be a drian plug on the bottom of the mower engine, just drain and tighten up the plug and refill. they usually hold about 16 to 20 ounces of oil. Go buy briggs and stration oil at walmart or kmart just the right amount
Jun 13, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Mower won't run....starts then stops
lawn mower only starts if i prime it. yard machine push mower. m/n 11a-549q229
Mar 01, 2009 | Yard Machines 158cc Push Lawn Mower #11a...
Garden Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
