The fan may be fine, (or not If it's making a rough noise,) Could be packed with dust or hair, or I've seen a label come loose and stop it turning. Either way you'll need to take the LT apart. Here is a guide which will hep you.. Follow step by step.
reinstall windows or get a external hard drive with windows os installed on it and then run that os then you will be able to change the password on the tablet using the external os
What is the exact model of your Dell Studio, A beep code can mean any hardware failure. Post the model of your Studio here and we will post what your beep code means.
Do this beeping code for motherboard troubleshooting.
First disconnect all memory,external video card, etc only motherboard and power supply.
Then power on if you hear continuous beeping means the motherboard working good.
Please do this beeping code troubleshooting.
No beeping meansShort, No power,
Bad CPU/MB, Loose Peripherals.
One beeping means Everything is
normal and Computer posted fine.
Two beeping means POST/CMOS Error.One Long Beep,
One Short Beep means Motherboard
Problem. One Long Beep,
Two Short Beeps means Video Problem. One Long Beep,
Three Short Beeps means Video problem. Repeated Long
Beeps means memory error. Continuous Hi-Lo
Beeps means CPU Overheating.
Each bios type used has its own code. They will flash a series of flashes and or beeps that will help narrow down the problem. These are alled POST codes or power on self test but are refered to as beep codes sometimes.
The code will repeat until you power down. So you need to run it long enough to get the code. The code will be in the pattern of a space then a series of long and or short beeps/flashes and then a paue and the will repeat. As an example three long beeps usually indicates a memory problem. A long beep being about a half second or so.
Once you know the beep code a simple search for beep code on google or bing will get you a chart showing the meanings. At that point you will know if it is a simple fix or a shop job.
