Question about Exercise & Fitness
I bought a Pro-Form Smart Strider (Model # PFEL04911.0) & after assembling it I tried it & there's a scrapping sound in (what I think is) the drive belt & I'd like to know if there's anything I can do to troubleshoot it short of disassembling it. Help, pls!
maxtreadmill
  • 832 Answers
SOURCE: I have a noisy Pro-Form Model 285T treadmill
Hey Richard Depending on the noise it could be one of several components failing. If loud clanking or clunking noises these components are Drive Motor, Front or Rear Rollers.
If it is a loud humming noise increasing and decreasing when planting yours feet then it is either the Inductor ( square object ) or the internal windings of the Drive Motor.
Unplug your unit remove the motor shroud with a long shaft flat tip screw driver you'll be able to pin point the problem with this tool.
Now locate front shaft and rear roller tension adjusting bolt ( refer to owners Manual) plug in unit, start unit and touch flat tip on the shaft and place your ear on the handle the noise will be amplified and you will be able to locate the noise repeat this procedure on the other above mentioned components if problem is not found. GOOD LUCK!
Posted on Jul 31, 2010
Robert Braun
  • 77 Answers
SOURCE: how do you change the
You get full instructions when you buy a new belt from Treadmill Parts
Posted on Jan 03, 2011
  • 190 Answers
SOURCE: I have a pro form treadmill and it seems like the
kilgore511,
The most common cause of belt sticking or "slippage" is lack of lubrication. Most treadmill belts use lubrication on the underside of the belt to reduce friction between the belt and the platform. This helps the treadmill glide along smoothly under the weight of a person. If your belt is lacking in lubrication, it can catch on the treadmill platform. Apply lubrication every few months to the underside of the belt to prevent this from occurring.
A petroleum or silicone based lubricant is recommended, and most easily applied in a spray can. Simply lift up the belt about midway along the platform and spray a small amount of lubricant underneath from about the middle of the platform width to the closest edge. Repeat from the other side. Apply lubricant sparingly...it can be messy.
Next, turn on the treadmill and let it run for a minute, then check if the belt still sticks. A little more lubricant may be necessary.
If you have found this helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Posted on Apr 30, 2011
  • 10 Answers
SOURCE: pro form 400gi belt adjustment
should be a allen wrench adj on the rear of the tradmill
Posted on Nov 11, 2011
ercupa190
  • 12223 Answers
SOURCE: I have a pro form 725 can't see the other letters
please see the video and fix it.
God bless you
Posted on May 23, 2013
I have a Proform Smart Strider. We just assembled it & when I tested it there's a very loud scraping sound when I stride, regardless of the level or program...help, pls. Thx.
I recomend you to disassemble again, and repeat the steps. Something must be there ARE not according with the instruction assembling. Try however for to see the some loose parts, bolts, nuts, and lube.
See this small instruction.s
God bless you
Remove the screws or bolts securing the ends of the pedals to the crank axles. Slide the ends of the pedals off the axles. Remove any screws or bolts securing the left and right disc shields to the base unit. Pull or pry the disc shields off the base unit and set them aside.
Remove any screws or bolts securing the left and right side shields to the base unit. Detach the side shields and set them aside. Examine the interior of the base unit and locate the drive belt.
Pull the drive belt free of the crank pulley, flywheel and any other pulleys. Discard the old drive belt and install a new belt in its place. Turn the crank axles by hand to confirm that the belt will turn smoothly when the device is in use.
Lubrication:
Detach the ends of the pedals from the crank axles. Spread a layer of machine grease over the crank axles, then reattach the ends of the pedals.
Remove the bolts connecting the pedals to the swing arms. Detach the pedals from the arms, then spread a layer of machine grease over the axles on the swing arms. On some models, the bolts may also serve as the axles. Reattach the pedals to the arms.
Remove the bolts connecting the swing arms to the elliptical's upright. Detach the swing arms from the upright, then spread a layer of machine grease over the axles on the upright. Reattach the arms to the upright.
Oct 15, 2013 | Proform Smart Strider SpaceSaver...
Resistance not adjusting
Reading on HSN website, it is b/c this product is junk. Dozens and dozens of reviews stating the resistance is stuck and wont' change.
http://www.hsn.com/products/proform-smart-strider-spacesaver-elliptical/6647352?query=6647352&isSuggested=True
Jan 20, 2013 | Proform Smart Strider SpaceSaver...
Days Strider Midi 4 Plus faults
HOW DO GET THE REAR WHEEL OFF MY SCOOTER NUT VERY TIGHT
Jul 10, 2012 | Electric Mobility Mobility Electric Power...
The latch that opens the door to my Jenn-Air model M170 microwave oven is broken. I need to repair or replace it.
If the point of damage can be glued together with good bonding and further re-enforcement , it can be strong to withstand pressure.
So remove the assembly to try this out before you think there is no way out but to replace with the handle assembly from the service center.
The other option is to get one from a scrapped set.
Oct 01, 2011 | Jenn-Air M170 Microwave Oven
Hi my days strider midi4 keeps going in reverse for about 4 seconds after you take the throttle off
spares sounds like the throttle pot is not being centered upon release making the scooter move in reverse or forward depending on which way it is off center. try pushing on the thottle lever slowly forward when you stop to see if that stops the creeping. Then you can try to adjust the pot by loosening the lever and retightening it in the forward direction that stops the creeping. You might have to order a new throttle pot assembly to get this working right. Hope this helps
Nov 18, 2010 | Electric Strider Midi 4 Wheel Mobility...
We bought a britax strider 3 wheeler pushchair, in january for our granddaughter, my daughter lost receipt moving house, the rear wheels on the pram are wearing uneven, causing the pram to have a wobble...
the strider is now made by 2 different companies
1, uppababby model vista 2009 have a uk based helpline http://www.uppababy.co.uk/contact-us.html
2, abc designs model cobra
http://www.abc-design.de/en/service/contact.html
I have found this out as I am using my strider for my new baby I can now use a carseat and carrycot with the adapters available from these companies
hope this helps
Sep 23, 2010 | Toys
Pro-Form Crosswalk Plus Treadbill back leg extension
iconservice.com has free pdf downloadable manuals for proform.
Nov 12, 2009 | Proform Crosswalk 500 Treadmill
Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Sep 29, 2009 | Poulan Garden
Sound card problem Dell
download from this link
www.lostmydrivers.com/
select sound card driver
select creative
select your model name and model no
Jun 29, 2009 | Creative Labs Sound Blaster Live! 5.1...
Exercise & Fitness Logo
170 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
