Question about Refrigerators
Leaking water jenn air refrigerator MODEL JRSD2490T
JRSD2490T JENN-AIR REFRIGERATOR IS LEAKING WATER FROM WATER. NEED HELP
SOURCE: Leaking water
Mine just starting leaking also. Water gathers in bottom, then freezessolid. then additional water leaks out. I've check ice maker and door water line. confirmed by turning off water supply. Water continues to build in bottom. I think it might be the defroster. somehow the defrosting water is not draining? Check your out and let me know what you find.
Posted on Jan 24, 2008
  • 1314 Answers
SOURCE: jenn air jcd2389g side by side refrigerator water leak
sounds like a leak where your incoming water line hooks to the water valves might just need to tighten the coupling or a mouse has chewed through one or both of the lines access the lines on the back and watch while some one gets water out the door to locate the leak
Posted on Feb 11, 2008
  • 360 Answers
SOURCE: How do I level a Jenn-Air side by side refrigerator
this manual has leveling instructions in it, to download, click --->here<---
Please take the time to give this solution a fix ya rating
clarkco
Posted on Feb 16, 2009
plnolte
  • 62 Answers
SOURCE: HELP WITH WATER LEAK??
If you have turned the water off and it is still leaking out of the freezer side you may have a plugged drain. the drain is there as part of the defrost system to keep modern refrigerators frost free. When the machine goes into defrost and the heater in the freezer comes on it drains out the drain to a pan underneath and the heat from the compressor and the condenser fan underneath the unit evaporate it and the whole process starts all over again. every once in a while something will plug the drain on the bottom of the inside of the freezer side and when the heater kicks on to defrost the refrig the water cant go anywhere but to the bottom of the freezer and seeps out the front at the bottom of the door between the gasket and the refrig. check the drain...because if you have turned off the water and it is still showing up this could very well be your problem. Take the bottom shelves out of the freezer and look to the back and bottom at the middle sometimes you can see the drain and sometimes you have to remove the thin metal panel covering the back bottom half of the freezer,....inspect the drain hole and remove any obstructions or ice build up. if need be pour hot water into the drain to melt any ice that could be causing the obstruction to the drain. and the hot water should drain out of the frige.Write me back and let me know if I can help you further....
Posted on May 13, 2009
  • 2266 Answers
SOURCE: water leaking from jenn air refrigerator side by side
check the freezer side and see if there is ice under bottom rack and floor if so you have a clogged drain,follow the floor to the back wall and the bottom of back wall panel,there is a drain there,use hair dryer to melt out and then you need a steamer or something to blow out the drain line,check it by pooring hot water in the drain you'll know if you unclogged it if the water drains through
Posted on Nov 01, 2009
Jenn-Air Side-by-side Refrigeration not making ice and leaks water underneath when ice maker arm is up
With the arm up in the ice tray, the water solenoid valve should be closed. When the arm drops, that tells the ice maker to open the water solenoid valve to fill the ice maker tray. It sound like the leak is at the inlet side of the water solenoid valve. On some models its not easy to get to, but follow the water line to it. Hope this is it for you. Good luck.
Dec 30, 2013 | Refrigerators
Refrigerators Problem
Make sure coils on back of unit are clean and not touching wall. Are doors closing and sealing with magnetic strip fully? Has some one changed settings without you knowing?
Dec 04, 2011 | Jenn-Air Refrigerators
We have an ice glacier building up behind and below our ice maker inside our Jenn Aire side by side refridgerator model JRSD 2450.
WATER LEAKS ON YOUR WATER SUPPLY CONTAINER TO THE WATER DISPENSER OR CONDENSATION PROBLEM RELATED TO FRIDGE DOOR FAULTY SEAL
Nov 09, 2010 | Jenn-Air JCD2389G Side by Side...
Water leaking from under refrigerator model
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Our Jenn-Air refridgerator is 11 years old and is leaking from the back onto the floor. We looked in the back behind the cardboard panel and saw that the pipes around the( pump ?)located in the lower...
Hello and Welcome to FixYa!
Actually the leaking water is from the evaporator coil unit.... Under normal conditions,Self-defrost refrigerators usually dispose the water generated during the defrost cycle through a tube or channel that directs the water a pan (Known as Drip pan), commonly below the refrigerator unit....
The channel or tube is clogged and the water is leaking to the refrigerator unit, so you need to clear that blockage/contamination....Once the blockage is removed, the generated water will move through that channel/tube directly to the drip pan and there will no water on the floor in the refrigerator compartment. This is all you need to do....
Best of Luck,
Your token of appreciation in form of rating would be highly obliged,
Concerned.
Aug 11, 2010 | Jenn-Air Refrigerators
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
Jenn air jcd2389g side by side refrigerator water leak
Feb 11, 2008 | Jenn-Air JCD2389G Side by Side...
Leaking water
Oct 28, 2007 | Jenn-Air JCB2389G Stainless Steel Side by...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
