Question about Barnett Crossbows Barnett 3x32 Illuminated Reticle Scope
Just recently purchased a cross 3x32 scope directions was very limited ,when you look through the scope you a line of circles up and down small to large but no direction whether in reference to closer or father away it would appear that the larger is for farther away
Which direction do you turn windage and elevation
To raise the point of impact, turn the elevation screw counterclockwise. To shift left, turn windage screw clockwise. If you raise the horizontal cross hair you will lower the point of impact of the bullet. If you move the vertical cross hair to the right the shot placement will go to the left. Make small adjustments tap the scope with a screwdriver handle to give it a shock, not to hard to help move the cross hairs and try to bore sight first. Hope this helps Fix ya up.
Jun 22, 2011 | Tasco 22 Riflescope
I have a newtonian telescope 76mm with SR4, H12.5 and H20. I have aligned the crosses up and can see through the viewfinder but nothing through the eye piece. Ive placed all the other lenses into the eye...
YOU MUST align the small finder scope with the main tube.
Point the scope at a distant object like the top of a telephone pole. GET the top in the center of the eyepiece in the main scope.
Then without moving the scope-- adjust the cross-hairs in the small finder scope so they line up on the same object.
Feb 09, 2011 | Bushnell Deep Space 78-9003 (525 x 76mm)...
I had a gunsmith install my Konus #7234 3x9x32 and the instructions were not forwarded. Q. As I look down the scope at the target, the adjustment labeled left (with arrow) is that oriented like my left...
yes it should be,,,to zero your scope clamp your rifle down so it wont move and fire into a target look at the hole the bullet made and if the cross is not on it move the cross till it is over the hole,,,dont move the gun till you have lined up the cross with the bullet strike,,,,,you should zero it in 3 shots this way?
Aug 28, 2010 | Konus hot Rifle Scope 7234 Matte 3-9x32
I assembled it without a manual because i cant find one, and i cant seem to work it everything looks good but with the lense i cant quite seem to work it, ...
Put the eyepiece with the largest number written on it into the focuser. DO NOT use the 2x barlow if you have one.
Go outside during the day time and practice focusing on a distant object using the eyepiece mentioned above.
Line up the small finder scope with the main tube-- point the scope at the top of a distant telephone pole or church steeple.
Without moving the scope, line up the cross-hairs in the finder scope with the same object. Once this is lined up you can use the small finder scope to locate objects in the sky.
Read my TIPS on my profile page.
Jul 14, 2010 | Citiwell International Orbitor 5500...
Crosshairs look like an x instead of a cross got back from ABO repair for stripped tube, where eye bell fits on. they said they changed the tube. I shot about 50 rds with it when problem developed tasco...
You can get to the cross hairs of a scope, but not much further without some special tools. Take off the rear lens, just unscrew the whole thing, and you will see inside there a ring with slots in the side? A small screwdriver in one of the slots should spin the threads out. You should be able to remove the cross hair tube, inside of it on the front, you should have another lock ring with the slots, spin the cross hairs straight and lock them down. This is a basic scope, I'm sure they are all different, but basically the same. Try it. You cant hurt it, it's already broken, and you will have to send it back out again if you fail. I don't know what they charged you, but there is a guy on ebay advertising scope repair, $45, all scopes.Hope this helps.
Oct 02, 2009 | Tasco Target/Varmint 6-24x42mm Rifle Scope...
I have a Bushnell Elite 4200 6x24x40 rifle scope 42-6242M
First is to try for a group, do not adjust the scope in any way. Shoot 4 rounds with out adjusting the scope. The gun should settle down and start to group. If you can not get a group in 6 rounds go clean that gun & check your ammo. Start over. If she does not group, its the gun not the scope. Once it starts to group move the cross hairs in the opp direction small clicks and "TAP' the scope after each adjustment. Shoot for a group each time 2 rounds should group. Get a target that has a grid to help get on faster.
Sep 20, 2009 | Bushnell Elite 4200 6-24x40 Riflescope...
Cross hairs canting to the left..how do i recenter the recticle?
From your short description, it sounds like the Horozontal (the ELEVATION) reticle is canted to the left. If that IS the case then do this;
Sand bag the rifle on what you know is a level and firm surface. The rifle MUST be level itself. You can use a small level to determine this.
Without moving the rifle, look through the scope and determine if indeed the horozontal or ELEVATION reticle is indeed canted. The reticle should be LEVEL in relation to the ground and the rifle itself.
If it still appears to be canted, loosen the set screws of the scope ring caps (Not the scope mounts) and while looking through the scope, gently rotate the barrel of the scope clock wise until the Horozontal reticle appears to be now level. Re-tighten the scope ring caps and look through the scope again to make sure the Reticle is still 'level'.
You must now make sure that your scope is still 'zero'd'.
IF the issue is something other than what I have assumed from your description, please send me a msg. with more detail and I will be able to resolve whatever issue you are having. Include the 'Brand and model', plus the power of it, and the brand/model/cal. of the rifle the scope is mounted on.
Good luck. :)
Apr 27, 2009 | Nikon Tactical Rifle Scope 4-16X 50...
Who makes twinstar telescopes and how do i find
I suggest avoiding the Twinstar line of telescopes. These are sold by Taximarketer who sells a line of disappointing scopes including the Baytronix 150/1400. It is best to avoid Ebay unless you really know your stuff.
One reason is the lack of directions-- NONE!
However Meade telescopes maintains a web site with manuals for their telescopes. Look around the page and find one similar to your scope and download the manual for free.
http://www.meade.com/manuals/index.html
Apr 19, 2009 | Optics
Crosshairs are cocked to the right.
your scope has spun in the scope rings. Loosen the screws holding the scope to the rifle and turn scope until crosshairs are into position. Then tighten screws. You will need to sight in again. If it keeps moving replace scope rings.
Dec 12, 2008 | Tasco 3-9x40 World Class Riflescope 30/30...
Roomba just runs in small circles
i just recently had someone bring in a roomba discovery and all it would do is stay in a tight 4 tile area and go in circles. battery was fully charged and all bumpers were clear.
i took a can of air blast for cleaning computers and blasted the area on the bottom underneath the sensor and watched as several dust bunnies came flying out.gave it a few more blasts for good measure and put it back on the floor and hit power then clean buttons.
thing went in same tight circle for 2 passes then the circle got bigger for 2 more passes , blue light indicator came on and it made a straight line dash across to closed door and started following the edge and criss-crossing the room.
called the owner back in to test and it repeated the same moves when she started it and all appeared to be working normal again.
Aug 13, 2008 | iRobot Vacuums
Barnett Crossbows Barnett 3x32 Illuminated Reticle Scope Logo
64 people viewed this question
Top Barnett Crossbows Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Barnett Crossbows Optic Expert? Answer questions, earn points and help others
