Question about Makita Tools 12" Compound Miter Saw - LS1221
Makita Ls1212 works intermittently
My mitre saw would occasionally stop working. Was a problem more and more until it would occasionally work. Now, it won't work. Tried different outlets just in case. I changed the brushes - worked for a little while. Now, not at all. The saw is 6 yrs old, but only gets used from time-to-time.
  • william_mall Apr 24, 2009
    Hooah! Thanks for the suggestion. The power cord is in perfect condition (from a visual inspection). I guess I could check the continuity from the trigger to the plug.
    Any idea how finicky the Makita is from a power requirement standpoint? I was originally under the impression that maybe the voltage from my box was insufficient - 113 v vice 120. I tried multiple outlets, but obviously they all go to the same box. The saw is now plugged into the outlet nearest the box.
    Thanks, I'll give it a go.
    President:
  • 1,902 Answers
Check the power cable. They could be broken or frayed and you are not getting enough power to it replace and then try to see if it works then. Make sure you buy the right size gauge for you machine
Posted on Apr 24, 2009
  • Jeremy Reddick
    Jeremy Reddick Apr 24, 2009
    If a piece of electrical says it needs 120 volts. Then anything from 110 to 125 volts will run the unit just fine. I am talking more about a issue concerning a shortage in the unit. The trigger is another good spot to start at. Visual inspection sometimes is great, but sometimes there are broken wires that are not allowing even 90 volts to get to the machine. This seems to be something small, like the power cord or the trigger. Doesnt seem to be the brushes
  • Jeremy Reddick
    Nota problem, if that does not work then write me back and we can look into other things. While you are in there checking the trigger, why dont you run some more diagnostics on the makita with the volt meter and see what is and what is not getting power. Remember though. The trigger should only be about 25 volts and some other parts will be the same way
Why doesn't the laser marker work on my Makita mitre saw?
contact Makita, it may be defective
, or they can troubleshoot. You can check on youtube.com for a possible fix also.
Mar 07, 2015 | Makita 10" Miter Saw LS1030N
Makita 2401b
Some mitre saws have extra windings in the field coil so a possibility is a break in this brake coil another possibility is the switch some have a contact that switches the back emf from the field coil to the brake coil when you release the trigger. And believe or it or not some times changing the brushes affects the braking have seen this a few times on the LS1013.
Mar 15, 2014 | Saws
Table saw starts for 2 second and stops
if it is electrical u might wont to check the battery if it is gas u might wont to chek the oil or the gas if it is gas
Jun 03, 2013 | Makita 2703 10" Table Saw, Electric Brake
Change blade Makita LS1030 10-Inch Compound Miter saw
There is an 8mm bolt on the front of the guard. Loosen/remove this and the central guard mount will drop slightly. Behind the metal guard is a slide lock for the blade spindle. Push the lock bar and turn the blade untill it catches and is held solid. Then remove the blade fixing bolt and bobs your uncle. Alternativly, with all mitre saws, you can just pop an old bit of wood on the work base and then use the spannrer/allen key supplied to turn the blade so it bites into the wood as if you are trying to cut it. This will hold the blade steady and you will also be turning the bolt in the right direction.
Jul 23, 2012 | Makita 10" Miter Saw LS1030N
Is there a safety or something that needs to be released to lift the mitre saw blade and handle up to get wood underneath the blade...borrowed from a buddy, not sure how it works.
Yeah, there is a latch type keeper on the back there that holds the motor down for transport. Should be easy to find. Hope this helps.
Sep 22, 2010 | Makita 10" Miter Saw LS1030N
I have a Makita 10 inch compond mitre saw. My owners manual has been lost and I need the tables that show what degree to set the mitre and bevel for various degrees.
You can get it at Makita.com, type in yr modal number in the search bar, download a parts breakdown or a manual, if not u can order a new sticker from makita.
Jun 08, 2010 | Makita 10" Compound Miter Saw LS1040
My makita sliding mitre saw is off a few degrees How do I adjust...non laser...10''
move the blade until it is square to the fence then loosen the screws on the table with the degree increments and set to zero.
Nov 19, 2009 | Makita 10" Compound Miter Saw LS1040
Need to re assemble trigger of ls1040 mitre saw, is there any instructions
go to MAKITA TOOLS.COM under benchtop on the menu select miter saws and your model number once in there there is a menu showing instruction manual, parts assembly and you can geta full print out diagram of how it should go together
May 03, 2009 | Makita 10" Compound Miter Saw LS1040
I have a makita mitre saw and need to adjust the angle to 45 degrees. I unlock it and try to turn it but it won't turn. Any ideas?
you have to turn the handle, it works like a bolt, you cant see it but it is tied in, you have to unscrew it before trying to move it
Dec 13, 2008 | Makita 10" Dual Bevel Sliding Compound...
Makita Tools 12" Compound Miter Saw - LS1221 Logo
270 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
