Question about Refrigerators
Ems 55 advanced temperature - Refrigerators
When em heat is on my outside unit runs but when not on em heat it doesn't. Which setting is best to use?
Has this always been this way? When the emergency heat is on the outside unit shouldn't run. When in normal heat, no emergency heat, the outside unit should be running unless the temperature is below the balance point ( usually around 35 degrees). If this has always been this way and the outside temperature is above 40 degrees you might have your 1st stage and 2nd stage wires switched.
Nov 27, 2016 | Heating & Cooling
Why if my antena is hooked to my dvd player is it not getting channels but my tv is if dvd player is turned off
The reason probably is because all broadcast TV is digital, and the em-55 tuner is set for analog channels. It cannot receive today's broadcasts "thru the air" because channel 2 for example is not broadcast, rather channel 2.1, 2.2, etc.
You can use the signal with a new TV, but when you turn ON the em-55, it inserts channel 3.
Most all TV here has what I call sidebands, and some have as many as 11, so the tv can be set for 3.1, or 3.2 or 3.3.
Even if you have a digital-to-analog device, the em-55 will not receive any .1, .2, .3, .4 and so on. I verified this recently reconnecting my old antenna to the converter then to several VCR's and DVD players.
Turn off the em-55, and the dot channels pass through the RF connectors..
Some DISH, cable direct TV receivers convert the signal to ch 3.
Sep 25, 2014 | Panasonic DMR-E55 DVD Recorder
Why i get H4 error on 5516
Heat roller abnormally low
temperature
When the temperature does not
reach 155°C within 55 sec after
turning on the power, or when it
falls under 145°C during printing,
or when it falls under 100°C
during pre-heating
May 28, 2014 | Sharp AR-5316 Advanced Digital Imager...
WHAT TEMPERATURE DO I COOK3LBS. BABYBACKRIBS
About 225f for 2hours. Don't fuss with rubs and such just soak em in Dale's before ya put em on. Have plenty refreshments handy. When do we eat?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 04, 2011 | Masterbuilt 20070106 Electric Smoker
How to preheat my new microwave model EM-C5796V of sanyo
you really don't pre-heat a microwave. set it for the time you want to cook and it reaches the temperature for cooking almost instantly
Sep 27, 2010 | Sanyo EM-Z2100GS Microwave Oven
Replacing temp sensor
Intake Air Temperature Sensor Operation The Intake Air Temperature (IAT) sensor is a variable temperature sensitive resistor. Sensor resistance will change based on air temperature. The higher the temperature, the lower the resistance. The Engine Management System (EMS) provides a reference voltage and monitors the voltage drop between a fixed value internal resistance and the sensor resistance. This is called a voltage divider circuit.
IAT sensor values are used by the EMS to assist with the calculation of idle speed, fuel mixture and spark advance.
Inaccurate voltages from the IAT sensor may affect pulse-width, idle quality and tail pipe emissions. Intermittent signals may cause hesitation, stumble and surging. If an IAT sensor failure accompanies an Engine Coolant Temperature (ECT) sensor failure cooling fan operation may also be affected.
Some manufacturers' incorporate the Intake Air Temperature (IAT) sensor as part of the Mass Air Flow (MAF) sensor, or air flow meter. Refer to current service information for specific applications.
Related Symptoms The following symptoms can be caused by a faulty IAT sensor due to loose connections, bad grounds, high resistance in the circuit, or opens in the circuit.
  • Extended crank time when the engine is cold
  • Poor fuel economy
  • Spark knock
Jul 16, 2010 | 1996 GMC Safari
Heat pump runs in em heat when outside temperature is low
Yes, you may turn to em heat only. May this confirmation help you.
Jan 06, 2010 | Heating & Cooling
Nikon EM film winding lever is stuck. Can I repair this myself? Purchased at a yard sale with loads of lens and worked great for about 7 rolls of film. Shot part of a roll and lever refused to advance...
Bad news. I have an EM on the junk pile for a similar reason. In my case, the lever stuck and when I tried to advance the film, the plastic on the top of the camera body fractured and the whole mechanism separated. The current E-bay price on an EM body is under $30. Since the EM was made out of plastic, it is not repairable. If you have several lenses, it will be worth the low cost.
I have had Nikons of various models for over 50 years and in my opinion, until they fail such as your has, the EM is probably the most comfortable non-professional 35mm camera to hold and use that Nikon ever made.
Nov 22, 2008 | Nikon EM 35mm SLR Camera
Shutter fires when film advance lever is used.
The problem you describe is common with the EM. I have one myself sitting on the junk pile for the same reason. The body is made of plastic and the plastic around the advance lever is a week point. Your body, unfortunately is not repairable. But there is good news. Because of the low cost of a replacement EM on E-bay (under $30), you should consider keeping your lenses and buying a new body (the standard 50mm f1.8 EM is superbly sharp for a low end lens). Since the EM lenses are interchangeable with later models, you could consider a later model used body. Many are selling for fire sale prices.
Sep 23, 2008 | Nikon EM 35mm SLR Camera
Refrigerators Logo
168 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
