Question about Vacuums
We have a rockworth model RW-WDV30LSS and when the machine is turned on the air is coming out the blowing port but also sucking from the vacuum port.
  • 883 Answers
SOURCE: Rainbow E Series Vacuum
the motor is actually spinning backwards? try to confirm this.
Posted on Jun 02, 2007
reddevil6
  • 1673 Answers
SOURCE: SteamVac Supreme Vacuum Problem:
Does this have the slot in front of the dirty water tank for the hose? If it does and the hose isn't installed, there is a block that you put in when the hose isn't being used. If not there, then it will blow air and won't suck up.
Posted on Jan 15, 2008
reddevil6
  • 1673 Answers
SOURCE: Dysin vacuum blows air instead of sucking it!
If it is blowing air, then it is still clogged up somewhere, you didn't give your model number, but some of these have removable covers on each side and on the back. Also make sure that all covers are back on securely.
Posted on Jan 22, 2008
SOURCE: Kenmore Progressive Model # 116 25914507
I had the same problem with my vacuum. I called in for technical service and was told to push the "reset button". It turns out that there is a small red button right next to the dirt indicator light. I pushed the button, plugged the vacuum back in and started it up and it worked like a charm! :) Hope this helps!
Posted on Mar 26, 2008
Agent Don
  • 310 Answers
SOURCE: My vacuum blows air instead
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=571660
Generic problem for all Vacuums
Posted by katweaver3 on May 04, 2008
My vacuum blows air instead of sucking air. I have a dirt devil swivel guide. I got something stuck in the brush spinner, got it out...but now the vacuum doesn’t **** stuff up anymore.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Normally if your vacuum has a round belt you may have your belt on backwards, please reverse the belt and the suction will return also you may have a clog in the tube leading up to the bag or dirt cup would be anther reason for the blowing instead of suction. This is not covered under the factory warranty. Feel free to contact your local vacuum dealer for questions.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Posted on May 05, 2008
Shop Vac MAC 12-200D my shop vac is blowing air instead of sucking air. How do I fix it
this might sound silly but have you got the pipe in the blowing end instead of the sucking end hope this helps
Oct 09, 2016 | Shop Vac Vacuums
Kenmore w PowerMate just blowing...NOT sucking
Have you made sure the hose is completely clear of any and all obstructions? the power mate also? I have to make the assumption that you're checking the air coming from the rear exhaust port to know that it's still blowing. Take the hose out of the machine and check the suction at the machine itself. If it's good there and not at the end of the hose, that's your problem.
Oct 22, 2013 | Vacuums
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
How do I switch from blowing to sucking
Just took a look at the exploded view for this vacuum and I think there is no way to set it up to "blow" air out of the unit via a hose. On a lot of the vacuums of old there was an input hose port and an output (blower) hose port. Many of them these days, such as yours, exhaust the air in a general manner as opposed to a port that a hose can be connected to in order to act as a blower. Looks like you can only use it as a vacuum.
Oct 02, 2010 | Black & Decker UV200 Wet/Dry Vacuum
Husky 6 gallon dry/vac wont **** in air, only blows air out
Maybe you have the vac hose plugged into the blow out port.
Nov 16, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Jan 07, 2008 | Vacuums
Dysons aren't supposed to clog up, but they do. There a number of ports you can open to see if there are clogs in any of them. Usually a clog is why it will blow air and debris out instead of sucking. You just need to find it.
Jan 05, 2008 | Vacuums
Blowing warm air
Is there a part missing on the front of the dirty water tank? On some of these machines, there is block that you take out so you can insert the hose in its place. So if this spot is open, then it can't suck and will be blowing warm air.
Dec 15, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Help needed pronto!!
Most vacuums are make to suck not blow. Except for the Rainbows or Rexair vacuums. They have a port for blowing air.
Oct 30, 2007 | Vacuums
Vacuums Logo
46 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
