Question about Moultrie Feeders Lx30ir Game Spy Camera
What iram on my camera - Moultrie Feeders Lx30ir Game Spy Camera
Night Pictures
make this test .God bless you
When troubleshooting problems with your photographs, you need to be able to distinguish between problems created by the camera and problems created by the, ahem, photographer. Some things, like a finger over half of the shot or a totally out of focus picture of your own feet are not camera malfunctions. Fortunately, most of what appear to be "malfunctions" are things you can correct through settings. Blurry pictures usually result in pressing the shutter button down before the autofocus kicks in; half-tap the shutter to bring the camera into focus then press it all the way down to take a clear shot. Grainy photos are the result of a high ISO value and low light; use a tripod or, if necessary, the flash when taking pictures in low light. Different makes and models have different ways to warn you that the light is low: some display a shaking hand icon, others a red light. Look for this and adjust photo settings.
Nov 08, 2013 | Moultrie Game Spy M-80xt Infrared Camera
I just changed the battery in my HP 48GX that I haven't used in some time, but the alert symbol is on and nothing else is happening
The following procedure valid for the HP 48G should work for the HP48GX.
Make the calculator perform a
Self test.
  1. Turn calculator on
  2. Press and HOLD the key [ON]
  3. Press and release the key with "E" to its right (the one before last in first row)
  4. Relaese the [ON] key.
It tests the RAM and ROM. You will see various patterns on screen. Afterwards you should see
IROM OK,
IRAM OK,
HP48GX OK
The self test will continue repeatedly until you perform a
System Halt
  1. Press and HOLD the [ON] key
  2. Press and release the "C" key
  3. Release the [ON] key.
The empty stack should appear.
If you do not see IROM OK and IRAM OK, the calculator requires service.
If the above procedure is successful, you may want
to test the keyboard.
  2. Press and HOLD the [ON] key
  3. Press and release the "D" key.
  4. Release the [ON] key
  5. Press and release the "E" key. KBD 1 should appear on the top left corner of the screen.
  6. Starting at the upper left corner of the keyboard, and moving Left to right, press every key in sequence. If you follow the sequence and the keys are functioning properly you should hear a hight pitch sound at each press.
  7. If everything is OK, when you press the last key (+) the screen displays KBD 1 OK.
To exit the keyboard test proceed as described above under System Halt.
If you follow the proper sequence and a hexadecimal number appears after pressing a key, the calculator requires service.
Hope it helps.
Nov 07, 2009 | HP 48gx Calculator
The calcutor doesn't turn on from the first time. It takes too long to turn on and at random. Also the soft keyd don't work. I try to set the modes but when I press shoose nothing happens.
The following testing procedure valid for the HP 48G should work for the HP48GX. If any the tests fails the calculator requires service.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 23, 2009 | HP 48gx Calculator
Have a 48GX that stopped working, placed new doubleA batt no response... Note a wird meshed blue line at the center of the screen... Thx jsd
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Sep 15, 2009 | HP 48gx Calculator
Calc. asks to recover memory, display goes blank, keys beep
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Aug 04, 2009 | HP 48gx Calculator
The #3 key sticks and won't show on the display
Try the following procedure (valid for the HP 48G should work for the HP48GX.) If any of the tests fails the calculator requires service
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Jun 30, 2009 | HP 48gx Calculator
HP48SX keeps asking to recover memory
Here is the procedure to test the good or bad working order of your calculator. The procedure valid for the HP 48G should work for the HP48GX. If any of the test fails the calculator requires service.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Mar 27, 2009 | HP 48gx Calculator
My HP 48GX with COGO Card is running slow.
You should perform the dagnostic tests.
The following procedure valid for the 48G should work for the HP48GX.
Self test.
IROM OK,
IRAM OK,
HP48GX OK
System Halt
Hope it helps.
Nov 12, 2008 | HP 48gx Calculator
Moultrie Feeders Lx30ir Game Spy Camera Logo
521 people viewed this question
Top Moultrie Video Cameras Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
