Question about Electronics - Others
Doesn't turn on with batteries
It doesn't work on batteries but it does work with electricity
  • David Dunn
    David Dunn May 11, 2010
    What is IT? Better questions lead to better answers.
My mac doesn't turn on
Sounds like an issue with the battery, or far less likely, the power supply (which carries electricity from the battery to the various components inside your computer).
Dec 13, 2012 | Apple MacBookAir A1370 -19648
Do i need to turn my 24v 200w kids razor sccoter on to charge it? and how long do I charge it for?
no it doesn;'t need to be turned on to charge it, it should usually take about 8 hours to get a full charge
Jun 28, 2012 | Electric Eyeware 24 Volt Battery Charger...
Hyundai Sante Fe Imobiliser problem?
can you hear the starter click at all take a hammer and tap on the starter if that works then you know the starter is bad, if you are comfortable enough take out the battery and the starter and take them to your local autozone have them tested just because a battery is fully charged doesn't mean that it doesn't have a dead cell or 2. They can test the starter also
Jun 03, 2012 | Hyundai Santa Fe Cars & Trucks
I have a laptop it was working well but than it stopped working i don t know what is the problem
hi, the lights in the laptop doesn't turn on either? If so, the problem must be electrical. Check your battery and the power outlet.
Sep 24, 2011 | Computers & Internet
Turn signals and horn not working
check the battery if it still ok
check each each bulb and circuit line of the signal lights as well as the horn too...
* might be some shorted or cut lines in the electrical thats why it doesn't work...
hope it helps...
Jun 04, 2011 | Suzuki GSX-R 750 J Motorcycles
My hyundai santa fey has just lost all electrics.Drove it fine to shop turned engine off. went to turn it back on nothing -no lights nothing from the battery even the key doesn`t work.tried jump start but...
i would start by checking the connections on the battery and having the battery tested, also why where you taking it to the shop?, if the connection are dirty a jump start wont work, they may look clean but loosen them and twist them on battery terminals to make good connection then tighten them ,and make sure battery is fully charged,
Jun 11, 2010 | 2006 Hyundai Santa Fe
Bought this used.. Plugged in the battery but it doesn't work (and the battery is good). Is there an on switch or a key or something to turn it on?
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
May 11, 2010 | Peg Perego John Deere Gator HPX Ride on...
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
