SOURCE: clock setting on alpine iva-w200
Copied from Alpine-usa.com support page:
Setting item: CLOCK ADJUST
Further setting items : HOUR / MINUTE / TIME ADJUST
Setting content: 1-12 / 0-59 / RESET
• The clock-adjusting mode is canceled when the power is turned off,
when [RETURN] or [CONTROL] is touched.
Setting item: DAYLIGHT SAVING TIME
Setting content: OFF / ON
Setting the Time
HOUR: Adjust the hour.
MINUTE: Adjust the minute.
RESET: If the clock shows less than 30 minutes past, the
minute will be “: 0”; more than 30, the hour
advances.
Setting Daylight Saving Time
ON: Place the Summer Time mode ON. The time advances by
one hour.
OFF: Return to the ordinary time.
SOURCE: I need instructions on how
If dont mistake and bad remmeber...
1. Press and hold the "sound setup" button for at least 2 seconds, and let the radio go into the setup mode. The button is located to the lower right of the control knob.
2. Turn the control knob to select "clock adjustment, and then press the "play" button. The time indicator will start to blink.
3. Turn the knob to adjust the hours, then press "play" again.
4. Turn the knob to adjust the minutes, then press and hold the "sound/setup" button until the radio returns to its normal operating mode.
This is other way, for Alpine Radio Cassete,
1. Turn the ignition to the "On" position so that the stereo powers up.
2. Press the "Clock" button and hold it down for at least three seconds or until the clock displays on the screen and starts to flash.
3. Press the "Hour" button (the No. 5 radio preset button) until it displays the correct hour.
4. Press the "Min" button (the No. 6 radio preset button) until it displays the correct minute.
5. Press the "Zero" button (the No. 4 radio preset button) to reset the second count to zero.
6. Don't touch any buttons for five seconds once the time is set. The display will stop blinking, and the time will be officially set.
Hope this helps.
SOURCE: i have an alpine cd player cde9845 in my car. how do i set the clock?
Follow the instructions on page 15 of the manual.
