Question about Whirlpool Duet GHW9150P Front Load Washer
Start and after few minutes show "dl" f
Press start and after few minutes beep and show "dl" f
  • Anonymous Apr 25, 2009
    I started the washer, ran a few minutes then got "DL" "f" problem.
    I cannot unlock the washer even after holding end of cycle button for 3 seconds.
  • 240 Answers
Easy fix, door lock failure, replace door lock asm. on old duet this part is same as GE, and samsung parts. new duets differ
Posted on Apr 26, 2009
Beeping sound when starting
Usually when you first turn the power on ... it's usual to hear a couple of beeping sounds . And then, you may hear whirling/clicking sounds when your disk starts up (rotating) and your CD/DVD drive starts up, etc.. Then the monitor/screen lights up and starts to show the operating system (e.g. Windows) panel ... as it starts up.
If your system just beeps ... and beeps ... and beeps... and nothing else happens, the screen doesn't light up and show anything (for a few minutes), it likely the system is not starting up properly.
If you can clarify what actually happens, maybe I can offer more suggestions/information to help.
Apr 03, 2014 | Computers & Internet
Samsung microwave displays press 1-4...
The SE indicates a short in the keypad membrane, but to cure this! the whole keypad control board should be changed if effort to resolve is decided, I would also suggest checking the pricing.
Apr 16, 2012 | Samsung SMH9187ST Microwave Oven
When I try to use the washer I press the Express Wash Cycle as usual. The panel lights up as usual but when I press the start button it dosen't start. I don't hear the front load door lock as usual and...
'F' for fault, 'dL' for door lock and you don't hear it operating. It's pretty clear there is a problem either with the lock operating solenoid (highly likely 'cos you don't hear it operate) or the door lock sensor (not so likely).
Either you need to replace it or it needs replacing by a service engineer. Sorry, no other option ;-0(
Good luck,
John C
Mar 04, 2011 | Kenmore Elite 45986 Front Load Washer
Dryer won't start. Pressing "Start" button just emits 4 beeps.
does the drum turn? if it doesnt you can assist it and see it that is problem, have to remove top and push it. that would be capacitor on motor or jumper the door closed switch and try to spin.
Apr 21, 2009 | Dryers
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
F7 Code and stove beeps
F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F7 Shorted key sensed for 32 seconds 1. Membrane shorted, or,
2.
Display board defectiveIf touch pad is a separate unit then unplug it and see if code comes back.  Unplug range before doing so.  Once touch pad is disconnected, plug range back in and see if code shows.  Wait a few minutes.  If no code then replace touch pad.  If code does come on while touch pad is disconnected then replace main control.  If touch pad and main control are all one part then replace the whole control.  Doubt if you would have any luck trying to unstick the bad button as stated above.
Oct 15, 2007 | Jenn-Air JGR8850 Gas Kitchen Range
Whirlpool Duet GHW9150P Front Load Washer Logo
159 people viewed this question
Dan Webster
Dan Webster
Sal De
