Question about Do All Traps Do-All Outdoors Red Pigeon Trap
Dosent seam to get power, red lite comes on when you let off pedal nothing works.
My Huskylock 936 won't sew. I was sewing yesterday, 4 thread overlock. I finished a seam, cut the thread, proceeded to sew another seam. I put my foot on the pedal..and nothing.If I turn the machi
Good evening madam
It sounds like there is something wrong with the electrical system in your sewing machine. You can check the power and connections.
good luck
Kolbrun
Feb 26, 2012 | Husqvarna Huskylock Computerized 936
My boss metal zone pedal power light wont come on when i hook the ac adapter to it i get nothing but a hum and no output clean or distortion,then when i plug a 9volt battery in it gives only clean tone...
There is a switch contact that connects the battery when you unplug the AC adapter. These commonly get sprung and cease to make contact leaving the battery disconnected when adapter is unplugged, resulting in no power. Verify the battery is being connected and see if the unit works properly. If so the adapter is either the wrong one or defective.
In other words, there may be two problems.
Jan 30, 2011 | Boss Mt 2 Metal Zone Effects Pedal
When switching ds lite on green light flashes then foes off andbottom screen just flashes on then foes off - top screen does nothing
make sure the top screen ribbon cable is attached to the connector properly, push the cable in as far as it will go and then try again, if that dosent work it may be a fuse on the board prob f2 if that dosent work change both it should fix the problem
Jan 14, 2010 | Nintendo DS Lite Console
Red lite comes on but tv will not power up.
Follow the solution for service port 'jump start' with a usb plug. Plug your cell phone charger in next to the TV. Touch the metal prongs of the service port with the metal part of the usb until you get a brief 'flash' on the TV. Then turn on the tv set. It takes patience and a flash light to do this, so you can see what your touching, as my husband couldn't get it to work, but I could.
Apr 20, 2009 | Olevia LT23HVX 23 in. LCD Television
1985 Chevy 1/2 ton
If you have no dash lites< I would suggest checking either of the following as thse are the most common problems 1) chec your fuses 2) test the headlite switch, as for the brake lites I would again check the fuses and then move on to the brake lite switch and see if there is power going into the switch and coming out of the switch with the brake pedal depressed, if not it's the switch if there is power trace the wire back to the brake lites checking all connections in between for power. Finally test the lite pig tail ( socket ). Good luck and rember to rate all the solutions that you get on FixYa, thanx
Nov 01, 2008 | 1985 Chevrolet Chevy
AR won't work, screen is white, nothing happens
this is an action replay problem, try to use a damp cotton swab and rub it on the bottom where it reads. If this dosent work please consult.
Jun 15, 2008 | Nintendo DS Lite Console
Samsung p2 won't turn on
HEYY. okay. mine did the exact same thing but i took a toothpick and pressed the "reset" button on the back of the player. after i hit it once or twice, i tried turning it on and it worked.
Mar 18, 2008 | Samsung Yepp YP-P2 Digital Media Player
Picture went off still had sound then i turned off at panel now only red timer/standy stays lit sony 61" projection
First plug in again and look at led light, the amount it blinks tells what is wrong. Then if it stays lite it tells something also. You can try Display-channel 5-volume +- Power(service mode). Then Channel 8-enter(test reset). If this doesn't work then you will have to replace somethings like F601, R607, Q601, IC601, R612, VDR601.
Oct 05, 2007 | Sony KP-61V85 61" Rear Projection...
Do All Traps Do-All Outdoors Red Pigeon Trap Logo
Top Do All Traps Sport & Outdoor - Others Experts
Are you a Do All Traps Sport and Outdoor - Other Expert? Answer questions, earn points and help others
