Question about Samsung UN-46D6400 46 in. Class LED Smart TV
I HAVE A SAMSUNG 46 INCH LED SMART TV AND IT WONT TURN OFF OR ON.THE RED LIGHT CONTINUOUSLY FLASHES.THE SMART TV SIGN WILL FLASH ON THE SCREEN FOR A SECOND THEN GOES OUT.I HAVE UNPLUGGED THE TV OVER NITE AND SOMETIMES IT WILL TURN ON THE NEXT MARNING BUT AFTER I SHUT IT OFF IT WONT COME BACK ON.HAD THE MOTHER BOARD CHECKED ITS GOOD
SOURCE: Samsung flat screen wont turn on red light just flashes..
wont turn on red light just flashes?
On my samsung flat screen tv when you are watching the televison there is no red light on the power button but when you turn the television off the red light stays on all the time? what can I do to turn this light off?
Posted on Oct 29, 2008
SOURCE: Samsung TV won't turn on- trying to fix it. A challenging problem
I had the same problem. I live in NJ and called the local authorized "service provide" listed on the Samsung website. What a joke. Quoted $350 just to show up, never showed up. So I opened my own TV. Took off the plastic back (10 screws) took off the large metal RF shield (12-14 screws) and noticed a blown component. The markings on the component were KL15L and it is apparently an NTC Thermistor. Obviously it got fried and not knowing if there was other damage I decided to set out to replace the entire Power PCB Board Assembly and not the component. There were two part numbers on the assembled board (BN97-00457E & BN94-00622E). After searching online I also found a suitable replacement number for these (BN96-04896A). I found two places who claimed to have the part or have it on order (shopjimmy.com and vancebaldwin.com). After placing orders with both and having neither come through, I broadened my search and found out that the LNR409D was basically the same model as my LNR408D so I looked for its Power PCB Board Assembly part number which turned out to be BN41-00521B. Google search for that part number showed the item available on ebay. I bought it a week ago (ebay 260311519904) for $144 plus $12 shipping. I removed the bad board an hour ago (6 screws about 7 connectors) installed the new one, plugged in the connectors, replaced the covers, plugged in the TV... AND IT WORKS!
Suggestion: If your TV is out of warranty then open it up (what have you got to lose) and see if the problem is obvious and maybe something you can fix (replace) yourself. The parts, spare boards, etc. are out there if you look.
Posted on Nov 16, 2008
SOURCE: samsung tv LE32R74BD standby light on but wont turn on
samsung tv le32r74bd had tv on standby and wont turn on,it is stuck on standby please can you solve this
Posted on Nov 24, 2008
  • 7 Answers
SOURCE: 46 inch Samsung TV that just clicks but wont turn on
I just fixed this very same problem. It is the capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Posted on Sep 25, 2009
  • 304 Answers
SOURCE: my 32" Samsung lcd tv won't turn on, led is solid red
The Main bd is bad. It is not sending a turn on signal to the power supply.
Posted on Apr 16, 2010
Samsung smart tv no picture and sound. Replaced T-CON and Main Board. Same result. Any ideas?
did you change power supply? how many times does light flash (red) you didnt change the power supply did you use a vom on connections?
We Are Here To Help !!!
Donal Deane MCSE,ASE,CPO
Aug 18, 2017 | Samsung Televison & Video
Why won't my 46 inch Smart TV power on. The power on/off red light just keep blinking.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
Dec 18, 2015 | Samsung 5500 Series UN46F5500AF 46" LED...
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
Tv does not come up standby light keeps blinking
It seems there is no information in the manual here http://www.finluxdirect.com/content/ebiz/shop/resources/pdf/46S8030-T.pdf
So you may want to attempt to talk to their support. They have free on line chat here Finlux Direct Help Centre
Good Luck
Apr 10, 2014 | Finlux 46S8070-T 46" LED TV 1920x1080, 100...
Tv wont power on red light continuously flashes
Hi,you need to have the capacitors in the powersupply replaced
Oct 15, 2013 | Samsung UN46D6400 46 Inch 3D 1080p Smart...
Jul 20, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Samsung UN-46D6400 46 in. Class LED Smart TV Logo
26 people viewed this question
Jerry Greenberg
Jerry Greenberg
