Question about Philips SRP5107/27 UNIVERSAL REMOTE 7 IN 1LED ILLUMINATED KEYS
Philips SRP5107/27 UNIVERSAL REMOTE code for DirecTV receiver. The code listed doesn't work.
  • 1694 Answers
SOURCE: remote codes for "ph301s" universal philips remote
www.remotecodelist.com .............................T.
Posted on Mar 23, 2008
IrishDruid
  • 2712 Answers
SOURCE: universal remote codes for a philips remote
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. -You can rate this solution with one of four votes, if you feel your issue is resolved (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 07, 2008
aprmaejun
  • 97 Answers
SOURCE: philips universal remote codes for symphonics tv
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Posted on Jun 18, 2008
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
Line up your original remote and the head-to-head before completing thefollowing steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
  • 74 Answers
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba 0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
Posted on Sep 17, 2009
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
Tip
DirecTV Remote Control Code List Download
Download DirecTV Remote Control Code List
Have you lost your Code List for your DirecTV Universal Remote Control?
Would you like a digital copy of the DirecTV Universal Remote Control Code List for easy searching of terms and quick reference?
The DirecTV Universal Remote Control Code List is available free in pdf format, just follow the link below (& Click FREE):
Download DirecTV Universal Remote Control Code List
I hope that helps.
________________________________________________
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Search
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Televison & Video
Tip
Download DirecTV Universal Remote Control Manual
Have you lost your Owner's Manual for your DirecTV Universal Remote Control?
Would you like a digital copy of the DirecTV Universal Remote Control Users Guide for easy searching of terms and quick reference?
The DirecTV Universal Remote Control manual is available free in pdf format, just follow the link below (& Click FREE):
I hope that helps.
Direct tv remote to visio tv
I can help you with your Vizio TV & DirecTV remote control.
This is a list of all the Vizio TV control codes for DIrecTV remote controls:
11758, 10864, 10885, 11499, & 11756.
Complete instructions on entering DirecTV remote control codes are here.
I hope that helps.
DirecTV Remote Control Onscreen Setup
May 13, 2010 | Universal Remote Control DIRECTV Universal...
How can i program my directv rca universal remote for my philips dsx 5500 receiver?
Press and "HOLD" CODE SEARCH.
2- Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
3- Enter the three digit code from the TV codes below
Philips 006,007,010,011,013,016,033,035
4- Release CODE SEARCH. 6- With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists
Hope this Helps you out
Cheers Little Dish Fitter
Oct 10, 2009 | RCA DIRECTV Satellite Remote Control
Tip
I hope that helps.
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
Tip
I hope that helps.
Philips Universal Remote
return it and get your money back. It's almost impossible to get through to their technical support and if you do they just give you the run around.
Jan 18, 2008 | Universal Remote Control DIRECTV Universal...
Philips SRP5107/27 UNIVERSAL REMOTE 7 IN 1LED ILLUMINATED KEYS Logo
315 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
