Question about Elna 8007
My pfaff hobbylock 4860 won't stitch correctly. Any ideas? I have threaded the machine many times and it doesn't help. It was service about a year ago and it's the first time I have tried to use it.
bargainbox
  • 1388 Answers
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Posted on Feb 01, 2008
SOURCE: Failure to form stitches
I needed to have it fixed as soon as poss so I had to take it to a machine repair man. He saw straightaway that it had a broken gear which was something I could never have sorted myself. Thanks for your reply.
Posted on Dec 04, 2008
bargainbox
  • 1388 Answers
SOURCE: thread nests created in bobbin area
Please TRY the solution BEFORE giving your considered rating.
Specific detail on bobbin case adjustment (with picture) near halfway down reply, the remainder will help you achieve a balance of top and bottom tensions.
Ensure that all is clean and free of lint and jams, this is the most likely cause....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tesion to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks
Best Wishes
Martyn
Bargain Box in Australia
Posted on Sep 17, 2009
  • 1788 Answers
SOURCE: I have an elna overlock
If you google elna overlock pro 5dc, I found this site and you can download your manual for $10, hopefully it will help you.http://www.tradebit.com/filedetail.php/30251842-elna-pro-5-dcde-sewing-machine-owner
It is so frustrating to have a great machine and no one can help you. Good luck
Posted on Sep 21, 2010
  • 1788 Answers
SOURCE: I've borrowed an old elna machine and I used it
Go to www.sewusa.com and you can see threading of different machines. You can buy a manual from them also. You tube shows how to thread machines also. Good luck
Posted on Jan 01, 2011
I need a video on how to thread a pfaff hobbylock 4842 serger
Pfaff has a video on threading the Hobbylock 4842 here: http://www.pfaff.com/mediafiles/threading_guide/index_en.html . You need Adobe Flash Player available on your browser. Enter the tutorial, the link is below the Quick Help paragraph. Then choose the correct machine (from the links across the top). Then use the drop-down menu to choose the stitch that you will be sewing for the appropriate threading video. Then click on the appropriate thread (below the video window) to see how to thread that section of the serger. (For two-thread stitches, you will see two options are greyed out.)
I hope this helps.
Jun 14, 2017 | PfaFF Sewing Machines
Pfaff hobbylock 4842 serger - how to thread
here is a manual:
PFAFF hobbylock 4842 Instruction Manual
Be sure to ALWAYS RAISE the presser foot when threading the machine. Also, thread each thread in the ORDER specified or your machine will most likely never stitch correctly (usually, the upper looper first, lower looper next, and then the needles).
I am looking for a lower looper for a Pfaff Hobbylock 4860 serger
There are some for sale on Ebay:
(this one has a better price tag)
http://www.ebay.com/itm/Pfaff-Home-Sewing-Lower-Looper-330667?item=280441236342&category=41248&rdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBIN&cmd=ViewItem
http://www.ebay.com/itm/Pfaff-Home-Sewing-Lower-Looper-340638?item=280441236320&category=41248&rdZ1QQssPageNameZWINQ3aPOST0Q3aRECOQ3aBIN&cmd=ViewItem
Oct 19, 2011 | PfaFF Hobby 4260
I need a manual for a Pfaff Hobbylock Serger 4762, where can I find one
I can't find a manual for this model, however there is a general hobbylock book http://sewingonline.co.uk/library/know-your-pfaff-hobbylock.html which would certainly be a good start.
You may find best source is to contact Pfaff locally and source it from them direct.
You could also try www.diplodocs.com, I can't see this manual but if you go through similar model numbers manuals you may see one very similar. Overlockers/Sergers are very similar in many ways so once you've mastered one, the next one is pretty straight forward. Four tension knobs, 2 needles and 2 loopers is the norm - to get a three thread stitch you just don't thread one of the needles. Tension adjustments alter the stitch formation, and you should have a stitch length knob on the right side of the machine along with a flywheel and if it has it, differential feed (which controls the feed dogs so you can stretch, or compress the fabric as it goes under the foot).
There are some good general how to use a serger books in the marketplace too which should help. Threading up, many machines have a diagram inside the front flap, colour coded dots on the knobs, eyelets and loopers. And oiling points are often marked on this diagram too. But basically oil the two loopers where they slide/move on another metal part. Some good info here too http://sewing.about.com/od/sergersoverlock/Sergers_Overlock_Sewing_Machines.htm
Hope this assists you a little.
Apr 18, 2011 | Sewing Machines
Hobbylock 797 how to thread
The hobbylocks all thread in much the same fashion.  There is a diagram for a four thread hobbylock on this website.  It would be better if you found a Pfaff dealer to show you as it is quite complicated.
http://www.pfaffmachines.co.uk/overlock/pfaff-hobbylock-2-overlocker.htm
Once you have it threaded, always cut the old threads at the spool and knot new ones on and pull through.  You will have to thread the needles as the knots will not pass through but it does save an awful lot of frustration when needing new colours on the spools.
Mar 28, 2011 | PfaFF Sewing Machines
Need Manual, wife passed and I have no idea on how to thread or use the hobbielock 786
The hobbylock 786 is quite complicated to thread without visual help. Try and find a Pfaff dealer and take it in to them. They should be able to show you and help you though it.
I do not want payment for this.
Jan 25, 2011 | PfaFF Quilt & Craft Pro 7530
Hobbylock 796 left thread not sewing
If the machine is correctly threaded this could be caused by incorrect installation of the left needle, if not full inserted it can cause the machine to drop the stitch, just loosen the needle and push it up into the holder.
Feb 11, 2009 | PfaFF Creative 7570
I have a pfaff Hobbylock 4860 serger. I got it serviced about 6 months ago but never used it until about a month ago. Now it will not cut my fabric as I serge. What should I do?
If it won't cut then you need either a new upper knife or lower knife. One or both has gotten dull or nicked up. The place you got it serviced or any dealership should be able to order new knives for it.
Dec 10, 2008 | Sewing Machines
Hobbylock 794
You have a timing problem which needs a technician to repair. to do this properly, you need some special gauges which, generally , are not found just anywhere. Take it a technician and get an estimate before you leave it.
sewman7
Oct 27, 2008 | PfaFF Hobby 4260
Manual
I have an extra copy of the manula for the PFAFF 783 Hobbylock. It cost me $12 plus $2 postage when I bought
it 4 years ago. Write me if interested. TRKSOCREF@aol.com
Sep 22, 2007 | Sewing Machines
Sewing Machines Logo
78 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Derek Massey
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
