Question about Lexmark C510 Laser Printer
C510 printer displays "994 Service Engine Error". How do you address this?
Printer displays "994 service Engine Error". How do you address this?
  • wayne churchill May 11, 2010
    Is this error on a C510?, because the manual lists 994 as OPC belt marker sensor error.
    Normally with an engine service error i reflash the engine firmware first, if that doesn't cure the fault i would then replace the engine board. If you need the firmware, visit the Lexmark site get the contact phone number for your region and ring them. They're normally quite helpful and of coarse can tell you how to reflash it.
3 Suggested Answers
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: C510 printer displays
    This error is likely the Photodeveloper Cartridge. You can try taking it out of the printer turning the white gear on the bottom right untill you see the black markers once you see the black markers then try to wipe them off with a lint free cloth. Reinstall the Photodeveloper and see if the error goes away. If it does then it will need to be replaced.
    Posted on Feb 01, 2010
    don_farr
    • 1011 Answers
    SOURCE: C510 printer displays "994 Service Engine Error". How do you addr
    Here you go, courtsey of Lexmark's Knowlwdgebase.
    Don
    994 Service Engine Error on a Lexmark C510 ID: ENUS21233 If your printer is unable to move the photodeveloper belt to the correct position during printing, a 994 error will occur. However, it may simply be the case that the photodeveloper is either contaminated with excess toner or improperly installed. To test for and resolve this issue, please do the following:
    1. Power the printer off and remove the photodeveloper cartridge.
    2. Rotate the green metallic photodeveloper belt by manually turning the white drive gear on the bottom of the cartridge until the black positioning markers are visible.
    3. If necessary, carefully wipe any excess toner powder from the positioning markers using a soft, lint-free cloth or tissue.
    4. While the top cover of the printer is still open, inspect the sensor that is used to locate the positioning markers on the belt. CAUTION! The photodeveloper is very sensitive to light. Cover the green metallic surface of the photodeveloper with a piece of paper while it is outside the printer.
      • Refer to this image, this image, and this image to identify the location of the sensor.
      • Verify that the sensor has not come loose from its housing and that it is not contaminated with excess toner powder. If necessary, clean the sensor with a soft, lint-free cloth or tissue.
    5. Re-install the photodeveloper cartridge and power the printer back on.
    6. If the error remains, it is likely that a service call will be necessary to resolve this issue. Please contact Lexmark Technical Support, having first obtained the serial number of your printer. NOTE: If practicable, attempt to order another photodeveloper and replace it first to avoid the inconvenience of a potentially unnecessary service call.
    Posted on Jun 22, 2009
    Lexmark C510 994 service
    If you are getting this error message, there is a need to replace the following:
    Marker sensor - 56P1684Engine Board - 56P1639 I/O board - 56P1617LVPS - 56P1641
    I
    Nov 28, 2011 | Lexmark C510 Laser Printer
    Lexmark C510 can not print and display with 994 service engine error. How to solve this problem. Thank you very much
    Please click on the link http://bit.ly/rv412w to see instruction on how to go about the procedure.
    For further assistance, please contact Lexmark Technical Support.
    Jun 08, 2011 | Lexmark C510 Laser Printer
    Printer is not printing - keeps showing 994 service engine error - pls help
    Please click on the link http://bit.ly/rv412wto see instruction on how to go about the procedure. For further assistance, please contact LexmarkTechnical Support.
    May 26, 2011 | Lexmark C510 Laser Printer
    My lexmark c510 has the following message - 994 engine service error
    Remove photodeveloper cartridge and observe markers on side. Clean these markers and try again
    Mar 08, 2011 | Lexmark C510 Laser Printer
    From a previous post: Posted by waynechurch on Apr 24, 2009 Is this error on a C510?, because the manual lists 994 as OPC belt marker sensor error.
    Sep 25, 2009 | Lexmark C510 Laser Printer
    Don
    Jun 22, 2009 | Lexmark C510n Laser Printer
    Lexmark C510 - Printer will not print
    Message:
    Invalid Engine Code
    What this message means:
    The printer engine code has not been programmed or is not valid.
    What you can do: [Not much]
    Call for service.
    See also: Calling for service
    Dec 04, 2008 | Lexmark C510 Laser Printer
    I have a Lexmark C510 and it's giving me an engine error 994. What do i do? I need your help.
    here is an excerpt from the lexmark technical tips library it could be usefull
    Bulletin Summary: 994 Density Sensor Error
    Document Date: Feb 03 2004
    Operating System: Printer Based
    Issue:
    The 994 Density Sensor Error can be caused my many different things. The basis of the Error comes from the printer not being able to do the auto calibration and the auto registration when the printer is turned on. Toner Patches are written to the belt on ever Power Cycle of the printer or when ever a door or cover is opened on the printer when the Auto Color Adjust is turned on and the Auto Registration is turned on. If too much of one color is placed on the belt or there is an absence of a color or all colors the printer will call the 994 Error. This error will also be called if the activation arm for the density sensor is not pushed in. Another thing that can cause the 994 Error is if the sensor for the under the belt for the BUD Clutch positioning is the incorrect part.
    Solution:
    Things to Try with Customer
    When the printer is powered on in Diagnostics the printer does not perform the Auto Calibration of Registration functions as would normally occur on POR. Turn the printer off and POR in Diagnostic Mode. From here print the Quality Pages under the Print Tests. These quality pages can give insight as to what is causing the 994 error.
    What to Look for on the Print Quality Pages
    First Look at the First Page on the Print Quality Pages. The first page tells mean things about the printer. There is a section that gives the Page Count on the printer, the Last 12 Errors, the Serial Number, Engine and Rip Code Levels. There is also a section on the first page that tells the last time the printer did the Auto Registration and Calibration. If the printer does not have 703.007 RIP on a C910 or IBM 1228 Printer this may not be displayed. Since there is only one Version of RIP on the C912 and IBM 1357's 720.013 this code will display the last time the printer was did a calibration and registration.
    Second - Go through all the Quality pages are any of the color planes missing completely?
    If only one color plane is missing it's possible that LED array is unplugged.
    Is the top half or bottom half of one or more color planes is missing completely?
    If yes then that one LED or Multiple LED's May have one Cable Unplugged.
    Are all the Color pages white but the black pages printed ok?
    If all the colors are missing and only black appears most likely the sensor under the Belt for the BUD Clutch position sensing is the incorrect part. This would only be the cause if that sensor was just replaced during fixing a 994 Error. Another check to do if this is the case is to look at the belt while it's in the printer. Open the Top Cover of the printer and check the right and left sides of the belt. The Belt should be raised on the right side and be equal height as the left side. The pictures below show the Belt in the Up and Down Position. If the belt is down when the printer tries to do the calibration no color will get transferred to the belt. This will cause the 994 Error. This also is why no colors would be appearing in all the planes but black is fine.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Dec 01, 2008 | Lexmark Office Equipment & Supplies
    Lexmark C510 Laser Printer Logo
    2,571 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
