Question about Goodman Heating & Cooling
Amana distinctions manual - Goodman Heating & Cooling
I have an Amana Distinction furnace, last heating season we had an issue with a lack of air movement to the second floor. We paid for a technician to come out. His solution - boost the blower speed.
If you have a variable speed motor The black wire going to the contactor relay is highest speed.or if there is a terminal strip near the motor there will be one wire and three places to plug a wire marked H, M, Low
Nov 07, 2014 | Amana Distinctions 95% Gas Furnace...
How do you hook up water for ice maker on the amana distinctions model DRB2201CW?
http://shop.amana.com/product_literature/search.jsp?siteCd=AMA
Apr 30, 2014 | Amana Refrigerators
Amana Distinctions 5 ton premium R410A system inducer draft motor short cycling and fan does not run
Amana distinctions furnace is the top quality furnace and I would you recommend to get professional technician help for that. You may call in Toronto at 905 201-1293, Clean Air Heat is there to help you out.
Jan 01, 2013 | Amana Distinctions 95% Gas Furnace...
I have an Amana Distinctions Washer DLW330RAW. I put a load in and in a couple of minutes had smoke. Shut it down and found the belt was broken and slightly burnt. I have replaced the belt but the...
The transmission is burned out. The same exact problem just occurred with my Amana Distinctions. Whirlpool will pay for this repair 'by concession'. Call the 800 number inside the lid and explain your problem, the operator should offer a free diagnostic visit and the repairman should offer free repair.
Aug 13, 2010 | Washing Machines
My Amana (distinctions) central heat and air unit -loud noise
If this s an Oklahoma Tulsa area call. KOOL BREEZES 918 6878813 for a diagnostic check.
Dec 05, 2009 | Heating & Cooling
Stall in rinse cycle
loks as if its been amonth since this post, but i would chek your cold water supply, common problem
Sep 05, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana Distinction leaks
this is a very common probelm with AM washer you have a bad upper sping bearing and at this point you need to cut your loses and send this one to the washer graveyard because this repair in labor intense
Jun 01, 2008 | Amana 3.2 cu. ft. Top-Load Washer
Amana Distinctions Dryer Runs for a while and then stops before clothes are dry
YOUR MTR IS GOING BAD PUT IN YOUR BUDGET TO REPLACE THE DR ASAP
May 29, 2008 | Dryers
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Heating & Cooling Logo
16 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
