Question about Makita 9910 Factory Reconditioned 3" X 18" Belt Sander
Makita 9910 belt slips - Makita 9910 Factory Reconditioned 3" X 18" Belt Sander
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Posted on Jan 19, 2009
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
Makita 9910
I think you'll need to replace the roller.
Aug 06, 2014 | Makita 3 x 24" Belt Sander
Makita planer 2012NB belt replacement
Use dish washing liquid to lubricate the roller and belt on both rollers and place the belt equally on each roller and move in on both rollers evenly
Feb 15, 2013 | Makita 2012NB Electric Planers
Makita 2012NB slipping
My makita2012NB was also slip too. I tried to fix it out then I found if I screwed the screw under the rollers tighter it could reduce this problem.
Nov 28, 2012 | Makita 2012NB Electric Planers
How do I change the belt on my Makita 2012 Planer
Probably not the proper way but it works. Assuming you have removed the side cover and the brace and are looking at the drive belt. I put my machine on its end so I was looking down on the belt. I put my belt on the first 2 groves of the small pulley and started the belt on the larger pulley (it will only go on about 1/3) using your allen wrench turn the large pulley clockwise while not letting the belt slip off the top. Now your belt should be started on both pulleys. From there it's a simple matter of walking the belt on one or two groves at a time by pushing down on the belt as it enters the pulley. Do one pulley then the other until it's completely seated in all groves.
Dec 31, 2010 | Makita 2012NB Electric Planers
Sander Belt keeps slipping off.
what I would do is using compressed air clean the underside as best you can there might be a buildup of dust not allowing the yoke to extend fully, then look at the condition of the rear roller, is should have a crown in the middle, make sure the belt tracking mechanism moves freely and I believe there was a plastic cap over the screw head to push the yoke. If it is not there it might be part of your problem. Lastly make sure if you are using directional belts that they are installed correctly, You can find a breakdown for this tool at Makitatools.com
Jun 09, 2010 | Makita 9404 4'' x 24'' Belt Sander
My Makita 9910 sander has the belt jammed. It started to walk sideways until it got jammed under the plastic at the edge. I can't move it after releasing tension. In fact now I have torn the sodding...
There should be a lateral running adjustment knob that corrects for this problem. It's too late for the current belt--get it out any way you can. Once you have a new belt in, bump the power button and try to correct the tracking in bursts. Once it is tracking, make only minor changes in the tracking adjustment so that you don't over-correct. Good luck!
May 20, 2010 | Garden
Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Jul 22, 2009 | Makita 9924DB Electric Sanders & Polishers
Clutch slipping on cordless drill. need spare parts to repair.
Are you sure you do not have a tourque adjustment problem. If not I do not believe Makita will want to send you parts,you would have to know what is precisely wrong and by the time you went back and forth you might as well find nearest dealer for repairs and google search Makita.com for service parts near you + zip code to get your drill fixed.
Thanks , Please rate jj505
Mar 28, 2009 | Makita 6349DWDE 18V 1/2" MXT Driver -...
Slipping belt
Jan 18, 2009 | Makita 3 x 24" Belt Sander
Makita 9910 Factory Reconditioned 3" X 18" Belt Sander Logo
56 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
