Question about Kenwood Car Audio Kenwood DNX690 / DNX690HD In Dash AV Navigation Receiver
My kenwood dnx690hd is in standby mode and will not turn on when I push the power button
Locked out
The setup Security Code can be done when the
<Demonstration mode Setting> (page 50) is set as OFF.
• When the Security Code function is activated, the code
can’t be changed and the function can’t be released.
Note, the Security Code can be set as the 4 digit number
of your choice.
1 Enter Standby
Press the [SRC] button.
Select the "STANDBY" display.
2 Enter Menu mode
Press the [MENU] button for at least 1 second.
When "Menu" is displayed, "Security" is displayed.
3 Enter Security Code mode
Press the Control knob for at least 1 second.
When "Enter" is displayed, "Security" is displayed.
4 Select the digits to enter
Push the Control knob to [4] or [¢].
5 Select the Security Code numbers
Push the Control knob to [FM] or [AM].
6 Repeat steps 4 and 5, and complete the
Security Code.
7 Confirm the Security Code
Press the Control knob for at least 3 seconds.
When "Re-Enter" is displayed, "Security" is
displayed.
8 Do the step 4 through 7 operation, and
reenter the Security Code.
"Approved" is displayed.
The Security Code function activates.
• When the wrong Code is entered in steps 4 through 6,
repeat from step 4.
Press the Reset button and when it’s removed
from the battery power source
1 Turn the power ON.
2 Do the step 4 through 7 operation, and enter
the Security Code.
The unit can be used.
In Standby mode
Touch Sensor Tone
Setting the operation check sound (beep sound)
ON/OFF.
Display Setting
"Beep : ON" Beep is heard.
"Beep : OFF" Beep canceled.
In Standby mode
Manual Clock Adjustment
• This adjustment can be done when the <Synchronize
Clock> (page 43) is set as OFF.
1 Select Clock Adjustment mode
Select the "Clock Adjust" display.
2 Enter Clock Adjust mode
The clock display blinks.
3 Adjust the hours
Adjust the minutes
4 Exit Clock adjustment mode
Press the [MENU] button.
The Whole manual is here.
http://www.kenwood.net-disp.com/i/05products/kdc_x789/pdf/kdc_x889_x789_mp828_k_english.pdf
Dec 06, 2007 | Kenwood KDC-MP628 CD Player
Kenwood car steroe KDC-108 error 99 code, how to fix?
Try to press the reset button on Kenwood (It returns to factory
settings when the reset button is pressed)
Jan 17, 2015 | Kenwood KDC-108
I have a kenwood kdc-mp235 unit and I bought a cable to hook smart phone to auxiliary port, I can play a cd or tunerbut no auxiliary! How do I fix this, I push src button but I get no auxiliary selection
You have to have the deck in "standby" mode before entering the settings menu. Press the source button until Standby comes up, then press and hold the menu button. Use the 4-way switch to scroll through the menu options until you get to AUX, then press the switch to the right to turn it on.
I got this from yahoo, click here to view.
Hope it helps.
May 29, 2011 | Kenwood Car Audio & Video
Cant adjust the time o the clock
  1. Select Clock Adjustment item during Menu mode (In Standby mode see below for standby mode explained). Select the "Clock Adjust" display.
  2. Enter Clock adjustment mode. Press and hold the control knob for at least one second. The clock will blink.
  3. Adjusting the clock. Push the control knob towards the left or right to select hours or minutes. To adjust each item turn the control knob or push it towards up or down.
  4. Exit clock adjustment mode. Press the (FNC) button.
  • Turn on the power.
  • When the power is ON, select a source.
  • SRC Select mode 1: PRess the (SRC) button and then turn the Control nob or push it toward left or right.
  • To determine the selected source, press the Control knob.
  • SRC Select mode 2: Pressing this button each time switches between sources.
  • Turner ("Turner"), USB or iPOD ("USB" or "iPod"), CD ("Compact Disc"), Auxiliary input ("AUX"), and Standby ("STANDBY")
  • Press at least 1 second to turn off the power
Nov 10, 2010 | Kenwood KDC-MP538U Car CD/ MP3 Player
I have a kenwood kdc-mp205 cd player. how do i change the clock? i do not have a manual.
Here is how to set the clock :
Enter standby Mode:
Press the [SRC] button,Select the "Standby" display.
Select clock Adjustment mode:
Push the control knob towards FM or AM, thenn Select the CLK ADJ display.
Enter Clock Adjust mode:
Press the control knob at least 1 second until the clock display blinks.
Adjust the Hours:
Push the control knob towards AM or FM
Adjust the Minutes:
Push the control knob towards |<< or >>|
Exit Clock adjustment mode:
Press the [Menu] button.
That should do it!
May 06, 2010 | Kenwood KDC-MP205 CD Player
I want to change the clock on my Kenwood Excelon KDC-X589.
try in standby mode push the menu button scroll through with track button till you see clock adj if not in standby mode try it in cd mode same steps
Mar 15, 2009 | Kenwood KDC-X589 CD Player
Connecting Bluetooth to Kenwood KDC X590
you need a kenwood kca-bt200 which is a bluetooth plugin for your head unit. when you have installed this here is a check to see if its recognised.
1 Select the STANDBY
Select the "STANDBY" display.   2 Enter Menu mode
D-1:Press the [MENU] button for at least 1 second.
D-2:Press the [MENU] button.
D-3:Press the [FNC] button.Turn the Control knob to select "MENU", and then press the Control knob.
"MENU" is displayed.   3 Select Bluetooth device selection mode
Push the Control knob towards up or down.
Select the "Phone Selection"/"PHONE SEL"/"PHN-SEL" display.   4 Enter the selected Bluetooth device selection mode
Press the Control knob for at least 1 second.   5 Select the KCA-BT200 Firmware
Select the "BT200 FW ***" display.   6 Exit the Bluetooth device selection mode
D-1/D-2:Press the [MENU] button.
after this you should be able to pair from the headunits menu
Nov 27, 2008 | Car Audio & Video
Kenwood KDC-138 Standby Question
Standby mode does not completely power down the unit it jsut does not draw as much power as when the unit is on. Also, depending on the unit, it might start back up faster in standby then from power off. You can select to have certain things displayed while in standby mode. Here is what can be selected for this unit:
Standby: displays CD loaded indicator, "STBY" indicator, and clock (when selected)
Hope this was helpful.
Oct 29, 2008 | Kenwood KDC-138 FM / AM Receiver
Kenwood Exelon 891
Check for dry joints in the display unit
Jan 15, 2008 | Kenwood KDC-X891 CD Player
Kenwood Car Audio Kenwood DNX690 / DNX690HD In Dash AV Navigation Receiver Logo
83 people viewed this question
Top Kenwood Car Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kenwood Car Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
