Question about Whirlpool Dryers
Lhe7800N1 needs a new thermostat but I cannot find any information. should I just get a new dryer? This one has been working fine for over 20 years with only two heating element replacements during that time.
  • 1028 Answers
SOURCE: Kenmore Dryer Model 110 Heating Element & Thermostat
believe that model has a relay under console..pull console end caps off remove screw on each end roll console back..if your model has an electronic bd it also has a heat relay it will be the one with 2 large red wires.. a quick ck would be to unplug power remove the red wires and tape bear ends together pug back up turn on dryer if it heats unplug and exchange the 2 relays the one with the blue wires is the motor relay and is same as heat relay try again if motor fails to start bad relay if motor starts bad control bd
Posted on Aug 10, 2008
jsrock516
  • 5911 Answers
SOURCE: Dryer Top Hot / New Heating Element Smell
Any time you perform work inside a dryer, lint can get kicked around and settle on components. It is common to have a slight burning smell for a day or so. However, your dryer getting too hot to the touch concerns me. Improper air flow is the number one cause of dryer overheating problems. You may have cleaned the lint out of the interior of your dryer, but did you check the air blower and vent duct lines? In addition, was the heating elements actually bad? Or, did you assume it was bad, because your dryer wasn't drying properly? The following link can explain:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
Pay particular attention to the paragraph that discusses proper ventilation. I would recommend you remove the vent hose from the back of the dryer and attempt to dry another load. If the dryer dries more efficiently and the top panel does not get scorching hot to the touch, then you have a vent clog somewhere EXTERNAL to the dryer. If the dryer air flow exiting the dryer is weak and the dryer still gets too hot to the touch, you have a clog INSIDE the dryer.
Follow these steps, first and see what you find. If you verify your ventilation is clear and not kinked or clogged anywhere, then you might assume you have a component malfunction. I would hope to try to save you from purchasing parts you may not need. I hope you find this information helpful. Let me know if you require additional assistance.
PS Make sure you are using semi-rigid (metal type) vent ducting. It is crush resistant, heat resistant, does not kink easily, and resists rodents. It is what most manufacturers recommend. If you haven't replaced the dryer vent in a while, this may be a good time.
Posted on Nov 18, 2008
Illeagle
  • 525 Answers
SOURCE: maytag neptune (gas dryer) just stopped heating
Gas dryers utilize a gas valve, ignitor assembly, and a series of coils mounted on the gas valve to provide heat and safety. The gas valve coils are the usual suspect when it comes to a "No Heat" complaint. I have provided a checklist from www.repairclinic.com, for your convenience. They also provide disassembnly diagrams and repair parts.
Firstly, ascertain that you have made an adequate "Heat" selection, then read on:
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Jul 08, 2009
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
tbreeze47
  • 3083 Answers
SOURCE: I have a samsung DV337AEG/XAA Electric Dryer which
This one isn't going to be easy, you've already replaced the major things. I'm guessing there's a crack in some connector, or other defect, that heats up like the element and opens up- giving the same symptoms. It could be a faulty connection in the power feed to the element connector, or any other connection en route to it. You might see something suspicious. If you have some electronic skills, you might run the dryer until it happens, then quickly disconnect it, and while it's still hot, ohm out all power connections and wiring that could affect the element. You might get lucky and find the open line, being able to hone in on the bad connection, etc. Good luck!
Posted on Mar 25, 2010
Brand new Maytag dryer has been coverted to propane and it keeps breaking (not heating up). The service contractor replaced some parts, tested it and worked fine for 1 day. Today I washed a blanket and...
even though the you might have a new dryer the vent line could be blocked with lint,or there are other parts that could go on a gas dryer,bad thermal fuse,gas coils,ignitor,sensor one of the thermostats,the only way to tell is to get in there with a meter,unplug the dryer remove at least one of the wires on the part you're checking and check the parts for continuity.that's a neptune those are the machines that put maytag out of bussiness a few years ago,i don't think it's new.you can go here and look up the parts i told you to check,if you need anymore help let me know.
Aug 24, 2013 | Maytag Neptune MDG5500AW Gas Dryer
My whirlpool awz 231 does not dry clothes,i take the back of the machine and test for continuity at both the thermostats and the element,all seems fine,i start a warm cycle and it works for about 15/20...
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Nov 28, 2010 | Dryers
We have a Maytag gas dryer that is probably 15 to 20 years old. It still works fine, but it makes a noise when it fist starts up. Sort of like a grinding sound .
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Oct 27, 2010 | Maytag Dryers
One month ago, my gas dryer began taking forever to dry the clothes. Upon inspection, I noticed I had a very badly clogged outside vent. I removed the vent and replaced the entire length of vent from the...
It sounds like it never was the thermostat. Usually when a thermostat goes there is no heat at all, unless it was the cycling t-stat, but unlikely. This sounds like the dryer coils are failing. They tend to fail as they heat up. They are inexpensive and easy to replace.
Here is a video at this will walk you thru the troubleshooting a gas dryer. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Sep 28, 2010 | Whirlpool LGB6300 Gas Dryer
Too hot wather/ thermostat problem
its 3 phase not 4 Your wired wrong one of those should be a nuetral or ground
May 10, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Jul 16, 2009 | Kenmore Dryers
There is a gas smell by my washing machine and dryer.
Ceck the follow instruction just to veryfy what kind of problems your dryer has. You dont have to buy anything just check all the information that is given to you
http://www.youtube.com/watch?v=rQV-z4f7fvA
Your ratting is very important to me
Was this helful?
May 21, 2009 | Kenmore Dryers
Replacing saftey thermostat monthly
Clean dryer vent to improve airflow so dryer will not cycle on high limit thermostat. The best way is to use a cordless drill vent cleaner designed to clean dryer vents. Manual brushes are also available, or you can disassemble, clean, and reassemble vent. (if so, use the foil tape when reassembling) Make sure you are not using flex dryer venting. This should also improve dryer performance, reducing dry time.
Jul 10, 2008 | LG DLE2532W Electric Dryer
My Hunter thermostat that controls both my air conditioner and heating system worked fine for a couple of years. Then the date and time started getting out of whack. I replaced the batteries..problem still...
If the Hunter thermostat is 3 year old or more you will need to replace the thermostat. I have serviced HVAC systems for 20 years and see this problem all the time with hunter thermostats.
Mar 29, 2008 | Computers & Internet
Kenmore dryer doesn't get hot but drum rotates fine
I read on another page
1) One of the thermostats could have a reset switch on it to cure problem... do not know where to find it or what it looks like! ....
2) May need to replace the element...
3) Could be the exhaust thermostat / or heater and thermostat complete/ check continuity...should be normally closed(complete circuit)
Any help to you ????
Best wishes willow
Mar 13, 2008 | Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
