Question about JVC Arsenal KD-AR560 CD Player
Color codes for my jvc arsenal kd-ar560 wire harness
I need color codes for my jvc arsenal kd-ar560 harness because the wires are not labeled. i need to know what color wire goes to what speaker, what color wire is the power, etc......
  • 655 Answers
Hello jlj2382,
Here's the wire colors for your KD-AR560:
Black = Ground (to vehicle chassis)
Yellow = Constant 12V (power)
Red = Accessory (to vehicle accessory terminal)
Blue/White = Remote turn-on lead (to remote amp)
Orange/White = Illumination (to vehicle light control switch)
Brown = Cell Phone terminal
White = Left Front Speaker positive (+)
White/Black = Left Front Speaker negative (-)
Gray = Right Front Speaker positive (+)
Gray/Black = Right Front Speaker negative (-)
Green = Left Rear Speaker positive (+)
Green/Black = Left Rear Speaker negative (-)
Violet = Right Rear Speaker positive (+)
Violet/Black = Right Rear Speaker negative (-)
Hope this helps.
Posted on Apr 24, 2009
Need color codes
Do you need color codes for the deck.. they should be on a sticker on the unit itself...if you need color codes for the vehicle your driving thats another thing..does ur vehicle have a harnass?? Or was the stereo harnass and plugs cut?
black..ground
yellow..battery 12v
red..accessory
Blue/white..remote
orange/white..illumination
brown..phone
white..front left +
White/black..front left -
Grey..front right +
Grey/black..front right -
Green..left rear +
Green/black..left rear -
purple..right rear +
Purple/black..right rear -
Apr 11, 2014 | JVC Arsenal KD-AR560 CD Player
How do i match the color code for my radio in my 1996 toyota avalon
You should buy a wiring harness for your vehicle. That would solve your problem because Replacement head units all have the same color coding you should always buy a wiring harness when replacing any head unit for a proper install.
May 25, 2010 | JVC Arsenal CS-AR690 Coaxial Car Speaker
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
I NEED A WIRING GIAGRAM BECAUSE THEIRE IS NO COLOR TO COLOR PATTERN ON BACK OF MY JVC-KD-G320
This may help your cause
http://www.nodevice.com/manual/JVC/page24.html
Jun 11, 2009 | JVC KD-G320 CD Player
Connect jvc kd-lh1150 in elantra 2001... different connector
Hello claude_bouth,You need a vehicle specific aftermarket connector generally called a "wiring harness". Your JVC came with a plug that fits the back of the receiver with "pigtail" wires which you splice to the harness wires. http://www.SonicElectronix.com sells the Metra 70-7301 which appears to be the correct harness for your Elantra.You can tap into the wiring of the car harness and splice the wires by function into the appropriate car wires, but using the aftermarket vehicle specific wiring harness is a lot easier and you don't need to disturb the vehicle wiring in any way, just plug into it. It also makes it possible to re-install the factory radio if you ever need to do so. If you choose to tap and splice, you can find your Elantra's wiring color code at http://www.modifiedlife.com.Hope this helps.
Jun 05, 2009 | JVC Arsenal KD-LH1150 CD Player
How to wire car speaker to JVC CD Receiver.
Hello anstrayer,
On your JVC wiring harness the speaker wire colors are:
Left front (+) - White
Left front (-) - White/Black
Right front (+) - Gray
Right front (-) - Gray/Black
Left rear (+) - Green
Left rear (-) - Green/Black
Right rear (+) - Purple
Right rear (-) - Purple/Black
You can download a the manual from Crutchfield. A complete wiring diagram with color codes is on page 41.
Hope this helps.
May 31, 2009 | JVC Car Audio & Video
Hi - You can download the manual from the link underlined in blue below:
KD-AR560
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Aug 17, 2008 | JVC Arsenal KD-AR560 CD Player
Jvc arsenal cd player in car
sounds like a ground issue... or a blown speaker. I would try to re-ground the unit first
Mar 07, 2008 | JVC Arsenal KD-AR560 CD Player
Subwoofer instalation
Even if your JVC doesn't have outputs for a subwoofer you can hook it up with the a speaker wire to RCA converter. You just spice your rear speaker wires to this device then connect RCA's to your amp. I've used them before... works great. http://cgi.ebay.com/ebaymotors/Speaker-to-RCA-Line-Level-Converter-Adjustable-High-Low_W0QQitemZ130143832174QQihZ003QQcategoryZ38636QQcmdZViewItem
Aug 20, 2007 | JVC Arsenal KD-AR560 CD Player
JVC Arsenal KD-AR560 CD Player Logo
979 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
